SS12 THRU SS1200
Reverse Voltage - 20 to 200 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.039 (1.00)
High forward surge current capability
High temperature soldering guaranteed:
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.096(2.42)
0.078(1.98)
Mechanical Data
0.059(1.50)
0.035(0.90)
Ca s e : JEDEC DO-214AC/SMA molded plastic body
Termina ls : Solderable per MIL-STD-750,Method 2026
Po larity : Color band denotes cathode end Moun ting
Po s ition : Any
Weigh t : 0.002 ounce, 0.07 grams
0.008(0.203)MAX.
0.205(5.20)
0.188(4.80)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
SS12
MDD
SS13
MDD
SS14
MDD
SS15
MDD
SS16
MDD
SS18
MDD
SS110
MDD
SS1150
MDD
SS1200
UNITS
Maximum repetitive peak reverse voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS voltage
Maximum DC blocking voltage
VRMS
VDC
14
30
28
40
35
50
42
60
56
80
70
100
105
150
140
200
V
V
Marking Code
I(AV)
1.0
A
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
25
A
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25℃
at rated DCblocking voltage
TA=100℃
VF
Maximum average forward rectified current
Peak forward surge current
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
0.55
0.3
10.0
IR
CJ
110
0.70
0.85
0.2
5.0
0.9
V
0.1
2.0
pF
80
RθJA
90.0
TJ
-55 to +150
TSTG
-55 to +150
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
mA
Rev:2024A3
Page :1
SS12 THRU SS1200
Typical Characterisitics
Fig.1 Forward Current Derating Curve
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Average Forward Current(A)
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10
4
10
3
10
2
TJ=100°C
TJ=75°C
SS12/SS14
SS16-SS120
101
10
TJ=25°C
Case Temperature(℃)
40
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
500
TJ=25°C
200
1.0
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
SS12/SS14
SS16
SS18~SS1120
SS1150/SS1200
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
SS12/SS14
SS16-SS1200
10
1.8
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
100
25
10
05
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
100
Fig.6- Typical Transient Thermal Impedance
30
00
10
1
Reverse Voltage (V)
Instaneous Forward Voltage (V)
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A3
Page :2
SS12 THRU SS1200
Packing information
unit:mm
P0
P1
Item
D1
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
d
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
E
W1
F
B
A
W
P
D2
T
C
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMA
REEL SIZE
7"
APPROX.
GROSS WEIGHT
(kg)
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
382*356*392
10,000
290*290*38
330
310*310*360
80,000
11.0
15,000
335*335*38
330
350*330*360
120,000
14.5
SMA
11"
5,000
4.0
SMA
13"
7,500
4.0
CARTON
SIZE
(m/m)
CARTON
(pcs)
80,000
16.0
Suggested Pad Layout
Symbol
A
Unit (mm)
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“SS13”相匹配的价格&库存,您可以联系我们找货
