FM25Q128AI3
128M-BIT SERIAL FLASH MEMORY
Datasheet
Sep. 2022
FM25Q128AI3 128M-BIT SERIAL FLASH MEMORY
V1.0
Datasheet
1
INFORMATION IN THIS DOCUMENT IS INTENDED AS A REFERENCE TO ASSIST OUR CUSTOMERS IN THE
SELECTION OF SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCT BEST SUITED TO THE
CUSTOMER'S APPLICATION AND SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD
DOES NOT
GUARANTEE THE AUTHENTICITY AND INTEGRITY OF THE INFORMATION.
INFORMATION DO NOT CONVEY ANY LICENSE UNDER ANY INTELLECTUAL PROPERTY RIGHTS, OR ANY OTHER RIGHTS,
BELONGING TO SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD OR A THIRD PARTY.
WHEN USING THE INFORMATION CONTAINED IN THIS DOCUMENTS, PLEASE BE SURE TO EVALUATE ALL INFORMATION
AS A TOTAL SYSTEM BEFORE MAKING A FINAL DECISION ON THE APPLICABILITY OF THE INFORMATION AND
PRODUCTS.
PURCHASERS ARE SOLELY RESPONSIBLE FOR THE CHOICE, SELECTION AND USE OF THE SHANGHAI FUDAN
MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN, AND SHANGHAI FUDAN
MICROELECTRONICS GROUP CO., LTD ASSUMES NO LIABILITY WHATSOEVER RELATING TO THE CHOICE, SELECTION
OR USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED
HEREIN. UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED SHANGHAI FUDAN MICROELECTRONICS
GROUP CO., LTD REPRESENTATIVE, SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS ARE NOT
RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE
SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN
PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE.
FUTURE ROUTINE REVISIONS WILL OCCUR WHEN APPROPRIATE, WITHOUT NOTICE. CONTACT SHANGHAI FUDAN
MICROELECTRONICS GROUP CO., LTD SALES OFFICE TO OBTAIN THE LATEST SPECIFICATIONS AND BEFORE PLACING
YOUR PRODUCT ORDER. PLEASE ALSO PAY ATTENTION TO INFORMATION PUBLISHED BY SHANGHAI FUDAN
MICROELECTRONICS GROUP CO., LTD BY VARIOUS MEANS, INCLUDING SHANGHAI FUDAN MICROELECTRONICS
GROUP CO., LTD HOME PAGE (HTTP://WWW.FMSH.COM/).
PLEASE CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD LOCAL SALES OFFICE FOR THE
SPECIFICATION REGARDING THE INFORMATION IN THIS DOCUMENT OR SHANGHAI FUDAN MICROELECTRONICS
GROUP CO., LTD PRODUCTS.
Trademarks
Shanghai Fudan Microelectronics Group Co., Ltd name and logo, the “复旦” logo are trademarks or registered trademarks of
Shanghai Fudan Microelectronics Group Co., Ltd or its subsidiaries in China.
Shanghai Fudan Microelectronics Group Co., Ltd, Printed in the China, All Rights Reserved.
V1.0
Datasheet
2
1.
Description
The FM25Q128AI3 is a 128M-bit (16,384K-byte) Serial Flash memory, operating in wide voltage
range. The FM25Q128AI3 supports the standard Serial Peripheral Interface (SPI), Dual/Quad I/O
as well as 2-clock instruction cycle Quad Peripheral Interface (QPI).
The FM25Q128AI3 can be programmed 1 to 256 bytes at a time, using the Page Program
instruction. It is designed to allow either single Sector/Block at a time or full chip erase operation.
The FM25Q128AI3 can be configured to protect part of the memory as the software protected
mode. The device can sustain a minimum of 100K program/erase cycles on each sector or block.
2.
Features
128Mbit of Flash memory
– 4096 uniform sectors with 4K-byte each
– 256 uniform blocks with 64K-byte each or
– 512 uniform blocks with 32K-byte each
– 256 bytes per programmable page
Serial Interface
– Standard SPI: CLK, CS#, DI, DO, WP#
– Dual SPI: CLK, CS#, DQ0, DQ1, WP#
– Quad SPI: CLK, CS#, DQ0, DQ1, DQ2,
DQ3
– QPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3
– Continuous READ mode support
– Program / Erase Suspend and Resume
support
– Allow true XIP (execute in place)
operation
High Performance
– Max FAST_READ clock frequency:
100MHz
– Max READ clock frequency: 50MHz
– Typical page program time: 0.7ms
– Typical sector erase time: 45ms
– Typical block erase time: 200/250ms
– Typical chip erase time: 50s
Supply Voltage: 2.3V to 3.6V
Industrial Temperature Rage
Flexible Architecture with 4KB Sectors
– Uniform Sector Erase(4K-bytes)
– Uniform Block Erase(32K and 64Kbytes)
– Program 1 to 256 bytes per programmable
page
– Erase/Program Suspend & Resume
Advanced Security Features
– Software and hardware write protection
– Top/Bottom, 4KB complement array
protection
– Power Supply Lock-Down and OTP
protection
– Individual Block/Sector array protection
– Lockable 4X256-Byte OTP Security
Register
– Discoverable
Parameters
(SFDP)
Register
– 64-Bit Unique ID for each device
– Volatile & Non-volatile Status Register
Bits
Green Package
– 8-pin SOP (208mil)
– 8-pad TDFN (6x5mm)
– 24-ball BGA (8x6mm)
– All Packages are RoHS Compliant and
Halogen-free
V1.0
Datasheet
3
3.
