DHE1G
DHE1G
    MDD(辰达半导体)
DHE1G 数据手册
DHE1A THRU DHE1M Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT HIGH EFFICIENCY RECTIFIER Features SOD-123FL  Glass passivated device  Ideal for surface mouted applications  Low reverse leakage  Metallurgically bonded construction 0.075(1.90) 0.067(1.70) 0.031 (0.80) 0.043 (1.10) 0.114(2.90) 0.102(2.60)  High temperature soldering guaranteed: 250°C/10 seconds,0.375”(9.5mm) lead length, 0.051(1.30) 0.039(1.00) 5 lbs. (2.3kg) tension 0.010(0.25) 0.004(0.10) 0.035(0.90) 0.028(0.70) Mechanical Data 0.154(3.90) 0.141(3.60) Case: JEDEC 6OD-123FL molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum Maximum Maximum Maximum Ta=65°C SYMBOLS VRRM DHE1A DHE1B DHE1D DHE1G DHE1J DHE1K DHE1M U1A U1B U1D U1G U1J U1K U1M 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS V V V repetitive peak reverse voltage RMS voltage DC blocking voltage average forward rectified current at VRMS VDC I(AV) 1.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 25 A Maximum instantaneous forward voltage at 2.0A VF Maximum DC reverse current TA=25℃ at rated DCblocking voltage TA=100℃ IR Typical junction capacitance (NOTE 1) Maximum Reverse Recovery Time (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction temperature range Storage temperature range CJ trr 1.0 1.25 5 100 1.7 μA pF 25 35 V 75 ns RJA 180 ℃/W TJ -55 to +125 ℃ TSTG -55 to +150 ℃ Note: 1.Measured with IF=0.5A, IR=1A, Irr=0.25A. 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. . 3.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area. http://www.microdiode.com Rev:2024A2 Page :1 DHE1A THRU DHE1M Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Typical Characterisitics Noninductive Noninductive +0.5 D.U.T + - PULSE GENERATOR Note 2 25Vdc approx 0 -0.25 1 ohm OSCILLOSCOPE Note 1 NonInductive -1.0 Note:1. Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 2.4 300 2.0 100 I R - Reverse Current (μA) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 1.6 1.2 0.8 Single phase half wave resistive or inductive P.C.B mounted on 0.5×0.5"(12.7×12.7mm) pad areas. 0.4 0.0 25 50 75 100 125 150 175 T J =125°C 10 T J =75°C 1.0 0.1 T J =25°C 0 Lead Temperature (°C) 80 60 100 % of PIV.VOLTS Fig.4 Typical Forward Characteristics Fig.5 Typical Junction Capacitance 10 T J =25°C Junction Capacitance (pF) Instaneous Forward Current (A) 40 20 1.0 DHE1A~DHE1D DHE1E/DHE1K 0.1 DHE1M 0.01 0.001 0 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 30 20 T J =25°C f = 1.0MHz V sig = 50mV p-p 10 0.1 1 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 60 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 10 00 1 10 Number of Cycles Number of Cycles 100 The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 DHE1A THRU DHE1M Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SOD-123FL A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.1 4.0 1.60 1.55 178.00 50.0 13.00 1.75 3.50 4.00 4.00 2.00 E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 0.25 8.15 10.5 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) SOD-123FL 7" 3,000 4.0 45,000 210*208*203 178 430*430*235 180,000 APPROX. GROSS WEIGHT (kg) 9.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 1.2 0.047 B 0.047 C 1.2 3.2 0.126 D 2 0.079 E 4.4 0.173 Unit (inch) Rev:2024A2 Page :3
DHE1G 价格&库存
很抱歉,暂时无法提供与“DHE1G”相匹配的价格&库存,您可以联系我们找货
