ESD8Dxxx Series
ESD Protection Diodes
DFN1006 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The ESD8Dxxx Series is designed to protect voltage sensitive components from ESD and transient
voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts
ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is
suited for use in cellular phones, portable devices, digital cameras, power supplies and many other
portable applications.
Features
Peak Power Dissipation : 150mW (8/20μs)
Transient protection for high speed data lines
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
Protects one directional I/O line
Low clamping voltage
Working voltages : 3.3V,5V, 8V, 12V,15V
Low leakage current
Pin Configuration
Applications
Cell Phone Handsets and Accessories
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Peripherals
Pagers
Circuit Diagram
Mechanical Characteristics
Package: DFN1006
Flammability Rating: UL 94V-0
Packaging: Tape and Reel
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Marking: see Page.2
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Units
VESD
± 30
± 22
KV
Total Power Dissipation on FR-5 Board (Note 1) @ Ta=25C
PD
150
mW
Operating Temperature
TOPT
−55 to +125
°C
Storage Temperature
TSTG
−55 to +150
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
These ratings are limiting values above which the serviceability of the diode may be impaired
Note 1. FR-5=1.0x0.75x0.62 in.
DN:T21826A1
http://www.microdiode.com
Rev:2021A1
Page :1
ESD8Dxxx Series
Electrical Characteristics (TA=25°C unless otherwise specified)
Part
Number
Device
Marking
VRWM
(V)
Max.
IR
(µA)
Max.
VB
(V)
Min.
IT
(Ma)
VC
(V)
Max. @A
VC
(V)
Max. @A)
PPK
(W)
Max.
CJ
(Pf)
Max.
ESD8D3V3
YA
3.3
2.5
5.0
1
10.0
5.0
11.5
7.5
105
105
ESD8D5V0
YB
5.0
1
6.2
1
11.6
5.0
15.0
7.0
105
80
ESD8D8V0
YC
8.0
1
8.5
1
15.0
5.0
18.0
6.0
108
65
ESD8D12V
YD
12.0
1
13.3
1
20.0
1.0
26.0
4.0
104
45
ESD8D15V
YE
15.0
1
16.0
1
23.0
1.0
30.0
4.0
120
28
The above data are for reference only.
Rev:2021A1
Page :2
ESD8Dxxx Series
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2020A0
Page :3
ESD8Dxxx Series
Outlitne Drawing
DFN1006 Package Outline Dimensions
A
DFN1006
Min
Max
Typ
Dim
A
0.50
0.45
0.55
b
0.55
0.50
0.45
D
1.05
0.95
1.00
E
0.55
0.60
0.65
e
0.40
L
0.30
0.25
0.20
R
0.07
0.17
0.12
All Dimensions in mm
D
R
E
b
e
L
Suggested Pad Layout
X1
Dimensions
C
G
X
X1
Y
X
Y
Value (in mm)
0.90
0.40
0.50
1.10
0.50
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
G
C
PACKAGE SPECIFICATIONS
Package Reel Size
DFN1006
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
10,000
210×210×205
100,000
445×445×230
400,000
7'
Rev:2021A1
Page :4
很抱歉,暂时无法提供与“ESD8D12V”相匹配的价格&库存,您可以联系我们找货
