BZT52C-Series
Small Singnal Zener Diodes
SOD-323 Plastic-Encapsulate Diodes
%=7C9S%=7CS
SOD-323
=(1(5 DIODE
0.010 (0.25)
0.019 (0.475) ref.
0.080 (0.0031)
0.018 (0.45)
0.150 (0.0059)
0.108 (2.75)
0.100 (2.55)
8°
0.071(1.80)
0.063(1.60)
0° to
0.047(1.20)
0.008 (0.2 )
0.055(1.40)
0.014(0.35)
0.010(0.25)
0.039 (1.00)
Planar die construction.
7RWDOSRZHUGLVVLSDWLRQ0D[3P: :LGH
]HQHUUHYHUVHYROWDJHUDQJH9WR9
General purpose, medium current .
6PDOOSODVWLFSDFNDJHVXLWDEOHIRUVXUIDFH
PRXQWHGGHVLJQ
7ROHUDQFHDSSUR[LPDWHO\5
0.032 (0.80)
0.008(0.20)max.
Cathode bar
FEATURES
Marking
Dimensions in inches and (millimeters)
XX= Device code,see table on page2 the marking code
The marking bar indicates the cathode
Mechanical Data
Case : SOD-323
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00019 ounce, 0.00548 grams
Maximum Ratings(Ta=25 ℃ unless otherwise specified)
Characteristic
Forward Voltage at IF = 10mA
Symbol
Value
VF
0.9
V
Pd
mW
RθJA
17
Tj
150
℃/W
Tstg
-55 ~ +150
(Note 2)
Power Dissipation(Note 1)
Typical thermal resistance from junction to ambient(Note 1)
Junction Temperature
Storage Temperature Range
Unit
Notes: 1. Thermal resistance from junction to ambient at P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper areas pads.
2.. Short duUDtion test pulse used to minimize self-heating effect
3.. f =kHz
http://www.microdiode.com
Rev:2024A1
Page :1
BZT52C-Series
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
BZT52C2V0S
WY
1.8
2
2.15
5
100
120
0.5
BZT52C2V2S
WZ
2.08
2.2
2.33
5
100
120
0.7
BZT52C2V4S
WX
2.28
2.4
2.56
5
100
120
1
BZT52C2V7S
W1
2.5
2.7
2.9
5
110
120
1
BZT52C3V0S
W2
2.8
3
3.2
5
120
50
1
BZT52C3V3S
W3
3.1
3.3
3.5
5
130
BZT52C3V6S
W4
3.4
3.6
3.8
5
130
10
1
BZT52C3V9S
W5
3.7
3.9
4.1
5
130
5
1
BZT52C4V3S
W6
4
4.3
4.6
5
130
5
1
BZT52C4V7S
W7
4.4
4.7
5
5
130
2
1
2
1.5
1
2.5
BZT52C5V1S
W8
4.8
5.1
5.4
5
130
BZT52C5V6S
W9
5.2
5.6
6
5
80
BZT52C6V2S
WA
5.8
6.2
6.6
5
50
1
3
BZT52C6V8S
WB
6.4
6.8
7.2
5
30
0.5
3.5
BZT52C7V5S
WC
7
7.5
7.9
5
30
0.5
4
BZT52C8V2S
WD
7.7
8.2
8.7
5
30
0.5
5
BZT52C9V1S
WE
8.5
9.1
9.6
5
30
0.5
6
BZT52C10S
WF
9.4
10
10.6
5
30
0.1
7
BZT52C11S
WG
10.4
11
11.6
5
30
0.1
8
BZT52C12S
WH
11.4
12
12.7
5
35
0.1
9
BZT52C13S
WI
12.4
13
14.1
5
35
0.1
10
BZT52C15S
WJ
13.8
15
15.6
5
40
0.1
11
BZT52C16S
WK
15.3
16
17.1
5
40
0.1
12
BZT52C18S
WL
16.8
18
19.1
5
45
0.1
13
BZT52C20S
WM
18.8
5
50
0.1
15
BZT52C22S
WN
20.8
22
23.3
5
55
0.1
17
BZT52C24S
WO
22.8
24
25.6
5
60
0.1
19
BZT52C27S
WP
25.1
27
28.9
2
70
0.1
21
BZT52C30S
WQ
28
30
32
2
80
0.1
23
BZT52C33S
WR
31
33
35
2
80
0.1
25
BZT52C36S
WS
34
36
38
2
90
0.1
27
BZT52C39S
WT
37
39
41
2
100
0.1
30
BZT52C43S
WU
40
43
46
2
130
0.1
33
0.1
36
BZT52C47S
WV
44
47
50
2
150
BZT52C51S
WW
48
51
54
2
180
0.1
39
BZT52C56S
XW
52
56
60
2
200
0.1
43
BZT52C62S
6E
58
62
66
2
215
0.1
47
BZT52C68S
6F
64
68
72
2
240
0.1
52
BZT52C75S
6H
70
75
79
2
