KBJ608
KBJ608
    MDD(辰达半导体)
    KBJ
    耐压:800V 电流:6A
KBJ608 数据手册
KBJ6005 THRU KBJ610 Reverse Voltage - 50 to 1000 Volts Forward Current - 6.0 Amperes GLASS PASSIVATED BRIDGE RECTIFIERS Features KBJ  Surge overload rating -170 amperes peak  Ideal for printed circuit board ? .134(3.4) ? .122(3.1) Case : JEDEC KBJ Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any - .043(1.1) .035(0.9) ? .134(3.4) ? .122(3.1) .382(9.7) .366(9.3) .602(15.3) .578(14.7) ~ .150(3.8) .130(3.3) Mechanical Data + ~ .074(1.9) .059(1.5) .057(1.45) .041(1.05) .083(2.1) .069(1.7) .189(4.8) .173(4.4) .150(3.8) .134(3.4) .114(2.9) .098(2.5) .708(18.0) .669(17.0) .118(3.0)*45° .157 (4.0)  Reliable low cost construction utilizing molded plastic technique  Plastic material has U/L lammability classification 94V-0 .995(25.3) .983(24.7) .031(0.8) .023(0.6) .303(7.7) .303(7.7) .303(7.7) SPACING .287(7.3) .287(7.3) .287(7.3) Maximum Ratings And Electrical Characteristics Dimensions in inches and (millimeters) Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward(with heatsink NOTE 2) Rectified current @T c =100°C(without heatsink) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Rating for Fusing(t
KBJ608 价格&库存
很抱歉,暂时无法提供与“KBJ608”相匹配的价格&库存,您可以联系我们找货
KBJ608
  • 5+2.71599
  • 50+2.22178
  • 300+1.96074
  • 600+1.69647
  • 2400+1.57875
  • 5100+1.50812
库存:284
KBJ608
  • 10+2.56540
  • 100+1.87060
  • 300+1.63260
  • 3000+1.27360
库存:290
