RS2AW THRU RS2MW
Reverse Voltage - 50 to 1000 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
SOD-123FL
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
0.075(1.90)
0.067(1.70)
0.031 (0.80)
0.043 (1.10)
0.114(2.90)
0.102(2.60)
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length,
0.051(1.30)
0.039(1.00)
5 lbs. (2.3kg) tension
0.010(0.25)
0.004(0.10)
0.035(0.90)
0.028(0.70)
Mechanical Data
0.154(3.90)
0.141(3.60)
Case: JEDEC 6OD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.007 ounce, 0.02 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
RS2AW RS2BW RS2DW RS2GW RS2JW RS2KW RS2MW
UNITS
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current at
TL(see fig.1)
VRRM
VRMS
VDC
2F1
2F2
2F3
2F4
2F5
2F6
2F7
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
2.0
A
Peak forward surge current 8.3ms single half
sine-wave
superimposed onrated load (JEDEC Method)
IFSM
50
A
Maximum instantaneous forward voltage at 2.0A
VF
V
Maximum DC reverse current
rated DCblocking voltage
IR
1.3
5
100
mA
40
pF
TA=25℃ at
TA=125℃
Typical junction capacitance (NOTE 1)
Maximum Reverse Recovery Time
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
Note:
CJ
trr
150
250
500
ns
℃/W
RθJC
75
22
TJ
-55 to +150
TSTG
-55 to +150
RJA
2.Measured with IF=0.5A, IR=1A, Irr=0.25A.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
4.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
RS2AW THRU RS2MW
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
3.0
100
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive or
inductive load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(uA)
Average Forward Current (A)
2.5
1.0
TJ=25°C
0.1
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics
10
TJ=125°C
10
Fig.4 Typical Junction Capacitance
TJ=25°C
TJ=25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
100
1.0
0.1
pulse with 300μ
s
0.0
0.5
1.0
1.5
2.0
TJ=25°C
f = 1.0MHz
Vsig = 50mVp-p
1% duty cycle
0.01
10
1
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
60
50
40
30
8.3 ms Single Half Sine Wave (JEDEC
Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
RS2AW THRU RS2MW
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.2
0.047
B
0.047
C
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“RS2MW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25560
- 100+0.15250
- 800+0.10670
- 3000+0.07620
- 6000+0.07250
- 30000+0.06700
