MBRF2045CT THRU MBRF20200CT
Reverse Voltage - 45 to 200 Volts
Forward Current - 20.0 Ampere
SCHOTTKY BARRIER RECTIFIER
Features
ITO-220AB
The plastic package carries Underwriters
Laboratory Flammability Classification 94V-0
Construction utilizes void-free
molded plastic technique
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
250°C,0.25”(6.35mm) from case for 10 seconds
PIN1
PIN2
Mechanical Data
Case : JEDEC ITO-220AB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.080 ounce, 2.24 grams
PIN3
PIN1
PIN2
PIN3
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
rectified current (see fig.1)
Peak forward surge current 8.3ms single half
sine-wave superimposed on rated load
(JEDEC Method)
Maximum instantaneous forward voltage at 10.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
VRRM
V RMS
V DC
MDD
MBRF
2060CT
MDD
MBRF
20100CT
MDD
MBRF
20150CT
100
70
150
135
150
60
45
32
42
60
45
100
I(AV)
IFSM
VF
IR
Typical thermal resistance (NOTE 2)
R θ JC
Operating junction temperature range
TJ
storage temperature range
MDD
MBRF
2045CT
T STG
0.65
0.75
V
V
V
A
150
A
0.85
0.95
0.2
50.0
1.5
50.0
2.0
200
140
200
UNITS
20.0
1.0
15.0
MDD
MBRF
20200CT
V
mA
℃/W
-55 to +150
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to case.
http://www.microdiode.com
Rev:2025A4
Page :1
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
~2
10
00
V
5
0.0
60
80
100 120 140 160 180
Instaneous Reverse Current ( mA)
25
45
Average Forward Current (A)
Fig.1 Typical Forward Current Derating Curve
100
45~60V
100~200V
10
T J =100°C
1.0
0.1
T J =25°C
0.01
0.001
Case Temperature (°C)
1
45V
60V
100V
150V
200V
0.4
0.6
0.8
60
80
100
1.0
Instaneous Forward Voltage (V)
Fig.4 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
T J =25°C
10
0.1
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic(per leg)
160
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
100
Number of Cycles at 60Hz
The curve above is for reference only.
Rev:2025A4
Page :2
Outlitne
ITO-220AB Package Outline Dimensions
C
A
E
B
M
N
D
b
F
L
L1
b1
H
G
UNIT
mm
G
A
B
b
b1
C
D
E
F
G
H
L
L1
M
N
max
10.66
3.5
1.5
1.0
4.9
16.37
2.9
3.55
2.75
0.70
4.0
14.3
7.2
3.5
min
9.6
2.54
1.1
0.5
4.3
14.7
2.34
2.56
2.34
0.30
2.3
12.0
6.2
3.0
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“MBRF2045CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.98191
- 10+1.63253
- 50+1.48284
- 100+1.29600
- 500+1.21284
- 1000+1.16295
