SL52C THRU SL510C
Reverse Voltage - 20 to 100 Volts
Forward Current - 5.0 Ampere
LOW FORWARD VOLTAGE SCHOTTKY BARRIER DIODES
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
0.280(7.11)
0.260(6.60)
High forward surge current capability
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case : JEDEC DO-214AB/SMC Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.007ounce, 0.25 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=90℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
VRRM
VRMS
VDC
MDD
SL52C
MDD
SL53C
MDD
SL54C
MDD
SL55C
MDD
SL56C
21
30
40
28
40
50
35
50
60
42
60
MDD
MDD
SL58C SL510C
80
56
80
100
70
100
UNITS
V
V
V
I(AV)
5.0
A
IFSM
120
A
VF
IR
CJ
RJA
Operating junction and storage temperature range TJ,TSTG
0.45
0.50
0.5
20.0
0.70
0.2
10.0
V
mA
200
pF
55.0
℃/W
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
Rev:2024A1
Page :1
SL52C THRU SL510C
FIG. 1- FORWARD CURRENT DERATING CURVE
5.0
P.C.B mounted on
2.0*2.0"(5.0*5.0cm)
copper pad areas
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SL52C-SL56C
SL58C-SL510C
1.0
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
120
96
72
48
24
175
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
50
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SL52C-SL54C
SL55C-SL56C
SL58C-SL510C
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
TJ=25 C
100
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
0.9
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
SL52C THRU SL510C
Packing information
P0
P1
unit:mm
d
E
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
F
B
A
W
P
D2
D1
T
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
BOX
(pcs)
6000
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
CARTON
SIZE
(mm)
365*365*340
CARTON
(pcs)
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Unit (inch)
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“SL56C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.45800
- 200+1.46620
- 800+1.02640
- 3000+0.73310
- 6000+0.69640
- 30000+0.64520
