MMBTA92
SOT-23 Plastic-Encapsulate Transistor
MMBTA92 TRANSISTOR (PNP)
SOT-23
FEATURES
High voltage transistor
Marking: 2D
(3)C
1. BASE
2D
2. EMITTER
3. COLLECTOR
(1)B
(2)E
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-300
V
VCEO
Collector-Emitter Voltage
-300
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current –Continuous
-0.3
A
PC*
Collector Power Dissipation
300
mW
RӨJA
Thermal Resistance, junction to Ambient
410
℃/mW
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Symbol
Parameter
Test
conditions
MIN
MAX
UNIT
Collector-base breakdown voltage
V(BR)CBO
IC= -100μA, IE=0
-300
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= -1mA, IB=0
-300
V
Emitter-base breakdown voltage
V(BR)EBO
IE= -100μA, IC=0
V
Collector cut-off current
ICBO
VCB=-200V, IE=0
-0.25
μA
Emitter cut-off current
IEBO
VEB= -5V, IC=0
-0.1
μA
hFE(1)
VCE= -10V, IC= -1mA
60
hFE(2)
VCE= -10V, IC=-10mA
10mA
100
hFE(3)
VCE=-10V, IC=-30mA
0m
60
Collector-emitter saturation voltage
VCE(sat)
IC=-20mA, IB= -2mA
-0.2
V
Base-emitter saturation voltage
VBE(sat)
IC= -20mA, IB=-2mA
-0.9
V
DC current gain
Transition frequency
fT
VCE= -20V, IC= -10mA,
f=30MHz
50
200
MHz
The above data are for reference only.
http://www.microdiode.com
Rev:2024A1
Page :1
MMBTA92
Typical Characteristics
The curve above is for reference only.
Rev:2024A1
Page :2
MMBTA92
Outlitne Drawing
SOT-23 Package Outline Dimensions
L
L1
E
E1
θ
1
e
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Suggested Pad Layout
0.037
0.95
0.037
0.95
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A1
Page :3
MMBTA92
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“MMBTA92”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.10285
- 10+0.09435
- 30+0.09265
- 国内价格
- 10+0.14170
- 100+0.11200
- 300+0.09558
- 3000+0.08565
- 6000+0.07712
- 9000+0.07247
