RS3AB THRU RS3MB
Reverse Voltage - 50 to 1000 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
Open Junction chip
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
0.185(4.70)
0.160(4.06)
0.012(0.305)
0.006(0.152)
250℃/ 10 seconds at terminals
Glass passivated chip junction
0.096(2.44)
0.084(2.13)
Mechanical Data
0.060(1.52)
0.030(0.76)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003 ounce, 0.098grams
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
MDD
MDD
RS3AB RS3BB
50
35
50
MDD
MDD
MDD
RS3DB RS3GB RS3JB
100
70
100
200
140
200
400
280
400
600
420
600
MDD
MDD
RS3KB RS3MB
800
560
800
1000
700
1000
UNITS
V
V
V
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
Maximum average forward rectified current
I(AV)
3.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
90
A
Maximum instantaneous forward voltage at 3.0A
VF
1.3
V
Maximum DC reverse current
at rated DCblocking voltage
IR
5
100
μA
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
VRMS
VDC
trr
150
250
40
CJ
RJA
48
RθJC
16
Operating junction and storage temperature range TJ,TSTG
-55 to +150
500
ns
pF
℃/W
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
RS3AB THRU RS3MB
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Maximum Average Forward Current Rating
Instaneous Reverse Current(μ A)
4.0
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
175
100
TJ=125°C
10
1.0
TJ=25°C
0.1
00
Case Temperature (°C)
60
80
100
C
140
TJ=25°C
1.0
0.1
pulse with 300μ
s
1% duty cycle
0.01
0.0
120
Fig.4 Typical Junction Capacitance
Junction Capacitance (pF)
Instaneous Forward Current (A)
40
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics TJ=25°
10
1.0
1.5
2.0
100
10
TJ=25°C
f = 1.0MHz
Vsig = 50mVp-p
1
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
120
100
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
RS3AB THRU RS3MB
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“RS3JB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.51200
- 100+0.30540
- 800+0.21380
- 3000+0.15270
- 6000+0.14510
- 30000+0.13440
- 国内价格
- 1+0.29387
- 10+0.23631
- 30+0.20758
- 100+0.18598
- 500+0.16870
- 1000+0.16006
