SS32BF THRU SS320BF
Reverse Voltage - 20 to 200 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SMBF
Metal silicon junction, majority carrier conduction For surface
mounted applications
0.146(3.70)
0.138(3.50)
0.086 (2.20)
0.075 (1.90)
Low power loss,high efficiency
High forward surge current capability
For use in low voltage,high frequency inverters, free
0.173(4.40)
0.165(4.20)
wheeling,and polarity protection applicatlons
0.051(1.30)
0.043(1.10)
Mechanical Data
0.010(0.26)
0.007(0.18)
0.048(1.20)
0.031(0.80)
Case:JEDEC 60B) molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body Mounting
Position: Any
Weight : 0.002 ounce, 0.057 grams
0.216(5.50)
0.200(5.10)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SS32BF SS33BF SS34BF SS35BF SS36BF SS38BF SS310BF
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
VRRM
Maximum RMS voltage
Maximum DC blocking voltage
VRMS
VDC
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
at rated DC blocking voltage
SS315BF SS320BF
MDD
S32B
MDD
S33B
MDD
S34B
MDD
S35B
MDD
S36B
MDD
S38B
MDD
S310B
MDD
S315B
MDD
S320B
UNITS
30
21
40
28
50
35
60
42
80
56
100
70
150
105
200
140
V
40
50
60
80
100
150
200
V
V
I(AV)
3.0
A
IFSM
80
A
VF
0.55
0.70
0.85
0.95
V
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
CJ
Typical thermal resistance (NOTE 2)
RJA
Operating junction temperature range
TJ
-55 to +125
TSTG
-55 to +150
Storage temperature range
IR
0.5
5.0
450
0.3
3.0
mA
pF
400
65
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SS32BF THRU SS320BF
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current ( μA)
3.5
Average Forward Current (A)
3.0
2.4
1.8
1.2
0.6
0.0
25
75
50
100
125
150
10
4
10
3
10
2
TJ=100°C
TJ=75°C
SS32BF/SS36BF
TJ=25°C
10
Case Temperature (°C)
80
100
TJ=25°C
1000
10
1.0
Junction Capacitance (pF)
500
SS32BF/SS345BF
SS36BF
SS38BF/SS312BF
SS315BF/SS320BF
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
200
100
SS32BF~SS36BF
SS38BF~SS320BF
10
0.1
1
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
100
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
60
Fig.4 Typical Junction Capacitance
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
SS38BF-SS320BF
101
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS32BF THRU SS320BF
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMBF
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.61
1.60
1 50
330.00
50.00
13.00
1.75
5.50
4.00
4.00
2.00
0.30
12.00
12.30
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMBF
13"
5,000
4.0
10,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
2.54
0.100
B
1.8
0.071
C
4.8
0.189
D
3.0
0.118
E
6.6
0.260
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS36BF”相匹配的价格&库存,您可以联系我们找货