Packaging Type And Pin Configurations
FM25Q128AI3 is offered in an 8-pin SOP (208mil),an 8-pad TDFN (6x5mm) and a 24-ball BGA
(8x6mm) packages as shown in Figure 1-3 respectively. Package diagrams and dimensions are
illustrated at the end of this datasheet.
3.1.
Pin Configuration SOP8 (208-mil)
Top View
CS#
DO(DQ1)
WP#(DQ2)
VSS
1
2
8
7
3
4
6
5
VCC
HOLD#/RESET#
(DQ3)
CLK
DI(DQ0)
Figure 1 FM25Q128AI3 pin assignments, 8-pin SOP(208mil)
3.2.
Pin Configuration TDFN8 (6x5mm)
Top View
CS# 1
DO(DQ1) 2
WP#(DQ2)
3
VSS 4
8 VCC
HOLD#/RESET#
7
(DQ3)
6 CLK
5 DI(DQ0)
Figure 2 FM25Q128AI3 pad assignments, 8-pad TDFN(6x5mm)
3.3.
Ball Configuration BGA24 (8x6mm) (6x4 Ball Array)
V1.0
Datasheet
4
Top View
A1
A2
A3
A4
NC
NC
NC
NC
B1
B2
B3
B4
NC
CLK
VSS
VCC
C1
C2
C3
C4
NC
CS#
NC
D1
D2
D3
NC
DO(DQ1)
E1
E2
E3
E4
NC
NC
NC
NC
F1
F2
F3
F4
NC
NC
NC
NC
WP#(DQ2)
D4
DI(DQ0) HOLD#/RESET#
(DQ3)
Figure 3 FM25Q128AI3 pad assignments, 24-ball BGA (8x6mm)
3.4.
Pin Configuration
PIN NAME
CLK
VSS
VCC
CS#
WP# (DQ2)
DO (DQ1)
DI (DQ0)
HOLD#/RESET# (DQ3)
NC
I/O
FUNCTION
I Serial Clock Input
Ground
Power Supply
I Chip Select Input
I/O Write Protect Input (Data Input Output 2)(2)
I/O Data Output (Data Input Output 1)(1)
I/O Data Input (Data Input Output 0)(1)
I/O Hold Input (Data Input Output 3)(2)
No connect
Note:
1 DQ0 and DQ1 are used for Dual SPI instructions.
2 DQ0 – DQ3 are used for Quad SPI and QPI instructions
3 WP#(DQ2), HOLD#/RESET#(DQ3) will remain internal pull up function while this pin is not physically
connected in system confguration. However, the internal pull up function will be disabled if the system has
physical connection to WP#(DQ2) or HOLD#/RESET#(DQ3).
V1.0
Datasheet
5
4.
Pin Descriptions
4.1.
Chip Select (CS#)
The SPI Chip Select (CS#) pin enables and disables device operation. When CS# is high, the
device is deselected and the Serial Data Output (DO, or DQ0, DQ1, DQ2, DQ3) pins are at high
impedance. When deselected, the devices power consumption will be at standby levels unless
an internal erase, program or write status register cycle is in progress. When CS# is brought low,
the device will be selected, power consumption will increase to active levels and instructions can
be written to and data read from the device. After power-up, CS# must transition from high to low
before a new instruction will be accepted. The CS# input must track the VCC supply level at
power-up (see “8 Write Protection” and Figure 81). If needed a pull-up resister on CS# can be
used to accomplish this.
4.2.
Serial Data Input, Output and I/Os (DI, DO and DQ0, DQ1,
DQ2, DQ3)
The FM25Q128AI3 supports standard SPI, Dual SPI, Quad SPI and QPI operation. Standard
SPI instructions use the unidirectional DI (input) pin to serially write instructions, addresses or
data to the device on the rising edge of the Serial Clock (CLK) input pin. Standard SPI also uses
the unidirectional DO (output) to read data or status from the device on the falling edge of CLK.
Dual/Quad SPI and QPI instructions use the bidirectional DQ pins to serially write instructions,
addresses or data to the device on the rising edge of CLK and read data or status from the
device on the falling edge of CLK. Quad SPI and QPI instructions require the non-volatile Quad
Enable bit (QE) in Status Register-2 to be set. When QE=1, the WP# pin becomes DQ2 and
HOLD# pin becomes DQ3.
4.3.
Write Protect (WP#)
The Write Protect (WP#) pin can be used to prevent the Status Registers from being written. The
WP# pin is active low. However, when the QE bit of Status Register-2 is set for Quad I/O, the
WP# pin function is not available since this pin is used for DQ2.
4.4.
HOLD (HOLD#)
The HOLD# pin allows the device to be paused while it is actively selected. When HOLD# is
brought low, while CS# is low, the DO pin will be at high impedance and signals on the DI and
CLK pins will be ignored (don’t care). When HOLD# is brought high, device operation can resume.
The HOLD# function can be useful when multiple devices are sharing the same SPI signals. The
HOLD# pin is active low. When the QE bit of Status Register-2 is set for Quad I/O, the HOLD# pin
function is not available since this pin is used for DQ3.
4.5.
Serial Clock (CLK)
The SPI Serial Clock Input (CLK) pin provides the timing for serial input and output operations.
4.6.
Reset(RESET#)
The RESET# pin allows the device to be reset by the controller. For 8-pin packages, when QE=0, the
DQ3 pin can be configured either as a HOLD# pin or as a RESET# pin depending on Status Register
setting.
When QE=1, the HOLD# or RESET# function is not available.
