RABS21 THRU RABS210
Voltage Range - 100 to 1000 Volts
Current - 2.0 Ampere
GLASS PASSIVATED SURFACE MOUNT BRIDGE RECTIFIERS
Features
ABS
Glass Passivated Chip Junction
Reverse Voltage - 100 to 1000 V
Forward Current- 2.0 A
Fast reverse recovery time
Designed for Surface Mount Application
Mechanical Data
(1)
(2)
Case: JEDEC ABS molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body Mounting
Position: Any
Weight : 0.0031 ounce, 0.088 grams
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Symbols
Marking Code
MDD
RABS21
MDD
RABS22
MDD
RABS24
MDD
RABS26
MDD
RABS28
MDD
Units
RABS210
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Average Rectified Output Current
at T c = 115 °C
IO
2.0
A
I FSM
50
A
VF
1.3
V
IR
5.0
200
μA
Typical Junction Capacitance (Note 1)
Cj
40
pF
Typical Thermal Resistance(Note2)
RθJA
50
°C/W
t rr
500
ns
T j , T stg
-55 ~ +150
°C
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Maximum Forward Voltage at 2.0 A
Maximum DC Reverse Current
@ T a =25 °C
at Rated DC Blocking Voltage
@ T a =125 °C
Maximum Reverse Recovery Time (Note3)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with4×1.5"×1.5"(3.81×3.81 cm)copper pad areas.
3. Measured with I = 0.5 A, I = 1 A, Irr = 0.25 A .
http://www.microdiode.com
Rev:2024A1
Page :1
RABS21 THRU RABS210
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
2.5
2.0
1.5
1.0
0.5
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
CaseTemperature (°C)
1.0
0.1
pulse with 300μs
1% duty cycle
Junction Capacitance (pF)
Instaneous Forward Current (A)
60
80
100
120
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
60
50
40
30
140
Fig.4 Typical Junction Capacitance
T J =25°C
0.01
0.0
40
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics
10
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A1
Page :2
RABS21 THRU RABS210
Suggested Pad Layout
Q1
P1
Dim
Min
P1
5.72
P2
4.00
Q1
1.00
Q2
0.90
Q2
P2
Dimensions in millimeters
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“RABS210”相匹配的价格&库存,您可以联系我们找货
