KBPC6005 THRU KBPC610
Reverse Voltage - 50 to 1000 Volts Forward Current - 6.0 Amperes
SILICON BRIDGE RECTIFIERS
Features
KBPC-6/BR-6
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Ideal for printed circuit boards
0.620(15.7)
0.580(14.7)
0.270(6.9)
0.230(5.8)
HOLE FOR
NO.6 SCREW
0.445(11.3)
0.405(10.3)
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
0.75
(19.1)
0.042(1.1) DIA.
0.039(1.0) TYP.
AC
MIN.
0.445(11.3)
0.405(10.3)
AC
260°C/10 seconds,5 lbs. (2.3kg) tension
Mechanical Data
Case : JEDEC BR-6 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.13 ounce, 3.66 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
TA=50°C(Note 1)
Maximum average forward
output rectified current at
TA=25°C(Note 2)
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Rating for Fusing(t
很抱歉,暂时无法提供与“KBPC608”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.34522
- 50+1.85210
- 200+1.59160
- 400+1.32786
- 2400+1.21047
- 5000+1.13994
- 国内价格
- 50+1.20571
- 1000+1.16842
- 国内价格
- 10+4.36640
- 40+2.60480
- 120+1.82330
- 200+1.30240
- 400+1.23730
- 2000+1.14610
