ESD0502L
ESD0502L
    MDD(辰达半导体)
ESD0502L 数据手册
ESD0502L Ultra Low Capacitance TVS/ESD Protection Diodes DFN1006-3L Plastic-Encapsulate ESD Protection Diodes DESCRIPTION ESD0502L is an ultra-low-capacitance Transient Voltage Suppressor (TVS) designed to provide electrostatic discharge (ESD) protection For high-speed data interfaces. With typical capacitance of 0.2pF (I/O to I/O) only, ESD0502L is designed to protect parasitic-sensitive systems against over-voltage and over-current transsient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transientt - EFT) (40A, 5/50 ns), very fast charged devicee model (CDM) ESD and cable discharge event (CDE), etc. ESD0502L uses ultra-small DFN1006-3L package. Each ESD0502L device can protect two high-speed data lines. The combined features of low capacitance, small size and high ESD robustness make ESD0502L ideal for high-speed data port and high-frequency line applications, The low camping voltage of the ESD0502L guarantees a minimum stress on the protected IC. Features          Peak Power Dissipation : 60W (8/20μs) Transient protection for high speed data lines IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) Cable Discharge Event (CDE) Small package (1.0mm0.6mm0.5mm) Protect two data lines Low clamping voltage Low Capacitance :0.2pF Typical (I/O - I/O) Low leakage current Applications        Serial ATA Desktops, Servers and Notebooks PCI Express MDDI Ports USB Data Line Protectioon Display Ports Digital Visual Interfacess (DVI) Pin Configuration Circuit Diagram Mechanical Characteristics Package: DFN1006-3L Flammability Rating: UL 94V-0 Packaging: Tape and Reel Terminals: Gold plated, solderable per MIL-STD-750, method 2026  Marking: 52L     Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol VESD Value ± 20 ± 20 Unit kV Peak Pulse Power(tp=8/20us waveform) PPP 60 W Operating Temperature TOPT −55 to +125 °C Storage Temperature Range TSTG −55 to +150 °C The above data are for reference only. DN:T21827A1 http://www.microdiode.com Rev:2021A1 Page :1 ESD0502L Ultra Low Capacitance TVS/ESD Protection Diodes Electrical Characteristics (TA=25°C unless otherwise specified) 6\PERO 3DUDPHWHU  7HVW&RQGLWLRQ 95:0 5HYHUVH:RUNLQJ9ROWDJH ,2WR*1' 9%5 5HYHUVH%UHDNGRZQ 9ROWDJH ,7 P$ %HWZHHQ,2DQG*1' ,5 5HYHUVH/HDNDJH&XUUHQW 95:0 9 %HWZHHQ,2DQG*1'  Q$ ,33 $WS ȝV %HWZHHQ,2DQG*1'  9 ,33 $WS ȝV %HWZHHQ,2DQG*1'  9 ,7 P$ %HWZHHQ,2DQG*1'  9 9& 9) &7 0LQ 7\S 0D[ 8QLWV  9 9  &ODPSLQJ9ROWDJH )RUZDUG9ROWDJH 95 9I 0+] %HWZHHQ,2DQG*1'   S) 95 9I 0+] %HWZHHQ,2DQG,2   S) 7RWDO&DSDFLWDQFH The above data are for reference only. http://www.microdiode.com Rev:2021A1 Page :2 ESD0502L Ultra Low Capacitance TVS/ESD Protection Diodes ELECTRICAL CHARACTERISTICS CURVE The above data are for reference only. http://www.microdiode.com Rev:2021A1 Page :3 ESD0502L Ultra Low Capacitance TVS/ESD Protection Diodes Outlitne Drawing DFN1006-3L Package Outline Dimensions Symbol A A1 D E b b1 e e1 L L1 L2 Dimensions In Millimeters Min. Max. 0.450 0.550 0.010 0.100 0.950 1.050 0.550 0.650 0.450REF. 0.100 0.200 0.635REF. 0.300 0.400 0.200 0.300 0.050REF. 0.300 0.200 Dimensions In Inches Min. Max. 0.018 0.022 0.000 0.004 0.037 0.041 0.022 0.026 0.018REF. 0.004 0.008 0.025REF. 0.012 0.016 0.008 0.012 0.002REF. 0.008 0.012 Suggested Pad Layout 0.700 Dimensions C G X X1 Y Value (in mm) 0.90 0.40 0.50 1.10 0.50 Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size DFN1006 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 10,000 210×210×205 100,000 445×445×230 400,000 7' http://www.microdiode.com Rev:2021A1 Page :4
ESD0502L 价格&库存
很抱歉,暂时无法提供与“ESD0502L”相匹配的价格&库存,您可以联系我们找货
