ST54B THRU ST510B
Reverse Voltage - 40 to 100 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
High efficiency operation
Ultra low forward voltage drop,low power losses
High forward surge current capability
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.185(4.70)
0.160(4.06)
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
260°C/10 seconds,0.375” (9.5mm) lead length, 5
lbs. (2.3kg) tension
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.220(5.59)
0.200(5.08)
Case : JEDEC DO-214AA/SMB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003ounce, 0.093 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
ST54B
ST56B
ST510B
MDD
ST54B
MDD
ST56B
MDD
ST510B
UNITS
Maximum repetitive peak reverse voltage
VRRM
40
60
100
V
Maximum RMS voltage
VRMS
28
42
70
V
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
VDC
40
60
100
V
Peak forward surge current 8.3ms single half sinewave
I(AV)
A
5.0
A
90
IFSM
100
Maximum instantaneous forward voltage at 5.0A
VF
0.45
0.50
0.60
Maximum DCreverse current
at rated DCblocking voltage
0.10
0.05
0.03
IR
superimposed onrated load (JEDEC Method)
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Operating storage temperaturerange
20.0
10.0
V
mA
CJ
500
pF
RJA
75.0
℃/W
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
ST54B THRU ST510B
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
5
P.C.B mounted on
2.0*2.0"(5.0*5.0cm)
copper pad areas
4
3
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
2
ST54B
ST56B-ST510B
1
50
75
100
125
150
175
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
120
100
ST54B
ST56B-ST510B
80
60
40
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
0.1
0.01
ST54B
ST56B
ST510B
0.0
0.2
0.4
0.6
0.8
0.9
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
100
10
1000
100
TJ=25 C
1.0
10
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
REVERSE VOLTAGE,VOLTS
TJ=75 C
0.1
TJ=25 C
0.01
0.001
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
2000
0.1
TJ=100 C
1
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
10
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
ST54B THRU ST510B
Packing information
P0
P1
d
unit:mm
E
F
B
A
Item
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
D1
T
C
W1
D
Symbol
Tolerance
SMB
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMB
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
13"
3,000
4.0
BOX
(pcs)
6,000
INNER
BOX
(mm)
REEL
DIA,
(mm)
CARTON
SIZE
(mm)
CARTON
(pcs)
190*190*41
330
365*365*360
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
Unit (inch)
0.110
4.6
0.094
0.181
2.2
7.0
0.086
0.276
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“ST54B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.92980
- 200+1.15110
- 800+0.80580
- 3000+0.57560
- 6000+0.54680
- 30000+0.50650
- 国内价格
- 5+0.98723
- 50+0.78084
- 150+0.67770
- 500+0.60027
- 3000+0.53838
- 6000+0.50739
