ESD5B5CU
Low Capacitance Bidirectional
TVS/ESD Protection Diode
SOD-523 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The ESD5B5CU is designed to protect voltage sensitive components from ESD and transient voltage
events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for
ESD protection on designs where board space is at a premium. Because of its small size, it is suited
for use in cellular phones, portable devices, digital cameras, power supplies and many other portable
applications where board space comes at a premium. Also because of its low capacitance, it is suited
for use in high frequency designs such as USB 2.0 high speed, VGA, DVI, SDI and other high speed
line applications.
This device has been specifically designed to protect sensitive components which are connected to
data and transmission lines from overvoltage caused by ESD(electrostatic discharge), and EFT
(electrical fast transients).
Features
Peak power dissipation: 35W (8/20μs)
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Protects one directional I/O line
Low clamping voltage
Low leakage current
Low capacitance
Working voltages : 5.0V
Meets MSL 1 Requirements
Applications
Pin Configuration
High Speed Line:USB1.0/2.0,VGA,DVI,SDI
Serial and Parallel Ports
Notebooks, Desktops, Servers
Projection TV
Cellular handsets and accessories
Portable instrumentation
Peripherals
Circuit Diagram
1
2
Mechanical Characteristics
Package: SOD-523
Flammability Rating: UL 94V-0
High temperature soldering guaranteed:
260℃/ 10s
Packaging: Tape and Reel
Weight: 0.001 gram (approx.)
Marking: LB
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
VESD
Value
± 15
±8
Unit
KV
Peak Pulse Power(8/20us )
PPP
35
W
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
Lead Solder Temperature – Maximum (10 Second
Duration)
The above data are for reference only.
http://www.microdiode.com
TL
260(10 sec.)
Rev:2024A1
°C
Page :1
ESD5B5CU
Electrical Characteristics (TA=25°C unless otherwise specified)
Max
Units
5.0
V
9.4
V
VRWM = 5V
2.0
μA
IPP = 1A, tp = 8/20μs
10.5
V
IPP = 2A, tp = 8/20μs
14.0
V
3.5
pF
Symbol
Parameter
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IT = 1mA
IR
Reverse Leakage Current
VC
CJ
Clamping Voltage
Junction Capacitance
Test Condition
VR = 0V, f = 1MHz
Min
Typ
5.6
3.0
Rev:2024A1
Page :2
ESD5B5CU
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A1
Page :3
ESD5B5CU
Outlitne Drawing
SOD-523 Package Outline Dimensions
6\PERO
A
A1
b
c
D
E
E1
E2
L
Κ
'LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
'LPHQVLRQV,Q,QFKHV
0D[
0LQ
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-523
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“ESD5B5CU”相匹配的价格&库存,您可以联系我们找货
