BAT54/A/C/S
SOT-23 Plastic-Encapsulate Diodes
BAT54/A/C/S
SOT-23
SCHOTTKY BARRIER DIODE
FEATURES
Extremely Fast Switching Speed
MARKING:
BAT54
BAT54A
BAT54C
BAT54S
Maximum Ratings (Ta=25℃ unless otherwise noted )
Parameter
Symbol
Peak Repetitive Reverse Voltage
VRRM
Working Peak Reverse Voltage
VRWM
Value
Unit
30
V
DC Blocking Voltage
VR
Forward Continuous Current
IFM
200
mA
Non-repetitive Peak Forward Surge Current @ t=8.3ms
IFSM
600
mA
Repetitive Peak Forward Current @ t≤1s,δ≤0.5
IFRM
300
mA
Power Dissipation
PD
200
mW
RΘJA
500
℃/W
Junction Temperature
Tj
125
Storage Temperature
Tstg
-55~+150
Thermal Resistance from Junction to Ambient
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Reverse voltage
Forward voltage
Symbol
Min
V(BR)
30
Typ
VF
Max
Unit
Test conditions
V
IR=100μA
0.24
V
IF1=0.1mA
0.32
V
IF2=1mA
0.40
V
IF3=10mA
0.50
V
IF4=30mA
1
V
IF5=100mA
Reverse current
IR
2
μA
A
Diode capacitance
CD
10
pF
Reverse recovery time
trr
5
ns
R=25V
VR=1V,f=1MHz
IF=IR=10mA
Irr=0.1×IR,RL=100Ω
The above data are for reference only.
https://www.microdiode.com
Rev:2025A4
Page :1
BAT54/A/C/S
Typical Characteristics
Forward
Characteristics
Reverse
300
200
Characteristics
100
100
(uA)
REVERSE CURRENT IR
FORWARD CURRENT
T=
a 2
5
o
C
IF
T
10
a
=1
00
o
C
(mA)
o
Ta=100 C
1
0.1
0.01
10
1
o
Ta=25 C
0.1
0.01
400
600
FORWARD VOLTAGE
800
VF
1000
(mV)
5
10
15
REVERSE VOLTAGE
25
VR
30
(V)
Power Derating Curve
Capacitance Characteristics
(mW)
f=1MHz
200
PD
16
12
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
8
4
100
50
10
15
REVERSE VOLTAGE
VR
25
(V)
30
50
75
AMBIENT TEMPERATURE
URE
Rev:2025A4
100
a
125
Page :2
BAT54/A/C/S
Outlitne Drawing
SOT-23 Package Outline Dimensions
θ
A
A1
b
c
D
E
E1
e
L
L1
θ
L
L1
E
E1
Symbol
1
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
Dimensions In Millimeters
Min
Typ
Max
0.65
1.40
0.20
0.00
0.30
0.55
0.20
0.08
2.70
3.10
1.15
1.65
2.80
2.10
1.70
2.10
0.15
0.50
0.35
0°
0.70
12°
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-23
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
330
3000
190*190*1900
45000
400*400*220
180000
7'
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“BAT54A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17230
- 100+0.10680
- 800+0.07050
- 3000+0.05040
- 6000+0.04780
- 30000+0.04430
- 国内价格
- 1+0.08876
- 10+0.06916
- 30+0.05827
- 100+0.05174
- 500+0.04603
- 1000+0.04303
