ESD0302TL
Ultra Low Capacitance TVS/ESD Protection Diodes
SOT-23 Plastic-Encapsulate TVS/ESD Protection Diodes
DESCRIPTION
ESD0302TL is an ultra-low-capacitance Transient Voltage Suppressor (TVS) designed to provide
electrostatic discharge (ESD) protection For high-speed data interfaces. With typical capacitance of
0.2pF (I/O to I/O) only, ESD0302TL is designed to protect parasitic-sensitive systems against overvoltage and over-current transsient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air,
±8kV contact discharge), IEC 61000-4-4 (electrical fast transientt - EFT) (40A, 5/50 ns), very fast
charged devicee model (CDM) ESD and cable discharge event (CDE), etc.
ESD0302TL uses ultra-small SOT-23 package. Each ESD0302TL device can protect two high-speed
data lines. The combined features of low capacitance, small size and high ESD robustness make
ESD0302TL ideal for high-speed data port and high-frequency line applications, The low camping
voltage of the ESD0302TL guarantees a minimum stress on the protected IC.
Features
Pin Configuration
Peak Power Dissipation : 56W (8/20μs)
Transient protection for high speed data lines
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Cable Discharge Event (CDE)
Small package (2.9mm2.4mm1.0mm)
Protect two data lines
Low clamping voltage
Low Capacitance :0.2pF Typical (I/O - I/O)
Low leakage current
Applications
Circuit Diagram
Mechanical Characteristics
Serial ATA
Desktops, Servers and Notebooks
PCI Express
MDDI Ports
USB Data Line Protectioon
Display Ports
Digital Visual Interfacess (DVI)
Package: SOT-23
Flammability Rating: UL 94V-0
Terminal: Matte tin plated.
High temperature soldering guaranted:
260℃/10s
Marking: 32L
Packaging: Tape and Reel
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
PPP
56
W
VESD
± 20
± 20
KV
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
Peak Pulse Power(8/20us )
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
http://www.microdiode.com
The above data are for reference only.
Rev:2024A1
Page :1
ESD0302TL
Electrical Characteristics (TA=25°C unless otherwise specified)
6\PERO
3DUDPHWHU
7HVW&RQGLWLRQ
0LQ
7\S
0D[
8QLWV
95:0
5HYHUVH:RUNLQJ9ROWDJH
,2WR*1'
9
9%5
5HYHUVH%UHDNGRZQ
9ROWDJH
,7 P$
%HWZHHQ,2DQG*1'
9
,5
5HYHUVH/HDNDJH&XUUHQW
95:0 9
%HWZHHQ,2DQG*1'
Q$
,33 $WS ȝV
%HWZHHQ,2DQG*1'
9
,33 $WS ȝV
%HWZHHQ,2DQG*1'
9
,7 P$
%HWZHHQ,2DQG*1'
9
95 9I 0+]
%HWZHHQ,2DQG*1'
S)
95 9I 0+]
%HWZHHQ,2DQG,2
S)
9&
9)
&7
&ODPSLQJ9ROWDJH
)RUZDUG9ROWDJH
7RWDO&DSDFLWDQFH
Rev:2024A1
Page :2
ESD0302TL
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A1
Page :3
ESD0302TL
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.89
1.40
1.00
0.10
0.06
0.01
0.37
0.50
0.44
0.20
0.09
0.13
2.80
2.90
3.10
1.20
1.60
1.30
2.40
2.10
2.80
1.78
2.04
1.90
0.10
0.30
0.69
0.35
0.54
0°
10°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A1
Page :4
ESD0302TL
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A1
Page :5
很抱歉,暂时无法提供与“ESD0302TL”相匹配的价格&库存,您可以联系我们找货
