ST54C
ST54C
    MDD(辰达半导体)
    SMC(DO-214AB)
    直流反向耐压(Vr):40V;平均整流电流(Io):5A;正向压降(Vf):430mV@5A;
ST54C 数据手册
ST54C THRU ST510C Reverse Voltage - 40 to 100 Volts Forward Current - 5.0 Ampere SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER Features DO-214AB/SMC  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Metal silicon junction,majority carrier conduction  High efficiency operation  Ultra low forward voltage drop,low power losses  High forward surge current capability 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90) 0.280(7.11) 0.260(6.60)  High temperature soldering guaranteed: 0.012(0.305) 0.006(0.152) 260°C/10 seconds at terminals 0.103(2.62) 0.079(2.06) Mechanical Data 0.060(1.52) 0.030(0.76) Case : SMC Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 217mg / 0.0077oz 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code ST54C ST56C ST510C MDD ST54C MDD ST56C MDD ST510C UNITS Maximum repetitive peak reverse voltage VRRM 40 60 100 V Maximum RMS voltage VRMS 28 42 70 V Maximum DC blocking voltage VDC 40 60 100 V Maximum average forward rectified current 0.375”(9.5mm) lead length(see fig.1) I(AV) 5.0 A IFSM 150 A Peak forward surge current 8.3ms single half sinewave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 5.0A Maximum DCreverse current TA=25℃ at rated DCblocking voltage TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Operating storage temperaturerange VF 0.45 IR 0.50 0.5 50 0.60 V mA CJ 500 pF RJA 60 ℃/W TJ -55 to +125 ℃ TSTG -55 to +150 ℃ Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2024A1 Page :1 ST54C THRU ST510C Reverse Voltage - 40 to 100 Volts Forward Current - 5.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve 10 4 10 3 10 2 5.0 TJ=100°C 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( A )μ Average Forward Current (A) 6.0 101 10 Case Temperature (°C) 0 0 60 80 Junction Capacitance (pF) 1 SSL54C SSL56C SSL510C 0 0.5 1.0 1.5 2.0 500 100 SSL54C 20 10 SSL56C-SSL510C 0.1 °C / W) 120 100 80 60 40 Wave 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance( 140 1 10 100 Fig.6- Typical Transient Thermal Impedance 160 8.3 ms Single Half Sine (JEDEC Method) 1 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 20 100 TJ=25°C Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 1000 10 00 20 Fig.4 Typical Junction Capacitance 20 Instaneous Forward Current (A) TJ=25°C Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 0.1 TJ=75°C 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2 ST54C THRU ST510C Reverse Voltage - 40 to 100 Volts Forward Current - 5.0 Ampere Packing information P0 P1 unit:mm d E F B A Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 BOX (pcs) 6000 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout Symbol Unit (mm) A 4.3 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Unit (inch) Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2024A1 Page :3
ST54C 价格&库存
很抱歉,暂时无法提供与“ST54C”相匹配的价格&库存,您可以联系我们找货
ST54C
  • 10+2.55440
  • 200+1.52370
  • 800+1.06660
  • 3000+0.76190
  • 6000+0.72380
  • 30000+0.67040
