ESD8D3V3
ESD8D3V3
    MDD(辰达半导体)
ESD8D3V3 数据手册
ESD8Dxxx Series ESD Protection Diodes DFN1006 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION The ESD8Dxxx Series is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, portable devices, digital cameras, power supplies and many other portable applications. Features Peak Power Dissipation : 150mW (8/20μs) Transient protection for high speed data lines IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) Protects one directional I/O line  Low clamping voltage  Working voltages : 3.3V,5V, 8V, 12V,15V  Low leakage current Pin Configuration     Applications        Cell Phone Handsets and Accessories Microprocessor based equipment Personal Digital Assistants (PDA’s) Notebooks, Desktops, and Servers Portable Instrumentation Peripherals Pagers Circuit Diagram Mechanical Characteristics Package: DFN1006 Flammability Rating: UL 94V-0 Packaging: Tape and Reel Terminals: Gold plated, solderable per MIL-STD-750, method 2026  Marking: see Page.2     Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Units VESD ± 30 ± 22 KV Total Power Dissipation on FR-5 Board (Note 1) @ Ta=25C PD 150 mW Operating Temperature TOPT −55 to +125 °C Storage Temperature TSTG −55 to +150 °C ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) These ratings are limiting values above which the serviceability of the diode may be impaired Note 1. FR-5=1.0x0.75x0.62 in. DN:T21826A1 http://www.microdiode.com Rev:2021A1 Page :1 ESD8Dxxx Series ESD Protection Diodes Electrical Characteristics (TA=25°C unless otherwise specified) Part Number Device Marking VRWM (V) Max. IR (µA) Max. VB (V) Min. IT (Ma) VC (V) Max. @A VC (V) Max. @A) PPK (W) Max. CJ (Pf) Max. ESD8D3V3 YA 3.3 2.5 5.0 1 10.0 5.0 11.5 7.5 105 105 ESD8D5V0 YB 5.0 1 6.2 1 11.6 5.0 15.0 7.0 105 80 ESD8D8V0 YC 8.0 1 8.5 1 15.0 5.0 18.0 6.0 108 65 ESD8D12V YD 12.0 1 13.3 1 20.0 1.0 26.0 4.0 104 45 ESD8D15V YE 15.0 1 16.0 1 23.0 1.0 30.0 4.0 120 28 The above data are for reference only. http://www.microdiode.com Rev:2021A1 Page :2 ESD8Dxxx Series ESD Protection Diodes ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :3 ESD8Dxxx Series ESD Protection Diodes Outlitne Drawing DFN1006 Package Outline Dimensions A DFN1006 Min Max Typ Dim A 0.50 0.45 0.55 b 0.55 0.50 0.45 D 1.05 0.95 1.00 E 0.55 0.60 0.65 e 0.40 L 0.30 0.25 0.20 R 0.07 0.17 0.12 All Dimensions in mm D R E b e L Suggested Pad Layout X1 Dimensions C G X X1 Y X Y Value (in mm) 0.90 0.40 0.50 1.10 0.50 Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. G C PACKAGE SPECIFICATIONS Package Reel Size DFN1006 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 10,000 210×210×205 100,000 445×445×230 400,000 7' http://www.microdiode.com Rev:2021A1 Page :4
ESD8D3V3 价格&库存
很抱歉,暂时无法提供与“ESD8D3V3”相匹配的价格&库存,您可以联系我们找货
