KBL6005 THRU KBL612
Reverse Voltage - 50 to 1200 V olts
Forward Current - 6.0 Amperes
SILICON BRIDGE RECTIFIERS
Features
KBL
The plastic package carries Underwriters Laboratory
0.768(19.5)
Flammability Classification 94V-0
0.728(18.5)
Ideal for printed circuit boards
Low reverse leakage
High forward surge current capability
0.580(14.7)
0.640(16.3)
0.594(15.1)
0.540(13.7)
High temperature soldering guaranteed:
260°C/10 seconds,0.375”(9.5mm) lead length, 5
lbs. (2.3kg) tension
AC
0.670
0.052(1.3)
(17.0)
0.046(1.18)
Mechanical Data
MIN.
0.083
Case : JEDEC KBL Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.20ounce , 5.6 grams
0.220(5.6)
(2.1)
0.180(4.6)
0.256(6.5)
0.217(5.5)
Maximum Ratings And Electrical Characteristics
Dimensions in inches and (millimeters)
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
output rectified current at
TA=50°C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
MDD
MDD
MDD
MDD
SYMBOLS
KBL6005
KBL601
KBL602
KBL604
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
400
280
400
MDD
MDD
MDD
MDD
UNITS
600
420
600
800
560
800
1000
700
1000
1200
840
1200
V
V
V
KBL606 KBL608 KBL610 KBL612
I(AV)
6.0
A
IFSM
200
A
Rating for fusing ( t
很抱歉,暂时无法提供与“KBL610”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.10000
- 50+0.85030
- 500+0.78320
