ST34 THRU ST310
Reverse Voltage - 40 to 100 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
High forward surge current capability
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.096(2.42)
0.078(1.98)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.208(5.30)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002ounce, 0.07 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
MDD Catalog Number
ST34
ST36
ST310
UNITS
Maximum repetitive peak reverse voltage
VRRM
40
60
100
V
Maximum RMS voltage
VRMS
28
42
70
V
Maximum DC blocking voltage
VDC
40
60
100
V
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
I(AV)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25 ℃
TA=100°C
Typical junction capacitance (NOTE 1)
VF
3.0
80.0
CJ
RθJA
Storage temperature range
TSTG
TJ,
0.50
0.45
0.30
IR
Typical thermal resistance (NOTE 2)
Operating junction temperature range
A
100.0
A
0.60
V
0.10
mA
280
pF
C/W
5.0
450
400
60
-55 to +125
-55 to +150
-55 to +150
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
ST34 THRU ST310
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
3
P.C.B mounted on
0.2*0.2"(5.0*5.0cm)
copper pad areas
2.4
1.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
ST34
ST36-ST310
0.6
50
75
100
125
150
175
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
90
75
ST34
ST36-ST310
60
45
30
15
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
0.1
ST34
ST36
ST310
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
100
10
TJ=100 C
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
2000
1000
100
TJ=25 C
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
ST34 THRU ST310
Packing information
unit:mm
P0
P1
d
Item
E
F
B
A
W
P
D2
D1
T
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
CARTON
SIZE
(m/m)
CARTON
(pcs)
480,000
APPROX.
GROSS WEIGHT
(kg)
12.0
SMA
7"
SMA
11"
5,000
4.0
10,000
290*290*38
330
310*310*360
80,000
11.0
SMA
13"
7,500
4.0
15,000
335*335*38
330
350*330*360
120,000
14.5
382*356*392
Suggested Pad Layout
https://www.microdiode.com
Symbol
Unit (mm)
A
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.90
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“ST34”相匹配的价格&库存,您可以联系我们找货
