ST54C THRU ST510C
Reverse Voltage - 40 to 100 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
High efficiency operation
Ultra low forward voltage drop,low power losses
High forward surge current capability
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
0.280(7.11)
0.260(6.60)
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
260°C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
Mechanical Data
0.060(1.52)
0.030(0.76)
Case : SMC
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 217mg / 0.0077oz
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
ST54C
ST56C
ST510C
MDD
ST54C
MDD
ST56C
MDD
ST510C
UNITS
Maximum repetitive peak reverse voltage
VRRM
40
60
100
V
Maximum RMS voltage
VRMS
28
42
70
V
Maximum DC blocking voltage
VDC
40
60
100
V
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
I(AV)
5.0
A
IFSM
150
A
Peak forward surge current 8.3ms single half sinewave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DCreverse current
TA=25℃
at rated DCblocking voltage
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Operating storage temperaturerange
VF
0.45
IR
0.50
0.5
50
0.60
V
mA
CJ
500
pF
RJA
60
℃/W
TJ
-55 to +125
TSTG
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
ST54C THRU ST510C
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
10
4
10
3
10
2
5.0
TJ=100°C
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( A
)μ
Average Forward Current (A)
6.0
101
10
Case Temperature (°C)
80
Junction Capacitance (pF)
1
SSL54C
SSL56C
SSL510C
1.0
1.5
2.0
500
100
SSL54C
SSL56C-SSL510C
0.1
°C /
W)
120
100
80
60
40
Wave
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(
140
1
10
100
Fig.6- Typical Transient Thermal Impedance
160
8.3 ms Single Half Sine
(JEDEC Method)
1
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
TJ=25°C
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
40
1000
10
00
Fig.4 Typical Junction Capacitance
Instaneous Forward Current (A)
TJ=25°C
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
0.1
TJ=75°C
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A1
Page :2
ST54C THRU ST510C
Packing information
P0
P1
unit:mm
d
E
F
B
A
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
BOX
(pcs)
6000
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
CARTON
SIZE
(mm)
365*365*340
CARTON
(pcs)
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Unit (inch)
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“ST56C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.40703
- 50+1.11413
- 150+0.98853
- 500+0.83193
- 3000+0.76227
- 6000+0.72036
