MMBZxxxAL Series
Common Anode Zeners for ESD Protection
SOT-23 Plastic-Encapsulate Anode Zeners for ESD Protection Diodes
DESCRIPTION
The dual monolithic silicon Zener diodes are designed for applications requiring transient overvoltage
protection capability. They are intended for use in voltage and ESD sensitive equipment such as
computers, printers, business machines, communication systems, medical equipment and other
applications. Their dual junction common anode design protects two separate lines using only one
package. These devices ideal for situations where board space is at a premium.
Features
SOT-23 package allows either two separate
unidirectional configurations or a single
bidirectional configuration.
Working peak reverse voltage 3V to 22V
Standard Zener breakdown voltage 5.6V to 27V
Peak power 24 or Watts @ 1.0ms (unidirectional)
per Figure 6 Waveform
ESD Rating:
Class 3B (>16kV) per the Human Body Model
Class C (>400V) per Machine Model
ESD Rating:
ESD Rating of IEC61000-4-2 level 4, ±30kV
contact Discharge
Low leakage < 5.0uA
Meets MSL 1 Requirements
Applications
Computers
Printers
Business Machines
Communication system
Medical equipment
http://www.microdiode.com
Schematic & Pin Configuration
3
1
2
SOT23 (Top View)
Circuit Diagram
Pin Description
1
cathode (diode 1)
2
cathode (diode 2)
3
common anode
Mechanical Characteristics
Package: SOT-23
Flammability Rating: UL 94V-0
Terminal: Matte tin plated.
High temperature soldering guaranted:
260℃/10s
Packaging: Tape and Reel
Quantity per reel: 3,000pcs
Rev:2024A3
Page :1
MMBZxxxAL Series
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
PPK
24
40
W
Peak Dissipation @1.0ms
MMBZ5V6AL thru MMBZ9V1AL
MMBZ12VAL thru MMBZ27VAL
Total Power Dissipation
PD
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
Lead Solder Temperature – Maximum (10 Second
Duration)
200
mW
Electrical Characteristics (TA=25°C unless otherwise specified)
24WATTS UNIDIRECTIONAL (Circuit tied to Pins 1 and 3 or Pins 2 to 3)
Part
Device
Number
Marking
VRWM
IR
(V)
(μA)
VRWM
MMBZ5V6AL
VBR
(V)
Min
Nom
Max
ZZT
(mA)
Max
IT
@IZT
ZZK
VC
(mA
Max
IZK
(V)
Max
(A)
IPP
5A6+code
3.0
5.0
5.32
5.6
5.88
1600
0.25
8.0
3.0
MMBZ6V2AL 6A2+code
3.0
0.5
5.89
6.2
6.51
1.0
8.7
2.76
MMBZ6V8AL 6A8+code
4.5
0.5
6.46
6.8
7.14
1.0
9.6
2.5
MMBZ9V1AL 9A1+code
6.0
0.3
8.65
9.1
9.56
1.0
14
1.7
VF=0.9V Max @ IF=10mA
40WATTS UNIDIRECTIONAL (Circuit tied to Pins 1 and 3 or Pins 2 to 3)
Part
Device
Number
Marking
VRWM
IR
(V)
(nA)
VRWM
VBR
VC (note1)
(V)
(mA)
Min
Nom
Max
IT
(V)
Max
(A)
IPP
MMBZ12VAL
12A+code
8.5
200
11.40
12
12.60
1
17
2.35
MMBZ15VAL
15A+code
12.0
50
14.25
15
15.75
1
21
1.90
MMBZ18VAL
18A+code
14.5
50
17.10
18
18.90
1
25
1.60
MMBZ27VAL
27A+code
22.0
50
25.65
27
28.35
1
40
1.0
Note: 1. Surge Current waveform per Figure 5
2.The above data are for reference only.
Rev:2024A2
Page :2
MMBZxxxAL Series
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A2
Page :3
MMBZxxxAL Series
Rev:2024A2
Page :4
MMBZxxxAL Series
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
1.40
0.89
1.00
0.10
0.06
0.01
0.50
0.37
0.44
0.20
0.09
0.13
2.80
2.90
3.10
1.60
1.20
1.30
2.40
2.10
2.80
1.78
2.04
1.90
0.10
0.30
0.69
0.35
0.54
0°
10°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A2
Page :5
MMBZxxxAL Series
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A2
Page :6
很抱歉,暂时无法提供与“MMBZ15VAL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.37390
- 100+0.22310
- 800+0.15620
- 3000+0.11150
- 6000+0.10600
- 30000+0.09820
