RS2A
RS2A
    MDD(辰达半导体)
    SMA(DO-214AC)
    耐压:50V 电流:2A 反向恢复时间:150NS
RS2A 数据手册
RS2A THRU RS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere SURFACE MOUNT FAST RECOVERY RECTIFIER Features DO-214AC/SMA  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Idea for printed circuit board  Open Junction chip  Low reverse leakage  High forward surge current capability 0.110(2.80) 0.094(2.40) 0.067 (1.70) 0.039 (1.00) 0.177(4.50) 0.157(3.99)  High temperature soldering guaranteed: 0.012(0.305) 0.006(0.152) 250℃/ 10 seconds at terminals  Glass passivated chip junction 0.096(2.42) 0.078(1.98) 0.059(1.50) 0.035(0.90) Mechanical Data 0.008(0.203)MAX. 0.205(5.20) 0.188(4.80) Case : JEDEC DO-214AC/SMA Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0019 ounce, 0.055grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=125℃ Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current at rated DC blocking voltage MDD RS2A MDD RS2B MDD RS2D MDD RS2G MDD RS2J MDD RS2K MDD RS2M UNITS VRRM 50 VRMS VDC 35 50 100 70 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V SYMBOLS Marking Code TA=25℃ TA=125℃ Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range 100 I(AV) 2.0 A IFSM 50 A VF 1.30 V IR 5.0 100 uA trr 250 150 CJ RθJA 22.0 RθJC 20.0 TJ,TSTG 65.0 -55 to +150 500 ns pF ℃/W ℃ Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com Rev:2024A3 Page :1 RS2A THRU RS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere Ratings And Characteristic Curves Fig.1 Forward Current Derating Curve Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 1.0 TJ=25°C 0.1 Case Temperature (°C) Junction Capacitance (pF) Instaneous Forward Current (A) TJ=25°C 0.1 pulse with 300μ s 1% duty cycle 0.0 0.5 1.0 1.5 20 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance 1.0 0.01 00 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Instaneous Forward Characteristics 10 TJ=125°C 10 2.0 2.5 Instaneous Forward Voltage (V) TJ=25°C 100 10 1 TJ=25°C f = 1.0MHz Vsig = 50mVp-p 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surge Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surge Current 60 50 40 30 20 10 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2 RS2A THRU RS2M Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SMA Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width A B C d D D1 D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 2.80 5.33 2.36 1.50 330.00 50.00 178.00 62.00 13.00 1.75 5.50 4.00 4.00 2.00 0.28 12.00 18.00 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMA REEL SIZE 7" APPROX. GROSS WEIGHT (kg) REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) 2,000 4.0 4,000 183*155*183 178 382*356*392 80,000 16.0 10,000 290*290*38 330 310*310*360 80,000 11.0 15,000 335*335*38 330 350*330*360 120,000 14.5 SMA 11" 5,000 4.0 SMA 13" 7,500 4.0 CARTON SIZE (m/m) CARTON (pcs) Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) Unit (inch) A 0.066 B 1.68 1.52 C 3.93 0.154 D 2.41 0.095 E 5.45 0.215 0.060 Rev:2024A3 Page :3
很抱歉,暂时无法提供与“RS2A”相匹配的价格&库存,您可以联系我们找货
