SS12F THRU SS1200F
Reverse Voltage - 20 to 200 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
Built-in strain relief,ideal for automated placement
0.146(3.70)
0.130(3.30)
High forward surge current capability
High temperature soldering guaranteed:
260 °C/10 seconds at terminals
0.047(1.20)
0.035(0.90)
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
Mechanical Data
0.193(4.90)
0.173(4.40)
Case: JEDEC SMAF molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight : 0.00095ounce, 0.027grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
VRRM
Maximum RMS voltage
Maximum DC blocking voltage
VRMS
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
VDC
MDD
SS13F
MDD
SS14F
MDD
SS15F
MDD
SS16F
MDD
SS18F
MDD
SS110F
MDD
SS1150F
MDD
SS1200F
UNITS
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
I(AV)
1.0
A
IFSM
25
A
VF
0.55
CJ
RJA
Operating junction temperature range
TJ
TSTG
0.70
0.3
10.0
IR
Typical thermal resistance (NOTE 2)
Storage temperature range
MDD
SS12F
110
0.85
0.90
V
0.2
5.0
80
0.1
2.0
mA
pF
℃/W
95.0
-55 to +125
-55to +150
-55to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SS12F THRU SS1200F
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current ( μA)
1.0
Average Forward Current (A)
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
SS12F-SS14F
SS16F-SS1200F
0.2
50
75
100
125
150
10
4
10
3
10
2
TJ=100°C
TJ=75°C
101
TJ=25°C
Case Temperature (°C)
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
500
TJ=25°C
200
1.0
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
SS12F/SS14F
SS16F
SS18F/SS112F
SS115F/SS120F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
SS12F/SS14F
SS16F-SS120F
10
1.8
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
25
1000
10
05
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
00
10
1
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS12F THRU SS1200F
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SMAF
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
2.80
4.75
1.42
1.50
178.00
54.40
13.00
1.75
5.05
4.00
4.00
2.00
0.30
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMAF
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
3,000
4.0
6,000
210*208*203
178
400*265*400
120,000
10.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.8
0.071
B
C
1.6
3.8
0.150
D
2.2
0.087
E
5.4
0.213
0.063
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS110F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.33705
- 200+0.11235
- 1500+0.07025
- 3000+0.05576
- 国内价格
- 50+0.12445
- 600+0.08412
- 1200+0.08286
- 3000+0.07548
- 国内价格
- 1000+0.09323
- 3000+0.08080
- 国内价格
- 10+0.13577
- 100+0.10749
- 300+0.09177
- 3000+0.08234
- 6000+0.07418
- 9000+0.06967