V1.0
Datasheet
6
5.
Block Diagram
Address
Generator
r
e
d
o
c
e
D
r X
e
d
o
c
e
D
HV Generator
Memory
Array
ic
g
lo
t
u
tp HOLD/RESET#
u
(DQ3)
O
l
ia
r
e WP#(DQ )
2
S
Y
WP#
CS#
c
i
g
o
L
t
u
p
n
Il
ia
r
e
S
Y-Gating
DO(DQ1)
CLK
DI
SRAM
DI(DQ0)
Sense
Amplifier
DO
HOLD/R
ESET#
Clock
Generator
State Machine
Figure 4 FM25Q128AI3 Serial Flash Memory Block Diagram
V1.0
Datasheet
7
6.
Memory Organization
The FM25Q128AI3 array is organized into 65,536 programmable pages of 256-bytes each. Up
to 256 bytes can be programmed (bits are programmed from 1 to 0) at a time. Pages can be
erased in groups of 16 (4KB sector erase), groups of 128 (32KB block erase), groups of 256
(64KB block erase) or the entire chip (chip erase). The FM25Q128AI3 has 4,096 erasable
sectors, 512 erasable 32-k byte blocks and 256 erasable 64-k byte blocks respectively. The
small 4KB sectors allow for greater flexibility in applications that require data and parameter
storage.
Table 1
Block
(64KB)
255
Block
(32KB)
511
510
248
497
496
15
31
30
8
7
2
1
16
15
14
5
4
3
2
1
Memory Organization
Sector
(4KB)
4095
4080
3983
3968
255
240
143
128
127
112
47
32
31
16
15
2
1
Address Range
FFF000h
FF0000h
F8F000h
F80000h
0FF000h
0F0000h
08F000h
080000h
07F000h
070000h
02F000h
020000h
01F000h
010000h
00F000h
002000h
001000h
000000h
V1.0
FFFFFFh
FF0FFFh
F8FFFFh
F80FFFh
0FFFFFh
0F0FFFh
08FFFFh
080FFFh
07FFFFh
070FFFh
02FFFFh
020FFFh
01FFFFh
010FFFh
00FFFFh
002FFFh
001FFFh
000FFFh
Datasheet
8
V1.0
Datasheet
9
7.
Device Operations
Power On
Reset (66h + 99h)/
Hardware Reset
Reset (66h + 99h)/
Hardware Reset
Device
Initialization
Standard SPI
Dual SPI
Quad SPI
operations
Enable QPI (38h)
Disable QPI (FFh)
QPI
operations
Figure 5 FM25Q128AI3 Serial Flash Memory Operation Diagram
7.1.
Standard SPI
The FM25Q128AI3 is accessed through an SPI compatible bus consisting of four signals: Serial
Clock (CLK), Chip Select (CS#), Serial Data Input (DI) and Serial Data Output (DO). Standard
SPI instructions use the DI input pin to serially write instructions, addresses or data to the device.
The DO output pin is used to read data or status from the device.
Commands, write instructions, addresses or data are latched on the rising edge of CLK, read
data or status are available on the falling edge of CLK.
SPI bus operation Mode 0 (0,0) and 3 (1,1) are supported. The primary difference between
Mode 0 and Mode 3 concerns the normal state of the CLK signal when the SPI bus master is in
standby and data is not being transferred to the Serial Flash. For Mode 0, the CLK signal is
normally low on the falling and rising edges of CS#. For Mode 3, the CLK signal is normally high
CS#
CLK
MODE3
MODE3
MODE0
MODE0
DI
DO
DONT CARE
Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0
MSB
HIGH IMPEDANCE
MSB
Figure 6 The difference between Mode 0 and Mode 3
7.2.
Dual SPI
The FM25Q128AI3 supports Dual SPI operation when using instructions such as “Fast Read
Dual Output (3Bh)” , “Fast Read Dual I/O (BBh)”. These instructions allow data to be transferred
to or from the device at two to three times the rate of ordinary Serial Flash devices. The Dual SPI
Read instructions are ideal for quickly downloading code to RAM upon power-up (codeshadowing) or for executing non-speed- critical code directly from the SPI bus (XIP). When using
Dual SPI instructions, the DI and DO pins become bidirectional I/O pins: DQ0 and DQ1.
V1.0
Datasheet
10
7.3.
Quad SPI
The FM25Q128AI3 supports Quad SPI operation when using instructions such as “Fast Read Quad
Output (6Bh)”, “Fast Read Quad I/O (EBh)”, “Word Read Quad I/O (E7h)”, “Octal Word Read Quad
I/O (E3h)”. These instructions allow data to be transferred to or from the device four to six times the
rate of ordinary Serial Flash. The Quad Read instructions offer a significant improvement in
continuous and random access transfer rates allowing fast code-shadowing to RAM or execution
directly from the SPI bus (XIP). When using Quad SPI instructions the DI and DO pins become
bidirectional DQ0 and DQ1 and the WP # and HOLD# pins become DQ2 and DQ3 respectively. Quad
SPI instructions require the non-volatile Quad Enable bit (QE) in Status Register-2 to be set.
7.4.
QPI
The FM25Q128AI3 supports Quad Peripheral Interface (QPI) operations only when the device is
switched from Standard/Dual/Quad SPI mode to QPI mode using the “Enable QPI (38h)” instruction.
