M1 THRU M7
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
0.110(2.80)
0.094(2.30)
0.067 (1.70)
0.051 (1.30)
Glass passivated Junction chip
Low reverse leakage
High forward surge current capability
0.181(4.50)
0.157(3.99)
High temperature soldering guaranteed
0.012(0.305)
0.006(0.152)
250 C/10 seconds at terminals
0.096(2.42)
0.078(1.98)
Mechanical Data
0.059(1.50)
0.035(0.90)
0.008(0.203)MAX.
0.205(5.20)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0019ounce, 0.055 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
MDD
M1
MDD
M2
MDD
M3
MDD
M4
MDD
M5
MDD
M6
MDD
M7
UNITS
50
35
50
100
70
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
100
Maximum average forward rectified current
I(AV)
1
A
Peak forward surge current 8.3ms single
half sine-wave superimposed onrated load
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
1.1
V
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
IR
5
50
15
CJ
RθJA
75
TJ,TSTG
-55 to +150
uA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0x2.0”(2.54x2.54cm) copper pad areas
http://www.microdiode.com
Rev:2024A3
Page :1
M1 THRU M7
Ratings And Characteristic Curves
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
1.2
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current (μA)
100
TJ=150°C
10
TJ=125°C
TJ=100°C
1.0
TJ=75°C
0.1
TJ=25°C
0.01
Junction Capacitance (pF)
25°
TJ=
0.8
0.9
J
T=
10
C
0°C
C
5°
12
TJ=
Instaneous Forward Current (A)
0.5
0.2
0.6
0.7
1.0
TJ=25°C
10
1
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
35
100
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1
Number of Cycles
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
800
100
1.0
00
600
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.1
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A3
Page :2
M1 THRU M7
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL S IZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
SMA
7"
2,000
4.0
4,000
183*155*183
178
382*356*392
80,000
16.0
SMA
11"
5,000
4.0
10,000
290*290*38
330
310*310*360
80,000
11.0
SMA
13"
7,5 00
4.0
15,000
335*335*38
330
350*330*360
120,000
14.5
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.066
B
1.68
1.52
C
3.90
0.154
D
2.41
0.095
E
5.45
0.215
0.060
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“M2”相匹配的价格&库存,您可以联系我们找货
