KBJ10005 THRU KBJ1010
Reverse Voltage - 50 to 1000 Volts Forward Current - 10.0 Amperes
GLASS PASSIVATED BRIDGE RECTIFIERS
Features
KBJ
Surge overload rating -210 amperes peak
Ideal for printed circuit board
? .134(3.4)
? .122(3.1)
.043(1.1)
.035(0.9)
? .134(3.4)
? .122(3.1)
.382(9.7)
.366(9.3)
.602(15.3)
.578(14.7)
.150(3.8)
.130(3.3)
Case : JEDEC KBJ Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
.074(1.9)
.059(1.5)
Mechanical Data
.057(1.45)
.041(1.05)
.083(2.1)
.069(1.7)
.189(4.8)
.173(4.4)
.150(3.8)
.134(3.4)
.114(2.9)
.098(2.5)
.708(18.0)
.669(17.0)
.118(3.0)*45°
.157
(4.0)
Reliable low cost construction utilizing molded plastic technique
Plastic material has U/L lammability classification 94V-0
.995(25.3)
.983(24.7)
.031(0.8)
.023(0.6)
.303(7.7) .303(7.7) .303(7.7)
SPACING
.287(7.3) .287(7.3) .287(7.3)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward(with heatsink NOTE 2)
Rectified current @T c =100°C(without heatsink)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Rating for Fusing(t
很抱歉,暂时无法提供与“KBJ1010”相匹配的价格&库存,您可以联系我们找货