The typical SPI protocol requires that the byte-long instruction code being shifted into the device only
via DI pin in eight serial clocks. The QPI mode utilizes all four DQ pins to input the instruction code,
thus only two serial clocks are required. This can significantly reduce the SPI instruction overhead
and improve system performance in an XIP environment. Standard/Dual/Quad SPI mode and QPI
mode are exclusive. Only one mode can be active at any given time. “Enable QPI (38h)” and
“Disable QPI (FFh)” instructions are used to switch between these two modes. Upon power-up or
after a software reset using “Reset (99h)” instruction or hardware reset, the default state of the device
is Standard/Dual/Quad SPI mode. To enable QPI mode, the non-volatile Quad Enable bit (QE) in
Status Register-2 is required to be set. When using QPI instructions, the DI and DO pins become
bidirectional DQ0 and DQ1, and the WP# and HOLD# pins become DQ2 and DQ3 respectively. See
Figure 5 for the device operation modes.
7.5.
Hold
For Standard SPI and Dual SPI operations, the HOLD# signal allows the FM25Q128AI3
operation to be paused while it is actively selected (when CS# is low). The HOLD# function may
be useful in cases where the SPI data and clock signals are shared with other devices. For
example, consider if the page buffer was only partially written when a priority interrupt requires
use of the SPI bus. In this case the HOLD# function can save the state of the instruction and the
data in the buffer so programming can resume where it left off once the bus is available again.
The HOLD# function is only available for standard SPI and Dual SPI operation, not during Quad
SPI or QPI.
To initiate a HOLD# condition, the device must be selected with CS# low. A HOLD# condition
will activate on the falling edge of the HOLD# signal if the CLK signal is already low. If the CLK is
not already low the HOLD# condition will activate after the next falling edge of CLK. The HOLD#
condition will terminate on the rising edge of the HOLD# signal if the CLK signal is already low. If
the CLK is not already low the HOLD# condition will terminate after the next falling edge of CLK.
During a HOLD# condition, the Serial Data Output (DO) is high impedance, and Serial Data
Input (DI) and Serial Clock (CLK) are ignored. The Chip Select (CS#) signal should be kept
active (low) for the full duration of the HOLD# operation to avoid resetting the internal logic state
of the device.
Active
Hold
Active
V1.0
Hold
Active
Datasheet
11
Figure 7 Hold Condition Waveform
7.6.
Software Reset & Hardware Reset
The FM25Q128AI3 can be reset to the initial power-on sate by a Software Reset sequence,
either in SPI or QPI mode. This sequence must include two consecutive commands: Enable
Reset (66h) & Reset (99h). No command will be accepted during the reset period.
FM25Q128AI3 can also be configured to utilize a hardware RESET# pin. The HOLD/RST bit in
the Status Register-2 is the configuration bit for HOLD# pin function or RESET# pin function.
When HOLD/RST=0 (factory default), the pin acts as a HOLD# pin as described above; when
HOLD/RST=1, the pin acts as a RESET# pin. Drive the RESET# pin low for a minimum period of
~1us will reset the device to its initial power-on state. Any on-going Program/Erase operation will
be interrupted and data corruption may happen. While RESET# is low, the device will not accept
any command input.
If QE bit is set to 1, the HOLD# or RESET# function will be disabled, the pin will become one of
the four data I/O pins.
Hardware RESET# pin has the highest priority among all the input signals. Drive RESET# low
for a minimum period of ~1us will interrupt any on-going external/internal operations, regardless
the status of other SPI signals (CS#, CLK, DI, DO, WP# and/or HOLD#).
Note:
1. While a faster RESET# pulse (as short as a few hundred nanoseconds) will often reset the
device, a 1us minimum time is recommended to ensure reliable operation.
2. Data corruption may happen if there is an on-going or suspended internal Erase or
Program operation when software/hardware reset is accepted by the device. It is
recommended to check the WIP bit and the SUS bit in Status Register before issuing the
software reset command or hardware reset.
V1.0
Datasheet
12
8.
Write Protection
Applications that use non-volatile memory must take into consideration the possibility of noise
and other adverse system conditions that may compromise data integrity. To address this
concern, the FM25Q128AI3 provides several means to protect the data from inadvertent writes.
Write Protect Features
Device resets when VCC is below threshold during WRITE operation
Time delay write disable after Power-up
Write enable/disable instructions and automatic write disable after erase or program
Software and Hardware (WP# pin) write protection using Status Register
Advanced Sector Protection
Write Protection using Power-down instruction
Lock Down write protection for Status Register until the next power-up
One Time Program (OTP) write-protection for array and Security Sectors using Status Register.
At power-up and power-down, the device must not be selected; that is, CS# must follow the voltage
applied on VCC until VCC reaches the correct values: VCC (min) at power-up and Vss at power-down.
To avoid data corruption and inadvertent WRITE operations during power-up, a power-on reset
circuit is included. The logic inside the device is held to RESET while VCC is less than the poweron reset threshold voltage of VCC (low); all operations are disabled, and the device does not
respond to any instruction. During a standard power-up phase, the device ignores all commands.
After power-up, the device is in standby power mode.
In the event Power-on Reset (POR) did not complete correctly after power up, the assertion of the
RESET# signal or receiving a software reset command (RESET) will restart the POR process.
At power-down, when VCC drops from the operating voltage to below the threshold voltage VCC
(low), all operations are disabled and the device does not respond to any command.
Note: If power-down occurs while a WRITE, PROGRAM, or ERASE cycle is in progress, data
corruption may result.
