RS3ABF THRU RS3MBF
Forward Current - 3.0 Ampere
Reverse Voltage - 50 to 1000 Volts
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
SMBF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Fast switching for high efficiency
Low reverse leakage
Built-in strain relief,ideal for automated placement
0.146(3.70)
0.138(3.50)
0.086 (2.20)
0.075 (1.90)
0.173(4.40)
0.165(4.20)
High forward surge current capability
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.051(1.30)
0.043(1.10)
Glass passivated chip junction
0.010(0.26)
0.007(0.18)
0.048(1.20)
0.031(0.80)
Mechanical Data
0.216(5.50)
0.200(5.10)
Case : JEDEC SMBF Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002ounce, 0.057 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
RS3ABF RS3BBF RS3DBF RS3GBF
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=125℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
VRRM
VRMS
VDC
RS3JBF RS3KBF RS3MBF
UNITS
MDD
R3AB
MDD
R3BB
MDD
R3DB
MDD
R3GB
MDD
R3JB
MDD
R3KB
MDD
R3MB
50
35
100
70
200
140
400
280
600
420
800
560
1000
700
V
V
50
100
200
400
600
800
1000
V
I(AV)
3.0
A
IFSM
80
A
Maximum instantaneous forward voltage at 3.0A
VF
1.30
V
Maximum DC reverse current
at rated DCblocking voltage
IR
5.0
100
μA
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
trr
150
250
40
CJ
RJA
45
RθJC
15
Operating junction and storage temperature range TJ,TSTG
-55 to +150
500
ns
pF
℃/W
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A3
Page :1
RS3ABF THRU RS3MBF
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
Junction Capacitance (pF)
Instaneous Forward Current (A)
60
80
100
120
140
Fig.4 Typical Junction Capacitance
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics
10
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surge Current (A)
Fig.5 Maximum Non-Repetitive Peak
90
75
60
45
30
15
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A3
Page :2
RS3ABF THRU RS3MBF
Packing information
P0
unit:mm
P1
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Item
Symbol
Tolerance
SMBF
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.61
1.60
1 50
330.00
50.00
13.00
1.75
5.50
4.00
4.00
2.00
0.30
12.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMBF
13"
5,000
4.0
10,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
2.54
0.100
B
1.8
0.071
C
4.8
0.189
D
3.0
0.118
E
6.6
0.260
Unit (inch)
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“RS3MBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34402
- 100+0.28750
- 1000+0.23800
- 2000+0.22097
- 5000+0.18662
- 国内价格
- 5+0.37530
- 50+0.31364
- 150+0.28275
- 500+0.25964
- 2500+0.24106
- 5000+0.20358
