ESD3B3CM
Low Capacitance Bidirectional
TVS/ESD Protection Diode
SOD-323 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The ESD3B3CM is designed to protect voltage sensitive components from ESD and transient voltage
events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for
ESD protection on designs where board space is at a premium. Because of its small size, it is suited
for use in cellular phones, portable devices, digital cameras, power supplies and many other portable
applications where board space comes at a premium. Also because of its low capacitance, it is suited
for use in high frequency designs such as high speed line applications.
This device has been specifically designed to protect sensitive components which are connected to
data and transmission lines from overvoltage caused by ESD (electrostatic discharge), and EFT
(electrical fast transients).
Features
Pin Configuration
Peak power dissipation: 500W (8/20μs)
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Protects one Vcc or data line
Low clamping voltage
Low leakage current
Low capacitance
Working voltages : 3.3V
Meets MSL 1 Requirements
Applications
Cell Phone Handsets and Accessories
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Networking and Telecom
Serial and Parallel Ports
Peripherals
Circuit Diagram
1
2
Mechanical Characteristics
Package: SOD-323
Flammability Rating: UL 94V-0
High temperature soldering guaranteed:
260℃/10s
Packaging: Tape and Reel
Marking: 2A
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 30
± 30
KV
Peak Pulse Power(8/20us )
PPP
500
W
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
The above data are for reference only.
http://www.microdiode.com
Rev:2024A1
Page :1
ESD3B3CM
Electrical Characteristics (TA=25°C unless otherwise specified)
Test Condition
Symbol
Parameter
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IR
Reverse Leakage Current
VC
Clamping Voltage
IPP = 1A, tp = 8/20μs
VC
Clamping Voltage
IPP = 28A, tp = 8/20μs
CJ
Junction Capacitance
VR = 0V, f = 1MHz
IT = 1mA
Min
Typ
Max
Units
3.3
V
6.0
V
1.0
μA
6.5
V
13
18
V
30
45
pF
4.0
VRWM = 3.3V
Rev:2024A1
Page :2
ESD3B3CM
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A1
Page :3
ESD3B3CM
Outlitne Drawing
SOD-323 Package Outline Dimensions
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-323
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“ESD3B3CM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18706
- 200+0.14688
- 600+0.12453
- 3000+0.10574
- 9000+0.09418
- 21000+0.08792
