BZX84C2V4 THRU BZX84C43
Zener Voltage - 2.4 to 43 Volts
Peak Pulse Power - 0.3 W
SURFACE MOUNT ZENER DIODE
SOT-23
Features
Planar Die Construction.
300mW Power Dissipation
Zener Voltages from 2.4V - 43V
Ultra-Small Surface Mount Package Power Dissipation
Mechanical Data
Case : JEDEC SOT-23Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Dimensions in inches and (millimeters)
MAXIMUM RATING
@ Ta=25℃ unless otherwise specified
Parameter
Symbol
Value
Unit
VF
0.9
V
Power Dissipation
Pd
300
mW
Typical thermal resistance juncting to ambient
RθJA
417
℃/W
Junction temperature
Tj
-55 to+150
Storage temperature range
Tstg
-55 to+150
Forward Voltage
http://www.microdiode.com
@ IF=10mA
Rev:2024A2
Page :1
Peak Pulse Power - 0.3W
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Maximum
Temperature
Reverse
Coefficent of
Current
Zener voltage
Maximum Zener
Impedance
ZenerVoltage Range (Note 2)
Type
(Note 3)
Number
Code
@ IZT=5mA
VZ@IZT
IZT
Nom(V)
Min(V)
Max(V)
(mA)
ZZT@IZT
ZZK@IZK
(Ω)
mV/°C
IZK
IR
VR
(mA)
(μA)
(V)
Min
Max
BZX84C2V4
Z11
2.4
2.20
2.60
5
100
600
1.0
50
1.0
-3.5
BZX84C2V7
Z12
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZX84C3V0
Z13
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZX84C3V3
Z14
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZX84C3V6
Z15
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZX84C3V9
Z16
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZX84C4V3
Z17
4.3
4.0
4.6
5
90
600
1.0
3
1.0
-3.5
BZX84C4V7
Z1
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
BZX84C5V1
Z2
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
BZX84C5V6
Z3
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
BZX84C6V2
Z4
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
BZX84C6V8
Z5
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
BZX84C7V5
Z6
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
BZX84C8V2
Z7
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
BZX84C9V1
Z8
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
BZX84C10
Z9
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
BZX84C11
Y1
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
BZX84C12
Y2
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
BZX84C13
Y3
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
BZX84C15
Y4
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
BZX84C16
Y5
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
BZX84C18
Y6
18
16.8
19.1
5
BZX84C20
Y7
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
BZX84C22
Y8
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
BZX84C24
Y9
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
BZX84C27
Y10
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
BZX84C30
Y11
30
28.0
32.0
2
BZX84C33
Y12
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
BZX84C36
Y13
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
BZX84C39
Y14
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
BZX84C43
Y15
43
40.0
46.0
2
100
700
1
0.1
32
45
80
225
300
1.0
0.5
0.1
0.1
12.6
21.0
12.4
24.4
10
16.0
29.4
12
Notes: 1. Valid provided that device terminals are kept at ambient temperature.
2. Tested with p ulses, p eriod=5ms,pulse width =300μs.
3. f=1KHz
Rev:2024A2
Page :2
Ratings And Characteristic Curves
o
( TA=25 C Unless otherwise noted )
Zener Characteristics(VZ Up to 10 V)
Zener Characteristics(11 V to 43 V)
100
100
PD =300mW
Pulsed
0.5
1
2
3
4
6
7
10
0.5
10
11
15
43
39
36
40
45
50
Typical Leakage Current
100
Pulsed
FOR BZX84CXXX SERIES
10
IR, LEAKAGE CURRENT (uA)
30
25
VZ @ IZT
15
10
5
1
0.1
0.01
Ta=100℃
1E-3
Ta=25℃
8
12
16
28
32
36
40
1E-4
44
VZ, NOMINAL ZENER VOLTAGE (V)
10
15
30
35
40
45
Effect of Zener Voltage on Zener Impedance
Typical Capacitance
1000
1000
Ta=25℃
Ta=25℃
f=1MHz
ZZT, DYNAMIC IMPEDANCE(Ω)
100
1V BIAS
BIAS AT
50% OF VZ NOM
10
1
10
IZ(AC)=0.1IZ(DC)
IZ=1mA
0V BIAS
C, CAPACITANCE (pF)
35
TYPICAL Ta VALUES
35
1
33
30
27
25
VZ, ZENER VOLTAGE (V)
Temperature Coefficients
40
θVZ, TEMPERATURE COEFFICIENT (mV/℃)
1
-5
24
10
1
10
18
8.2
9.1
7.5
6.2
6.8
5.1
5.6
4.7
2.4
10
PD =300mW
11
12
13
IZ, ZENER CURRENT (mA)
Pulsed
Ta =25℃
15
16
Ta =25℃
100
f=1kHz
100
IZ=5mA
10
1
1
10
Power Derating Curve
350
250
POWER DISSIPATION
PD
(mW)
300
200
150
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
The cruve raph is for reference onl , can't be the basis for ud ment 曲线图仅供参考 !
Rev:2024A2
Page :3
Outlitne Drawing
SOT-23 Package Outline Dimensions
1
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
θ
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
1.00
1.40
0.10
0.35
0.50
0.10
0.20
2.70
2.90
3.10
1.20
1.60
2.4
2.80
1.90
0.10
0.30
0.4
0°
10°
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A2
Page :4
很抱歉,暂时无法提供与“BZX84C4V3”相匹配的价格&库存,您可以联系我们找货