Software controlled write protection is facilitated using the Write Status Register instruction and
setting the Status Register Protect (SRP0, SRP1) and Block Protect (CMP, SEC, TB, BP[3:0])
bits. These settings allow a portion as small as a 4KB sector or the entire memory array to be
configured as read only. Used in conjunction with the Write Protect (WP#) pin, changes to the
Status Register can be enabled or disabled under hardware control. See Status Register section
for further information. Additionally, the Power-down instruction offers an extra level of write
protection as all instructions are ignored except for the Release Power-down instruction.
The FM25Q128AI3 also provides another Write Protect method using the individual Block Locks.
Each 64KB block (except the top and bottom blocks, total of 254 blocks) and each 4KB sector
within the top/bottom blocks (total of 32 sectors) are equipped with an Individual Block Lock bit.
When the lock bit is 0, the corresponding sector or block can be erased or programmed; when
the lock bit is set to 1, Erase or Program commands issued to the corresponding sector or block
will be ignored. When the device is powered on, all individual Block Lock bits will be 1, so the
entire memory array is protected from Erase/Program. An “Individual Block Unlock (39h)”
instruction must be issued to unlock any specific sector or block.
The WPS bit in Status Register-2 is used to decide which Write Protect scheme should be used.
When WPS=0(factory default), the device will only utilize CMP,SEC,TB, BP[2:0] to protect specific
areas of the array; when WPS=1, the device will utilize the Individual Block Locks for write protection,
each protect scheme for the corresponding is available.
V1.0
Datasheet
13
9.
Status Register
Three Status Registers are provided for FM25Q128AI3. The Read Status Register-1/2/3
instructions can be used to provide status on the availability of the Flash memory array, whether
the device is write enabled or disabled, the state of write protection, Quad SPI setting, Security
Sector lock status, Erase/Program Suspend status and output driver strength. The Write Status
Register instruction can be used to configure the device write protection features, Quad SPI
setting, Security Sector OTP lock, Hold/RESET functions and output driver strength. Write
access to the Status Register is controlled by the state of the non-volatile Status Register Protect
bits (SRP0, SRP1), the Write Enable instruction, and during Standard/Dual SPI operations, the
WP# pin.
Factory default for all Status Register bits are 0.
9.1.
Status Register-1(SR1)
Related Commands: Read Status Register (RDSR1 05h), Write Status Register (WRSR 01h),
Write Enable (WREN 06h), Write Disable (WRDI 04h), Write Enable for Volatile Status Register
(50h).
S7
S6
SRP0 SEC
S5
S4
S3
S2
S1
S0
TB
BP2
BP1
BP0
WEL
WIP
STATUS REGISTER PROTECT 0
(Volatile/Non-Volatile writable)
SECTOR PROTECT BIT
should be set to 0)
TOP/BOTTOM PROTECT
BLOCK PROTECT BITS
WRITE ENABLE LATCH
ERASE/WRITE IN PROGRESS
Figure 8 Status Register-1
9.1.1.
Write In Progress (WIP)
WIP is a read only bit in the status register (S0) that is set to a 1 state when the device is
executing a Page Program, Quad Page Program, Sector Erase, Block Erase, Chip Erase, Write
Status Register or Erase/Program Security Sector instruction. During this time the device will
ignore further instructions except for the Read Status Register and Erase/Program Suspend
instruction (see tW, tPP, tSE, tBE, and tCE in “11.6 AC Electrical Characteristics”). When the
program, erase or write status register (or security sector) instruction has completed, the WIP bit
will be cleared to a 0 state indicating the device is ready for further instructions.
V1.0
Datasheet
14
9.1.2.
Write Enable Latch (WEL)
Write Enable Latch (WEL) is a read only bit in the status register (S1) that is set to 1 after
executing a Write Enable Instruction. The WEL status bit is cleared to 0 when the device is write
disabled. A write disable state occurs upon power-up or after any of the following instructions:
Write Disable, Page Program, Quad Page Program, Sector Erase, Block Erase, Chip Erase,
Write Status Register, Erase Security Sector and Program Security Sector.
9.1.3.
Block Protect Bits (BP2, BP1, BP0)
The Block Protect Bits (BP2, BP1, BP0) are non-volatile read/write bits in the status register that
provide Write Protection control and status. Block Protect bits can be set using the Write Status
Register Instruction (see tW in “11.6 AC Electrical Characteristics”). All, none or a portion of the
memory array can be protected from Program and Erase instructions (see Status Register Memory
Protection). The factory default setting for the Block Protection Bits is 0, none of the array protected.
9.1.4.
Top/Bottom Block Protect (TB)
The non-volatile Top/Bottom bit (TB) controls if the Block Protect Bits (BP2, BP1, BP0) protect
from the Top (TB=0) or the Bottom (TB=1) of the array as shown in Status Register Memory
Protection table. The factory default setting is TB=0. The TB bit can be set with the Write Status
Register Instruction depending on the state of the SRP0, SRP1 and WEL bits.
9.1.5.
Sector/Block Protect (SEC)
The non-volatile Sector/Block Protect bit (SEC) should be set to 0. The factory default setting is
SEC=0.
9.2.
Status Register-2 (SR2)
Related Commands: Read Status Register-2 (RDSR2 35h), Write Status Register-2 (WRSR2
31h), Write Enable (WREN 06h), Write Disable (WRDI 04h), Write Enable for Volatile Status
Register (50h).
S15
HOLD or RESET function
(Volatile/Non-Volatile Writable)
COMPLEMENT PROTECT
S14
S13
S12
S11
HOLD
DRV DRV
WPS
CMP
/RST
1
S10
S9
S8
LB
QE
SRP1
OUTPUT DRIVE STRENGTH
WRITE PROTECT SELECTION
SECURITY REGISTER LOCK BIT
QUAD ENABLE
STATUS REGISTER PROTECT 1
Figure 9 Status Register-2
V1.0
Datasheet
15
9.2.1.
