ESD5B3CM
Low Capacitance Bidirectional
TVS/ESD Protection Diode
SOD-523 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The ESD5B3CM is designed to protect voltage sensitive component from ESD and transient voltage
events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for
ESD protection on designs where board space is at a premium. Because of its small size, it is suited for
use in cellular phones, portable devices, digital cameras, power supplies and many other portable
applications where board space comes at a premium. Also because of its low capacitance, it is suited
for use in high frequency designs such as high speed line application.
This device has been specifically designed to protect sensitive components which are connected to data
and transmission lines from overvoltage caused by ESD (electrostatic discharge), and EFT (electrical
fast transients).
Features
Pin Configuration
Peak power dissipation: 400W (8/20μs)
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Protects one directional I/O line
Low clamping voltage
Low leakage current
Low capacitance
Working voltages : 3.3V
Meets MSL 3 Requirements
Applications
High Speed Line
Serial and Parallel Ports
Notebooks, Desktops, Servers
Projection TV
Cellular handsets and accessories
Portable instrumentation
Peripherals
Circuit Diagram
1
2
Mechanical Characteristics
Package: SOD-523
Flammability Rating: UL 94V-0
High temperature soldering guaranteed:
260℃/ 10s
Packaging: Tape and Reel
Weight: 0.001 gram (approx.)
Marking: 3CM
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
VESD
Value
± 30
± 30
Unit
KV
Peak Pulse Power(8/20us )
PPP
400
W
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
Lead Solder Temperature – Maximum (10 Second
Duration)
TL
260(10 sec.)
°C
The above data are for reference only.
http://www.microdiode.com
Rev:2024A2
Page :1
ESD5B3CM
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Parameter
Test Condition
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IR
Reverse Leakage Current
VC
Clamping Voltage
IPP = 1A, tp = 8/20μs
VC
Clamping Voltage
IPP = 23A, tp = 8/20μs
CJ
Junction Capacitance
VR = 0V, f = 1MHz
IT = 1mA
Min
Typ
Max
Units
3.3
V
6.0
V
1.0
μA
6.5
V
13
18
V
38
45
pF
4.0
VRWM = 3.3V
Rev:2024A2
Page :2
ESD5B3CM
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A2
Page :3
ESD5B3CM
Outlitne Drawing
SOD-523 Package Outline Dimensions
6\PERO
A
A1
b
c
D
E
E1
E2
L
Κ
'LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
'LPHQVLRQV,Q,QFKHV
0D[
0LQ
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-523
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2024A2
Page :4
很抱歉,暂时无法提供与“ESD5B3CM”相匹配的价格&库存,您可以联系我们找货
