ST34BF THRU ST310BF
Reverse Voltage - 40 to 100 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER
Features
SMBF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
High efficiency operation
Ultra low forward voltage drop,low power losses
High forward surge current capability
0.146(3.70)
0.138(3.50)
0.086 (2.20)
0.075 (1.90)
0.173(4.40)
0.165(4.20)
High temperature soldering guaranteed:
260°C/10 seconds,0.375” (9.5mm) lead length, 5
lbs. (2.3kg) tension
0.051(1.30)
0.043(1.10)
0.010(0.26)
0.007(0.18)
0.048(1.20)
0.031(0.80)
Mechanical Data
0.216(5.50)
0.200(5.10)
Case : JEDEC SMBF Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002ounce, 0.057 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
ST34BF
ST36BF
ST310BF
MDD
ST34BF
MDD
ST36BF
MDD
ST310BF
UNITS
Maximum repetitive peak reverse voltage
VRRM
40
60
100
V
Maximum RMS voltage
VRMS
28
42
70
V
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
VDC
40
60
100
V
Peak forward surge current 8.3ms single half sinewave
I(AV)
3.0
A
IFSM
80
A
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DCreverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction temperature range
Operating storage temperaturerange
VF
0.45
0.50
0.60
0.30
IR
0.10
5.0
CJ
350
RJA
47.0
160
400
60.0
V
mA
pF
℃/W
TJ
-55 to +150
TSTG
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
ST34BF THRU ST310BF
FIG. 1- FORWARD CURRENT DERATING CURVE
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half wave resistive
or inductive
0.0
25
75
50
100
125
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
90
75
ST34BF
ST36BF-ST310BF
60
45
30
15
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
0.1
ST34BF
ST36BF
ST310BF
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
100
10
TJ=100 C
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
2000
1000
100
TJ=25 C
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
ST34BF THRU ST310BF
Packing information
P0
P1
unit:mm
d
E
Item
Symbol
Tolerance
SMBF
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.61
1.60
1 50
330.00
50.00
13.00
1.75
5.50
4.00
4.00
2.00
0.30
12.00
12.30
F
B
A
W
P
D2
D1
T
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMBF
13"
5,000
4.0
10,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
2.54
0.100
B
1.8
0.071
C
4.8
0.189
D
3.0
0.118
E
6.6
0.260
Unit (inch)
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“ST36BF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+1.43820
- 100+0.85790
- 500+0.60050
- 5000+0.42890
- 10000+0.40760
- 50000+0.37740
- 国内价格
- 5+0.45257
- 50+0.36049
- 150+0.31441
- 500+0.27988
- 2500+0.25227
- 5000+0.23847