Status Register Protect (SRP1, SRP0)
The Status Register Protect bits (SRP1 and SRP0) are non-volatile read/write bits in the status
register (S8 and S7). The SRP bits control the method of write protection: software protection,
hardware protection, power supply lock-down or one time programmable (OTP) protection.
Table 2
SRP1 SRP0 WP#
X
1
1
X
1
1
X
Status
Register
Description
WP# pin has no control. The Status register can be
written to after a Write Enable instruction, WEL=1.
(Factory Default)
Hardware
When WP# pin is low the Status Register locked and can
Protected
not be written to.
Hardware
When WP# pin is high the Status register is unlocked and
Unprotected can be written to after a Write Enable instruction, WEL=1.
Power Supply Status Register is protected and can not be written to
Lock-Down again until the next power-down, power-up cycle.(1)
One Time Status Register is permanently protected and can not be
Program
written to.
Software
Protection
Note:
1. When SRP1, SRP0 = (1, 0), a power-down, power-up cycle will change SRP1, SRP0 to (0, 0)
state.
9.2.2.
HOLD# or RESET# pin function(HOLD/RST)
The HOLD/RST bit is used to determine whether HOLD# or RESET# function should be
implemented on the hardware pin for 8-pin packages. When HOLD/RST=0 (factory default), the
pin acts as HOLD#; when HOLD/RST=1, the pin acts as RESET#. However, HOLD# or RESET#
functions are only available when QE=0. If QE is set to 1, the HOLD# and RESET# functions are
disabled, the pin acts as a dedicated data I/O pin.
9.2.3.
Complement Protect (CMP)
The Complement Protect bit (CMP) is a non-volatile read/write bit in the status register (S14). It is
used in conjunction with SEC, TB, BP[2:0] bits to provide more flexibility for the array protection.
Once CMP is set to 1, previous array protection set by SEC, TB, BP2, BP1 and BP0 will be
reversed. For instance, when CMP=0, a top 4KB sector can be protected while the rest of the
array is not; when CMP=1, the top 4KB sector will become unprotected while the rest of the array
become read-only. Please refer to Status Register Memory Protection table for details. The
default setting is CMP=0.
9.2.4.
Write Protect Selection (WPS)
The WPS bit is used to select which Write Protect scheme should be used. When WPS=0, the
device will use the combination of CMP, TB, SEC, BP[2:0] to protect a specific area of the
memory array. When WPS=1, the device will utilize the Individual Block Locks to protect any
individual sector or blocks. The default value for all Individual Block Lock bits is 1 upon device
power on or after reset.
9.2.5.
Output driver strength (DRV1, DRV0)
The DRV1 & DRV0 bits are used to determine the output driver strength.
V1.0
Datasheet
16
Table 3 Driver strength configuration
DRV1, DRV0
0,0
0,1
1,0
1,1
9.2.6.
Driver Strength
100%
75%
50%
25%
Security Sector Lock Bit (LB)
The Security Register Lock Bit (LB) is non-volatile One Time Program (OTP) bits in Status
Register (S10) that provide the write protect control and status to the Security Registers. The
default state of LB is 0, Security Registers are unlocked. LB can be set to 1 individually using the
Write Status Register instruction. LB is One Time Programmable (OTP), once it’s set to 1, the
corresponding 1024-Byte Security Register will become read-only permanently.
9.2.7.
Quad Enable (QE)
The Quad Enable (QE) bit is a non-volatile read/write bit in the status register (S9) that allows
Quad SPI and QPI operation. When the QE bit is set to a 0 state (factory default), the WP# pin
and HOLD# are enabled. When the QE bit is set to a 1, the Quad DQ2 and DQ3 pins are enabled,
and WP# and HOLD# functions are disabled.
QE bit is required to be set to a 1 before issuing an “Enable QPI (38h)” to switch the device from
Standard/Dual/Quad SPI to QPI; otherwise the command will be ignored. When the device is in
QPI mode, QE bit will remain to be 1. A “Write Status Register” command in QPI mode cannot
change QE bit from a 1 to a 0.
WARNING: If the WP# or HOLD# pins are tied directly to the power supply or ground
during standard SPI or Dual SPI operation, the QE bit should never be set to a 1.
9.3.
Status Register-3 (SR3)
Related Commands: Read Status Register-3 (RDSR3 15h), Write Enable (06h). Write Enable
(06h) can be used to clear ERR bit of SR3 if ERR is set to 1 by the last operation.
S23
S22
S21
S20
S19
S18
S17
S16
SUS
RFU
RFU
RFU
ERR
RFU
RFU
RFU
SUSPEND STATUS
(Volatile, Read Only)
Reserved
Program/Erase Fail Bit
(Volatile,Read Only)
Reserved
Figure 10 Status Register-3
V1.0
Datasheet
17
9.3.1.
Erase/Program Suspend Status (SUS)
The Suspend Status bit is a read only bit in the status register (S23) that is set to 1 after
executing an Erase/Program Suspend (75h) instruction. The SUS status bit is cleared to 0 by
Erase/Program Resume (7Ah) instruction as well as a power-down, power-up cycle.
9.3.2.
Write Fail Bit (ERR)
The Write Fail bit is a status flag, which shows the status of last write operation. It will be set to 1,
if the program or erase or write status register operation fails. It is cleard to 0 by WREN (06h) or
Reset operation.
