ESD0501OC
TVS/ESD Protection Diodes
DFN1006 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
ESD0501OC is a low-capacitance Transient Voltage Suppressor (TVS) designed to provid electrostatic
discharge (ESD) protection for data , control or power lines. With typical capacitance of 10pF only,
ESD0501OC is designed to protect parasitic-sensitive systems against over-voltage and over-current
transsient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge),
IEC 61000-4-4 (electrical fast transientt - EFT) (40A, 5/50 ns), very fast charged devicee model (CDM)
ESD and cable discharge event (CDE), etc. ESD0501OC uses ultra-small DFN1006 package. Each
ESD0501OC device can protect one data line. It offers system designers flexibility to protect single data
line where space is a premium concern.
Features
Transient protection for high speed data lines
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Cable Discharge Event (CDE)
Package optimized for hingh-speed lines Protects
one data,control or power line
Low Capacitance
Low leakage current
Low clamping voltage
Each I/O pin can withstand over 1000 ESD strikes
for ±8kV contact dischage
Applications
Portable Electronice
Desktops, Servers and Notebooks
Cellular Phones
MP3 Ports
Display Ports
Subscriber ldentity Module (SIM) card
Digital Visual Interfacess (DVI)
Pin Configuration
Circuit Diagram
Mechanical Characteristics
Package: DFN1006
Flammability Rating: UL 94V-0
Packaging: Tape and Reel
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Marking: FOC
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
VESD
Value
± 30
± 30
Unit
kV
Peak Pulse Power(tp=8/20us waveform)
PPP
150
W
Operating Temperature
TOPT
−40 to +125
°C
Storage Temperature Range
TSTG
−40 to +150
°C
260(10 sec.)
°C
Lead Solder Temperature – Maximum (10 Second
Duration)
TL
The above data are for reference only.
DN:T21827A1
http://www.microdiode.com
Rev:2021A1
Page :1
ESD0501OC
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
bol
Param
Test Condition
Min
Typ
Max
Units
5.0
V
7.8
V
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IT = 1mA
IR
Reverse Leakage Current
VRWM = 5V
1.0
uA
IPP = 5A, tp = 8/20μs
11.6
V
16
V
15
pF
VC
Clamping Voltage
CJ
Junction Capacitance
5.6
IPP = 9.4A, tp = 8/20μs
VR = 0V, f = 1MHz
10
Rev:2021A1
Page :2
ESD0501OC
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only. .
Rev:2021A1
Page :3
ESD0501OC
Outlitne Drawing
DFN1006 Package Outline Dimensions
A
DFN1006
Min
Max
Typ
Dim
A
0.50
0.45
0.55
b
0.55
0.50
0.45
D
1.05
0.95
1.00
E
0.55
0.60
0.65
e
0.40
L
0.30
0.25
0.20
R
0.07
0.17
0.12
All Dimensions in mm
D
R
E
b
e
L
Suggested Pad Layout
X1
Dimensions
C
G
X
X1
Y
X
Y
Value (in mm)
0.90
0.40
0.50
1.10
0.50
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
G
C
PACKAGE SPECIFICATIONS
Package Reel Size
DFN1006
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
10,000
210×210×205
100,000
445×445×230
400,000
7'
Rev:2021A1
Page :4
很抱歉,暂时无法提供与“ESD0501OC”相匹配的价格&库存,您可以联系我们找货
