US3AC THRU US3MC
Reverse Voltage - 50 to 1000 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT ULTRA FAST RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Ultra fast switching for high efficiency
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed
250 °C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
Mechanical Data
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case : JEDEC DO-214AB/SMC Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002 ounce, 0.25 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
at rated DCblocking voltage
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
US3AC US3BC US3DC US3GC US3JC US3KC US3MC
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
3.0
A
IFSM
90
A
VF
1.0
1.3
5.0
100.0
IR
trr
50
CJ
RJA
RθJC
75.0
TJ,TSTG
1.68
45.0
15.0
-55 to +150
V
μA
75
ns
50
pF
℃/W
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
US3AC THRU US3MC
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Maximum Average Forward Current Rating
4.0
Instaneous Reverse Current(μ A)
100
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
TJ=125°C
10
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
80
100
120
140
120
1.0
US3AC~US3DC
US3GC
0.1
US3JC~US3MC
0.01
Fig.4 Maximum Non-Repetitive Peak
TJ=25°C
0.001
40
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Forward Characteristics
10
1.0
1.5
Instaneous Forward Voltage (V)
2.0
2.5
100
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
US3AC THRU US3MC
Packing information
P0
unit:mm
P1
d
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
BOX
(pcs)
6000
CARTON
SIZE
(mm)
CARTON
(pcs)
365*365*340
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
C
4.1
7.9
0.160
0.311
D
3.8
0.150
E
12
0.472
B
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“US3GC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37865
- 100+0.29927
- 300+0.25964
- 3000+0.22994
- 6000+0.20607
- 9000+0.19419
- 国内价格
- 20+0.73760
- 100+0.44000
- 800+0.30800
- 3000+0.22000
- 6000+0.20900
- 30000+0.19350
