ESD0301L
Ultra Low Capacitance ESD Protection Diodes
DFN1006 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
ESD0301L is a low-capacitance Transient Voltage Suppressor (TVS) designed to provid electrostatic
discharge (ESD) protection For high-speed data interfaces. With typical capacitance of 0.4pF, ESD0301L
is designed to protect parasitic-sensitive systems against over-voltage and over-current transsient events.
It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4
(electrical fast transientt - EFT) (40A, 5/50 ns), very fast charged devicee model (CDM) ESD and cable
discharge event (CDE), etc. ESD0301L uses ultra-small DFN1006 package. Each ESD0301L device can
protect one high-speed data line. It offers system designers flexibility to protect single data line where
space is a premium concern. The combined features of low capacitance, ultra-small size and high ESD
robustness make ESD0301L ideal for high-speed data port and high-frequency line applications, such as
cellular phoones and HD visual devices.
Features
Peak Power Dissipation : 56W (8/20μs)
Transient protection for high speed data lines
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Cable Discharge Event (CDE)
Package optimized for hingh-speed lines
Protect one data, control line
Low clamping voltage
Low Capacitance :0.4pF(Typical)
Low leakage current
Applications
Pin Configuration
Serial ATA
Desktops, Servers and Notebooks
Cellular Phones
MDDI Ports
USB Data Line Protectioon
Display Ports
Digital Visual Interfacess (DVI)
Circuit Diagram
Mechanical Characteristics
Package: DFN1006
Flammability Rating: UL 94V-0
Packaging: Tape and Reel
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Marking: 3L
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
VESD
Value
± 20
± 20
Unit
kV
Peak Pulse Power(tp=8/20us waveform)
PPP
56
W
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature Range
TSTG
−55 to +150
°C
The above data are for reference only.
DN:T21827A1
http://www.microdiode.com
Rev:2021A1
Page :1
ESD0301L
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
bol
Param
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IR
Reverse Leakage Current
VC
Clamping Voltage
CJ
Junction Capacitance
Test Condition
IT = 1mA
Min
Typ
Max
Units
3.3
V
4.2
V
VRWM = 3.3V
100
nA
IPP = 1A, tp = 8/20μs
10
V
IPP = 4A, tp = 8/20μs
14
V
0.5
pF
VR = 0V, f = 1MHz
0.4
Rev:2021A1
Page :2
ESD0301L
ELECTRICAL CHARACTERISTICS CURVE
Rev:2021A1
Page :3
ESD0301L
Outlitne Drawing
DFN1006 Package Outline Dimensions
A
DFN1006
Min
Max
Typ
Dim
A
0.50
0.45
0.55
b
0.55
0.50
0.45
D
1.05
0.95
1.00
E
0.55
0.60
0.65
e
0.40
L
0.30
0.25
0.20
R
0.07
0.17
0.12
All Dimensions in mm
D
R
E
b
e
L
Suggested Pad Layout
X1
Dimensions
C
G
X
X1
Y
X
Y
Value (in mm)
0.90
0.40
0.50
1.10
0.50
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
G
C
PACKAGE SPECIFICATIONS
Package Reel Size
DFN1006
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
10,000
210×210×205
100,000
445×445×230
400,000
7'
Rev:2021A1
Page :4
很抱歉,暂时无法提供与“ESD0301L”相匹配的价格&库存,您可以联系我们找货