265
0.1
56
(1) V ZT is tested with pulses (20 ms)
Rev:2024A1
Page :2
BZT52C-Series
Typical Characterisitics
mA
103
mW
500
102
IF
400
10
Ptot
TJ = 100 °C
1
300
10-1
TJ = 25 °C
200
10-2
10-3
100
10-4
10-5
0.4
0.6
0.8
1V
VF
Fig. 1 - Forward characteristics
Fig. 2 - Admissible Power Dissipation vs. Ambient Temperature
Ω
100
Ω
1000
TJ = 25 °C
TJ = 25 °C
5
4
3
2
rzj
200 °C
Tamb
5
4
3
rzj
100
5
4
3
33
2
27
22
10
18
2
10
12
3
10
2
2
6.8/8.2
5.6
1
0.1
2
5
1
2
5
10
2
5
100 mA
Fig. 3 - Dynamic Resistance vs. Zener Current
0.1
1
5
2
Ω
103
Tj = 25 °C
7
5
4
2
2
Rzth
47 + 51
43
39
36
10
IZ
2
5
100 mA
Rzth = RthA x VZ x
5
4
3
2
Δ VZ
ΔTj
102
5
4
3
102
2
7
5
4
3
10
5
4
3
2
negative
2
10
0.1
5
Fig. 4 - Dynamic Resistance vs. Zener Current
Ω
103
3
6.2
1
IZ
Rzj
15
5
4
2.7
3.6
4.7
5.1
5
4
3
positive
1
2
3
4 5
1
2
IZ
3 4 5
10
mA
Fig. 5 - Dynamic Resistance vs. Zener Current
1
2
3
4 5
10
2
3 4 5
100 V
VZ at IZ = 5 mA
Fig. 6 - Thermal Differential Resistance vs. Zener Voltage
Rev:2024A1
Page :3
BZT52C-Series
Ω
100
mV/°C
25
7
5
4
Rzj
Δ VZ
ΔTj
3
15
10
10
IZ =
5 mA
1 mA
20 mA
7
5
5
4
3
Tj = 25 °C
IZ = 5 mA
1
1
2
3
10
4 5
2
3 4 5
-5
1
100 V
2
3
4 5
Fig. 7 - Dynamic Resistance vs. Zener Voltage
V
9
25
0.7
15
VZ at IZ = 5 mA
8
10
0.6
8
43
4
0.2
6.2
5.9
3
0.1
5.6
2
6
5
7
0.3
VZ at IZ = 2 mA
7
Δ VZ
0.5
0.4
36
1
5.1
4.7
3.6
- 0.2
60
80
IZ = 2 mA
-1
100 120 140 C
60
80 100 120
140 °C
Tj
Tj
Fig. 9 - Change of Zener Voltage vs. Junction Temperature
Fig. 10 - Change of Zener Voltage vs. Junction Temperature
mV/°C
100
V
1.6
IZ = 5 mA
Δ VZ
ΔTj
100 V
3 4 5
2
Fig. 8 - Temperature Dependence of Zener Voltage vs.
Zener Voltage
V
0.8
Δ VZ
10
VZ at IZ = 5 mA
V ≥ 27 V, I = 2 mA
VZ
Δ VZ = rzth x IZ
IZ = 5 mA
VZ ≥ 27 V; IZ = 2 mA
1.4
1.2
80
Δ VZ
1
0.8
60
0.6
0.4
40
0.2
- 0.4
40
80
100 V
1
2
3
4 5
Fig. 11 - Temperature Dependence of Zener Voltage vs.
Zener Voltage
10
2
3 4 5
100 V
VZ at IZ = 5 mA
VZ at IZ = 2 mA
Fig. 12 - Change of Zener Voltage from Turn-on up to the Point of
Thermal Equilibrium vs. Zener Voltage
Rev:2024A1
Page :4
BZT52C-Series
V
5
mA
50
ΔVZ = rzth x IZ
4
Tj = 25 °C
3.9 5.6
2.7
6.8
3.3 4.7
40
lZ
Δ VZ
3
8.2
30
IZ = 5 mA
2
Test
current
IZ 5 mA
10
IZ = 2.5 mA
60
80
100 V
2
3
4
VZ at IZ = 5 mA
5
6
7
8
9 10 V
VZ
Fig. 13 - Change of Zener Voltage from Turn-on up to the Point of
mA
30
lZ
Fig. 14 - Breakdown Characteristics
10
12
Tj = 25 °C
15
22
27
Test
10 current
IZ 5 mA
33 36
40 V
VZ
Fig. 15 - Breakdown Characteristics
Test Current IZ
2 mA
Fig. 16 - Breakdown Characteristics
The curve above is for reference only.
Rev:2024A1
Page :5
BZT52C-Series
Packing information
P0
unit:mm
P1
d
Item
E
F
B
A
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-323
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.028
B
0.7
0.7
C
2.5
0.085
D
1.8
0.071
E
3.2
0.112
0.028
Rev:2024A1
Page :6
很抱歉,暂时无法提供与“BZT52C27S”相匹配的价格&库存,您可以联系我们找货
