ESD3Z5V0BU
Ultra Low Capacitance ESD Protection Diode
DESCRIPTION
SOD-323 Plastic-Encapsulate ESD Protection Diodes
ESD3Z5V0BU is an ultra low-capacitance Transient Voltage Suppressor (TVS) designed to provide
electrostatic discharge (ESD) protection for high-speed data interfaces. With typical capacitance of
0.25pF, ESD3Z5V0BU is designed to protect parasitic-sensitive systems against over-voltage and overcurrent transient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact
discharge), IEC 61000-4-4 (electrical fast transient - EFT) (40A, 5/50 ns), very fast charged device
model (CDM) ESD and cable discharge event (CDE), etc.
ESD3Z5V0BU uses ultra-small SOD-323 package. Each ESD3Z5V0BU device can protect one highspeed data line. It offers system designers flexibility to protect single data line where space is a premium
concern. The combined features of low capacitance, ultra-small size and high ESD robustness make
ESD3Z5V0BU ideal for high-speed data port and high-frequency line applications, such as cellular
phones and HD visual devices.
Features
Peak power dissipation: 100W (8/20μs)
Transient protection for high-speed data lines
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Cable Discharge Event (CDE)
Ultra-small package
Protects one data, control line
Low capacitance: 0.25pF (Typical)
Low clamping voltage
Low leakage current
Meets MSL 1 Requirements
Applications
10/100M Ethernet Ports
WAN/LAN Equipment
Desktops, Servers and Notebooks
Cellular Phones
Switching Systems
Audio/Video Inputs
Pin Configuration
Circuit Diagram
Mechanical Characteristics
Package: SOD-323
Flammability Rating: UL 94V-0
High temperature soldering guaranteed:
260℃/ 10s
Packaging: Tape and Reel
Marking: 5BU
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
VESD
Value
± 20
± 20
Unit
KV
Peak Pulse Power(8/20us )
PPP
100
W
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
Lead Solder Temperature – Maximum (10 Second
Duration)
The above data are for reference only.
http://www.microdiode.com
Rev:2024A1
Page :1
ESD3Z5V0BU
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Parameter
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IR
Reverse Leakage Current
VC
Clamping Voltage
VC
CJ
Test Condition
IT = 1mA
Min
Typ
Max
Units
5.0
V
6.0
V
100
nA
IPP = 1A, tp = 8/20μs
13
V
Clamping Voltage
IPP = 4A, tp = 8/20μs
25
V
Junction Capacitance
VR = 0V, f = 1MHz
0.40
pF
VRWM = 5.0V
0.25
Rev:2024A1
Page :2
ESD3Z5V0BU
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A1
Page :3
ESD3Z5V0BU
Outlitne Drawing
SOD-323 Package Outline Dimensions
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-323
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“ESD3Z5V0BU”相匹配的价格&库存,您可以联系我们找货
