ESD0302L
Ultra Low Capacitance TVS/ESD Protection Diodes
DFN1006-3L Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
ESD0302L is an ultra-low-capacitance Transient Voltage Suppressor (TVS) designed to provide
electrostatic discharge (ESD) protection For high-speed data interfaces. With typical capacitance of 0.2pF
(I/O to I/O) only, ESD0302L is designed to protect parasitic-sensitive systems against over-voltage and
over-current transsient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact
discharge), IEC 61000-4-4 (electrical fast transientt - EFT) (40A, 5/50 ns), very fast charged devicee
model (CDM) ESD and cable discharge event (CDE), etc. ESD0302L uses ultra-small DFN1006-3L
package. Each ESD0302L device can protect two high-speed data lines. The combined features of low
capacitance, small size and high ESD robustness make ESD0302L ideal for high-speed data port and
high-frequency line applications, The low camping voltage of the ESD0302L guarantees a minimum
stress on the protected IC.
Features
Peak Power Dissipation : 56W (8/20μs)
Transient protection for high speed data lines
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Cable Discharge Event (CDE)
Small package (2.9mm2.4mm1.0mm)
Protect two data lines
Low clamping voltage
Low Capacitance :0.2pF Typical (I/O - I/O)
Low leakage current
Applications
Serial ATA
Desktops, Servers and Notebooks
PCI Express
MDDI Ports
USB Data Line Protectioon
Display Ports
Digital Visual Interfacess (DVI)
Pin Configuration
Circuit Diagram
Mechanical Characteristics
Package: DFN1006-3L
Flammability Rating: UL 94V-0
Packaging: Tape and Reel
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Marking: 32L
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
VESD
Value
± 20
± 20
Unit
kV
Peak Pulse Power(tp=8/20us waveform)
PPP
56
W
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature Range
TSTG
−55 to +150
°C
The above data are for reference only.
DN:T21827A1
http://www.microdiode.com
Rev:2021A1
Page :1
ESD0302L
Electrical Characteristics (TA=25°C unless otherwise specified)
6\PERO
3DUDPHWHU
7HVW&RQGLWLRQ
95:0
5HYHUVH:RUNLQJ9ROWDJH
,2WR*1'
9%5
5HYHUVH%UHDNGRZQ
9ROWDJH
,7 P$
%HWZHHQ,2DQG*1'
,5
5HYHUVH/HDNDJH&XUUHQW
95:0 9
%HWZHHQ,2DQG*1'
Q$
,33 $WS ȝV
%HWZHHQ,2DQG*1'
9
,33 $WS ȝV
%HWZHHQ,2DQG*1'
9
,7 P$
%HWZHHQ,2DQG*1'
9
9&
9)
&7
0LQ
7\S
0D[
8QLWV
9
9
&ODPSLQJ9ROWDJH
)RUZDUG9ROWDJH
95 9I 0+]
%HWZHHQ,2DQG*1'
S)
95 9I 0+]
%HWZHHQ,2DQG,2
S)
7RWDO&DSDFLWDQFH
Rev:2021A1
Page :2
ESD0302L
ELECTRICAL CHARACTERISTICS CURVE
Rev:2021A1
Page :3
ESD0302L
Outlitne Drawing
DFN1006-3L Package Outline Dimensions
Symbol
A
A1
D
E
b
b1
e
e1
L
L1
L2
Dimensions In Millimeters
Min.
Max.
0.450
0.550
0.010
0.100
0.950
1.050
0.550
0.650
0.450REF.
0.100
0.200
0.635REF.
0.300
0.400
0.200
0.300
0.050REF.
0.300
0.200
Dimensions In Inches
Min.
Max.
0.018
0.022
0.000
0.004
0.037
0.041
0.022
0.026
0.018REF.
0.004
0.008
0.025REF.
0.012
0.016
0.008
0.012
0.002REF.
0.008
0.012
Suggested Pad Layout
0.700
Dimensions
C
G
X
X1
Y
Value (in mm)
0.90
0.40
0.50
1.10
0.50
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
DFN1006
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
10,000
210×210×205
100,000
445×445×230
400,000
7'
Rev:2021A1
Page :4
很抱歉,暂时无法提供与“ESD0302L”相匹配的价格&库存,您可以联系我们找货
