ESD0502TL
ESD0502TL
    MDD(辰达半导体)
ESD0502TL 数据手册
ESD0502TL Ultra Low Capacitance TVS/ESD Protection Diodes SOT-23 Plastic-Encapsulate TVS/ESD Protection Diodes DESCRIPTION ESD0502TL is an ultra-low capacitance Transient Voltage Suppressor (TVS) designed to provide electrostatic discharge (ESD) protection for high-speed data interfaces. With typical capacitance of 0.2pF (I/O to I/O) only, ESD0502TL is designed to protect parasitic-sensitive systems against overvoltage and over-current transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device model (CDM) ESD and cable discharge event (CDE), etc. ESD0502TL uses small SOT-23 package. Each ESD0502TL device can protect two high-speed data lines. The combined features of low capacitance, small size and high ESD robustness make ESD0502TL ideal for high-speed data port and high-frequency line applications. The low clamping voltage of the ESD0502TL guarantees a minimum stress on the protected IC. Features          Pin Configuration Peak Power Dissipation : 60W (8/20μs) Transient protection for high speed data lines IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) Cable Discharge Event (CDE) Small package (2.9mm2.4mm1.0mm) Protect two data lines Low clamping voltage Low Capacitance :0.2pF Typical (I/O - I/O) Low leakage current Applications        Circuit Diagram Mechanical Characteristics Serial ATA Desktops, Servers and Notebooks PCI Express MDDI Ports USB Data Line Protectioon Display Ports Digital Visual Interfacess (DVI) Package: SOT-23 Flammability Rating: UL 94V-0 Terminal: Matte tin plated. High temperature soldering guaranted: 260℃/10s  Marking: 52L  Packaging: Tape and Reel     Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit PPP 60 W VESD ± 20 ± 20 KV Operating Temperature TOPT −55 to +125 °C Storage Temperature TSTG −55 to +150 °C TL 260(10 sec.) °C Peak Pulse Power(8/20us ) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Lead Solder Temperature – Maximum (10 Second Duration) http://www.microdiode.com The above data are for reference only. Rev:2024A1 Page :1 ESD0502TL Ultra Low Capacitance TVS/ESD Protection Diodes Electrical Characteristics (TA=25°C unless otherwise specified) 6\PERO 3DUDPHWHU  7HVW&RQGLWLRQ 95:0 5HYHUVH:RUNLQJ9ROWDJH ,2WR*1' 9%5 5HYHUVH%UHDNGRZQ 9ROWDJH ,7 P$ %HWZHHQ,2DQG*1' ,5 5HYHUVH/HDNDJH&XUUHQW 95:0 9 %HWZHHQ,2DQG*1'  Q$ ,33 $WS ȝV %HWZHHQ,2DQG*1'  9 ,33 $WS ȝV %HWZHHQ,2DQG*1'  9 ,7 P$ %HWZHHQ,2DQG*1'  9 9& 9) &7 0LQ 7\S 0D[ 8QLWV  9 9  &ODPSLQJ9ROWDJH )RUZDUG9ROWDJH 95 9I 0+] %HWZHHQ,2DQG*1'  S) 95 9I 0+] %HWZHHQ,2DQG,2  S) 7RWDO&DSDFLWDQFH The above data are for reference only. http://www.microdiode.com Rev:2024A1 Page :2 ESD0502TL Ultra Low Capacitance TVS/ESD Protection Diodes ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :3 ESD0502TL Ultra Low Capacitance TVS/ESD Protection Diodes Outlitne Drawing SOT-23 Package Outline Dimensions e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 1.40 0.89 1.00 0.10 0.06 0.01 0.50 0.37 0.44 0.20 0.09 0.13 3.10 2.80 2.90 1.60 1.20 1.30 2.40 2.80 2.10 1.78 2.04 1.90 0.10 0.30 0.69 0.35 0.54 0° 10° Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 http://www.microdiode.com inches mm Rev:2024A1 Page :4 ESD0502TL Ultra Low Capacitance TVS/ESD Protection Diodes SOT-23 Tape and Reel SOT-23 Embossed Carrler Tape Packaging Description: SOT-23 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 3,000 units per 7" or 17.8cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). SOT-23 Tape Leader and Trailer SOT-23 Reel 3000 pcs http://www.microdiode.com 7 Inch 45,000 pcs 203×203×195 180,000 pcs 438×438×220 Rev:2024A1 Page :5
ESD0502TL 价格&库存
很抱歉,暂时无法提供与“ESD0502TL”相匹配的价格&库存,您可以联系我们找货
