UMB2S THRU UMB10S
Voltage Range - 200 to 1000 V olts
Current - 0.5/0.8 Ampere
GLASS PASSIVATED ULTRA FAST RECOVERY BRIDGE RECTIFIERS
Features
MBS
Ideal for printed circuit board
.043(1.10)
.028(0.70)
Reliable low cost construction utilizing molded plastic technique
.193(4.90)
.177(4.50)
.053(1.53)
.037(0.95)
High temperature soldering guaranteed: 260°/10 seconds at 5
.033(0.84)
.022(0.56)
lbs., (2.3kg) tension
.157(4.00)
Small size, simple installation
High surge current capability
.276(7.0)
MAX
.142(3.60)
.083(2.12)
.043(1.10)
.014(0.35)
.006(0.15)
.102(2.60)
.087(2.20)
Mechanical Data
(1)
(2)
Case : JEDEC MBS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0035 ounce, 0.1 grams
.106(2.70)
.118(3.0)
.090(2.30)
MAX
.008(0.20)
MAX
(4)
(3)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
UMB2S
MDD
UMB4S
MDD
UMB6S
MDD
UMB8S
MDD
UMB10S
UNITS
VRRM
VRMS
VDC
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
On glass-epoxy P.C.B.(Note1)
On aluminum substrate(Note2)
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 0.4A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=100°C
Maximum reverse recovery time
Typical thermal resistance(NOTE 3)
Operating temperature range
storage temperature range
(NOTE 4)
IF(AV)
0.5
0.8
A
IFSM
30
A
VF
1.0
1.4
RθJL
RθJA
TJ
TSTG
50
V
uA
mA
5
0.5
IR
trr
1.7
75
28
85
-55 to +150
-55 to +150
ns
°C/W
°C
°C
NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads.
2.On aluminum substrate P.C.B. with an area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad.
3.Thermal resistance form junction to ambient and junction to lead mounted on P.C.B. with 0.2X0.2''(5X5mm)copper pads.
4.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A.
http://www.microdiode.com
Rev:2024A1
Page :1
UMB2S THRU UMB10S
Ratings And Characteristic Curves
FIG.2 PEAK FORWARD SURGE CURRENT
FIG.1 FORWARD DERATING CURVE
35
Peak Forward Surge Current,
(A)
Average Forward Rectified
Current, (A)
0.8
Aluminum Substrate
0.7
0.6
0.5
0.4
Glass Epoxy
P.C.B.
0.3
0.2
0.1
60
80
100
120
140 )
160
30
25
10
5
Ambient Temperature, (°C )
Number Of Cycles At 60Hz
FIG.3 TYPICAL FORWARD CHARACTERISTICS
FIG.4 TYPICAL REVERSE CHARACTERISTICS
100
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
1
0.1
UMB2S
UMB4S
UMB6S-UMB10S
0.2
0.6
1.0
1.4
1.8
2.0
Instantaneous Reverse Leakage
Current, ( A)
Instantaneous Forward Current, (A)
100
10
TJ=125
10
1
0.1
TJ=25
0.01
Instantaneous Forward Voltage, ( V )
60
80
100
Percent Of Rated Peak Reverse Voltage, %
The curve above is for reference only.
Rev:2024A1
Page :2
UMB2S THRU UMB10S
Suggested Pad Layout
P2
P1
Dim
Min
P1
6.00
P2
2.40
Q1
1.84
Q2
1.20
Q1
Q2
Dimensions in millimeters
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“UMB10S”相匹配的价格&库存,您可以联系我们找货
