ST34B THRU ST310B
Reverse Voltage - 40 to 100 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
High efficiency operation
Ultra low forward voltage drop,low power losses
High forward surge current capability
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.06)
High temperature soldering guaranteed:
260°C/10 seconds,0.375” (9.5mm) lead length, 5
0.012(0.305)
0.006(0.152)
lbs. (2.3kg) tension
0.096(2.44)
0.084(2.13)
Mechanical Data
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003ounce, 0.093 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
ST34B
Maximum repetitive peak reverse voltage
VRRM
40
Maximum RMS voltage
VRMS
28
Maximum DC blocking voltage
VDC
40
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
I(AV)
Peak forward surge current
8.3ms single half sine-wave superimposed on rated
load (JEDEC Method)
IFSM
80.0
70.0
80.0
A
VF
0.45
0.50
0.60
V
0.30
0.50
0.3
MDD Catalog Number
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 °C
at rated DC blocking voltage
TA=100 °C
Typical junction capacitance (NOTE 1)
IR
CJ
Typical thermal resistance (NOTE 2)
Operating junction temperature range
RθJA
Storage temperature range
TSTG
TJ,
ST36B
ST310B
UNITS
60
100
V
42
70
V
60
100
V
3.0
A
5.0
400
450
60
-55 to +125
-55 to +150
-55 to +150
mA
180
pF
70
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
ST34B THRU ST310B
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
3
P.C.B mounted on
2.0*2.0"(5.0*5.0cm)
copper pad areas
2.4
1.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
ST34B
ST36B-ST310B
0.6
50
75
100
125
150
175
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
90
75
ST34B
ST36B-ST310B
60
45
30
15
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
ST34B
ST36B
ST310B
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
100
10
1000
100
TJ=25 C
10
REVERSE VOLTAGE,VOLTS
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
2000
1.0
TJ=75 C
0.1
TJ=25 C
0.01
0.001
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
0.1
TJ=100 C
1
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
10
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
ST34B THRU ST310B
Packing information
P0
P1
d
unit:mm
E
F
B
A
Item
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
D1
T
C
W1
D
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMB
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
13"
3,000
4.0
BOX
(pcs)
6,000
INNER
BOX
(mm)
REEL
DIA,
(mm)
CARTON
SIZE
(mm)
CARTON
(pcs)
190*190*41
330
365*365*360
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“ST310B”相匹配的价格&库存,您可以联系我们找货
