MBRF1045CT THRU MBRF10200CT
Reverse Voltage - 45 to 200 Volts
Forward Current - 10.0 Amper
SCHOTTKY BARRIER RECTIFIER
Features
ITO-220AB
High surge capacity.
For use in low voltage, high frequency inverters,free
wheeling,and polarity protection applications.
Metal silicon junction,majority carrier conduction.
High current capability,low forward voltage drop.
Guard ring for over voltage protection.
PIN1
PIN2
Mechanical Data
Case : JEDEC TO-220AB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.060 ounce, 1.67 grams
PIN3
PIN1
PIN2
PIN3
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
rectified current (see fig.1)
Peak forward surge current 8.3ms single half
sine-wave superimposed on rated load
(JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
VRRM
V RMS
V DC
MDD
MBRF
1045CT
MDD
MBRF
1060CT
MDD
MBRF
10100CT
MDD
MBRF
10150CT
MDD
MBRF
10200CT
UNITS
45
32
60
42
100
70
45
60
100
150
135
150
200
140
200
V
V
V
A
10.0
I(AV)
150
IFSM
VF
0.60
IR
15.0
0.85
0.75
1.0
50.0
125
A
0.95
0.1
15.0
1.5
V
mA
Typical thermal resistance (NOTE 2)
R θ JC
Operating junction temperature range
TJ
-55 to +150
T STG
-55 to +150
storage temperature range
2.0
℃/W
Note:2.Thermal resistance from junction to case.
http://www.microdiode.com
Rev:2024A2
Page :1
Forward Current - 10.0 Ampere
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
8.0
6.0
~2
00
V
4.0
2.0
0.0
60
80
100 120 140 160 180
Instaneous Reverse Current ( mA)
10
45
Average Forward Current (A)
Fig.1 Typical Forward Current Derating Curve
100
45~60V
100~200V
10
T J =100°C
1.0
0.1
T J =25°C
0.01
0.001
Case Temperature (°C)
T J =25°C
10
1
45V
60V
100V
150V
200V
0.1
0.6
0.9
1.2
40
60
80
100
1.5
Instaneous Forward Voltage (V)
Fig.4 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic(per leg)
Percent of Rated Peak Reverse Voltage(%)
1.8
160
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
The curve above is for reference only.
Rev:2024A2
Page :2
Outlitne
ITO-220AB Package Outline Dimensions
A
C
E
B
M
N
D
J
L
b
F
L1
b1
H
G
UNIT
max
mm
mil
G
A
B
b
b1
C
D
E
F
10.5
2.85
1.4
0.8
4.7
16.0
2.9
2.8
typ
10.0
2.70
1.2
0.6
4.5
15.0
2.7
2.7
min
9.85
2.54
1.1
0.5
4.4
14.7
2.5
2.5
max
413
112
55
31
185
630
114
110
typ
394
106
47
24
177
590
106
106
min
388
100
43
580
98
98
G
2.54
TYPICAL
100
TYPICAL
H
L
L1
M
0.70
2.9
14.3
7.0
0.55
2.5
13.5
6.8
0.41
2.3
13.0
6.3
27
114
563
276
22
98
531
267
16
91
512
248
Rev:2024A2
N
3.4
TYPICAL
133
TYPICAL
Page :3
很抱歉,暂时无法提供与“MBRF10150CT”相匹配的价格&库存,您可以联系我们找货