9.4.
Status Register Memory Protection (WPS=0, CMP=0)
Table 4
STATUS REGISTER
SEC
FM25Q128AI3 (128M-BIT) MEMORY PROTECTION
TB BP2 BP1 BP0
PROTECTED
BLOCK(S)
PROTECTED
ADDRESSES
PROTECTED PROTECTED
DENSITY
PORTION
X
X
NONE
NONE
NONE
NONE
252 thru 255
FC0000h – FFFFFFh
256KB
Upper 1/64
248 thru 255
F80000h – FFFFFFh
512KB
Upper 1/32
1
240 thru 255
F00000h – FFFFFFh
1MB
Upper 1/16
224 thru 255
E00000h – FFFFFFh
2MB
Upper 1/8
192 thru 255
C00000h – FFFFFFh
4MB
Upper 1/4
1
128 thru 255
800000h – FFFFFFh
8MB
Upper 1/2
0 thru 3
000000h – 03FFFFh
256KB
Lower 1/64
0 thru 7
000000h – 07FFFFh
512KB
Lower 1/32
1
0 thru 15
000000h – 0FFFFFh
1M
Lower 1/16
1
0 thru 31
000000h – 1FFFFFh
2MB
Lower 1/8
1
0 thru 63
000000h – 3FFFFFh
4MB
Lower 1/4
1
1
0 thru 127
000000h – 7FFFFFh
8MB
Lower 1/2
X
1
1
1
0 thru 255
000000h – FFFFFFh
16MB
ALL
1
255
FFF000h – FFFFFFh
4KB
Top Block
1
FFE000h – FFFFFFh
8KB
Top Block
1
1
255
FFC000h – FFFFFFh
16KB
Top Block
1
X
255
FF8000h – FFFFFFh
32KB
Top Block
1
1
FF8000h – FFFFFFh
32KB
Top Block
1
1
000000h – 000FFFh
4KB
Bottom Block
1
1
000000h – 001FFFh
8KB
Bottom Block
1
1
1
000000h – 003FFFh
16KB
Bottom Block
V1.0
Datasheet
18
STATUS REGISTER
SEC
9.5.
TB BP2 BP1 BP0
PROTECTED
BLOCK(S)
PROTECTED
ADDRESSES
PROTECTED PROTECTED
DENSITY
PORTION
1
1
1
X
000000h – 007FFFh
32KB
Bottom Block
1
1
1
1
000000h – 007FFFh
32KB
Bottom Block
Status Register Memory Protection (WPS=0, CMP=1)
Table 5
STATUS REGISTER
SEC
FM25LQ128 (128M-BIT) MEMORY PROTECTION
TB BP2 BP1 BP0
PROTECTED
BLOCK(S)
PROTECTED
ADDRESSES
PROTECTED PROTECTED
DENSITY
PORTION
X
0 to 255
000000h – FFFFFFh
ALL
ALL
0 to 255
000000h – FBFFFFh
16128KB
Lower 63/64
0 to 255
000000h – F7FFFFh
15872KB
Lower 31/32
1
0 to 255
000000h – EFFFFFh
15MB
Lower 15/16
0 to 255
000000h – DFFFFFh
14MB
Lower 7/8
0 to 255
000000h – BFFFFFh
12MB
Lower 3/4
1
0 to 255
000000h – 7FFFFFh
8MB
Lower 1/2
4 to 255
040000h – FFFFFFh
16128KB
Upper 63/64
8 to 255
080000h – FFFFFFh
15872KB
Upper 31/32
1
16 to 255
100000h – FFFFFFh
15MB
Upper 15/16
1
32 to 255
200000h – FFFFFFh
14MB
Upper 7/8
1
64 to 255
400000h – FFFFFFh
12MB
Upper 3/4
1
1
128 to 255
800000h – FFFFFFh
8MB
Upper 1/2
X
X
1
1
1
NONE
NONE
NONE
NONE
1
0 to 255
000000h – FFEFFFh
16380KB
L-4095/4096
1
0 to 255
000000h – FFDFFFh
16376KB
L-2047/2048
1
1
0 to 255
000000h – FFBFFFh
16368KB
L-1023/1024
1
X
0 to 255
000000h – FF7FFFh
16352KB
L-511/512
1
1
0 to 255
000000h – FF7FFFh
16352KB
L-511/512
1
1
0 to 255
001000h – FFFFFFh
16380KB
U-4095/4096
1
1
0 to 255
002000h – FFFFFFh
16376KB
U-2047/2048
1
1
1
0 to 255
004000h – FFFFFFh
16368KB
U-1023/1024
1
1
1
X
0 to 255
008000h – FFFFFFh
16352KB
U-511/512
1
1
1
1
0 to 255
001000h – FFFFFFh
16352KB
U-511/512
V1.0
Datasheet
19
Status Register Memory Protection (WPS=1)
Block 255
(64KB)
9.6.
Sector 15(4KB)
Sector 14(4KB)
Individual Block Locks:
32 Sectors(Top/Bottom)
254 Blocks
Sector 1(4KB)
Sector 0(4KB)
Individual Block Lock:
36h + Address
Block 254(64KB)
Individual Block Unlock:
39h + Address
Read Block Lock:
3Dh + Address
Block 0
(64KB)
Block 1(64KB)
Global Block Lock:
7Eh
Sector 15(4KB)
Sector 14(4KB)
Global Block Unlock:
98h
Sector 1(4KB)
Sector 0(4KB)
Figure 11 Individual Sector/Block Locks
V1.0
Datasheet
Instructions
The Standard/Dual/Quad SPI instruction set of the FM25Q128AI3 consists of 44 basic
instructions that are fully controlled through the SPI bus (see Table 7 ~ Table 10 Instruction Set).
Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked
into the DI input provides the instruction code. Data on the DI input is sampled on the rising edge
of clock with most significant bit (MSB) first.
The QPI instruction set of the FM25Q128AI3 consists of 30 basic instructions that are fully
controlled through the SPI bus (see Table 10 Instruction Set). Instructions are initiated with the
falling edge of Chip Select (CS#). The first byte of data clocked through DQ[3:0] pins provides
the instruction code. Data on all four DQ pins are sampled on the rising edge of clock with most
significant bit (MSB) first. All QPI instructions, addresses, data and dummy bytes are using all
four DQ pins to transfer every byte of data with every two serial clocks (CLK).
Instructions vary in length from a single byte to several bytes and may be followed by address
bytes, data bytes, dummy bytes (don’t care), and in some cases, a combination. Instructions are
completed with the rising edge of CS#. Clock relative timing diagrams for each instruction are
included in Figure 12 through Figure 85. All read instructions can be completed after any clocked
bit. However, all instructions that Write, Program or Erase must complete on a byte boundary
(CS# driven high after a full 8-bits have been clocked) otherwise the instruction will be ignored.
This feature further protects the device from inadvertent writes. Additionally, while the memory is
being programmed or erased, or when the Status Register is being written, all instructions
except for Read Status Register will be ignored until the program or erase cycle has completed.
10.1.
Device ID and Instruction Set Tables
10.1.1. Manufacture and Device Identification
Table 6
OP Code
ABh
90h, 92h, 94h
9Fh
Manufacturer and Device Identification
MF7-MF0
ID15-ID0
17h
17h
A1h
A1h
ID7-ID0
4018h
V1.0
Datasheet
21
10.1.2. Standard SPI Instructions Set
Table 7
Standard SPI Instructions Set (1)
CLOCK NUMBER
Write Enable
Volatile SR Write Enable
Write Disable
Write Status Register-1(3)
BYTE
1
(0-7)
06h
50h
04h
05h
01h
35h
31h
15h
Page Program
Sector Erase (4KB)
Block Erase (32KB)
Block Erase (64KB)
02h
20h
52h
D8h
C7h/60
h
75h
7Ah
B9h
03h
0Bh
INSTRUCTION NAME
Chip Erase
Erase / Program Suspend
Erase / Program Resume
Power-down
Read Data
Fast Read
BYTE 2
BYTE 3
BYTE 4
BYTE 5
BYTE 6
(8-15)
(16-23)
(24-31)
(32-39)
(40-47)
(S7-S0)(2)
(S7-S0) (3)
(S15-S8)(2)
(S15-S8)
(S23S16)(2)
A23-A16
A23-A16
A23-A16
A23-A16
A15-A8
A15-A8
A15-A8
A15-A8
A7-A0
A7-A0
A7-A0
A7-A0
D7-D0
D7-D0(4)
A23-A16
A23-A16
A15-A8
A15-A8
A7-A0
A7-A0
(D7-D0)
dummy
(ID7ID0)(2)
(MF7MF0)
(5)
ABh
dummy
dummy
Dummy
Manufacturer/Device ID(5)(6)
90h
dummy
dummy
00h
(ID15ID8)
Memory
Type
00h
(ID7ID0)
Capacit
y
A7-A0
dummy
dummy
Release Powerdown / ID
(D7-D0)
(ID7-ID0)
Read SFDP Register
5Ah
(MF7MF0)
Manufactur
er
00h
Read Unique ID(6)
4Bh
dummy
dummy
dummy
44h
A23-A16
A15-A8
A7-A0
42h
A23-A16
A15-A8
A7-A0
D7-D0
D7-D0
48h
A23-A16
A15-A8
A7-A0
dummy
(D7-D0)
38h
66h
99h
36h
39h
3Dh
7Eh
98h
A23-A16
A23-A16
A23-A16
A23-A16
A23-A16
A15-A8
A15-A8
A15-A8
A15-A8
A15-A8
A7-A0
A7-A0
A7-A0
A7-A0
A7-A0
JEDEC ID
(6)
Erase
Security Sectors(7)
Program
Security Sectors(7)
Read
Security Sectors(7)
Enable QPI
Enable Reset
Reset
Read Block Lock
Global Block Lock
Global Block Unlock
9Fh
V1.0
(D7-D0)
(UID63UID0)
Datasheet
22
10.1.3. Dual SPI Instructions Set
Table 8
INSTRUCTION NAME BYTE 1
BYTE 2
BYTE 3
BYTE 4
BYTE 5
BYTE 6
(40-47)
(D7D0, …)(9)
CLOCK NUMBER
(0-7)
(8-15)
(16-23)
(24-31)
(32-39)
Fast Read Dual Output
3Bh
A23-A16
A15-A8
A7-A0
Dummy
Fast Read Dual I/O
BBh
A23-A8(8)
A7-A0,
M7-M0 (8)
Dummy
by
Dual I/O(5)(6)
92h
A23-A8(8)
A7-A0,
M7-M0(8)
(MF7-MF0,
ID7-ID0)
(D7-D0, …)(9)
10.1.4. Quad SPI Instructions Set
Table 9
CLOCK NUMBER
BYTE
1
(0-7)
Quad Page Program
32h
A23-A16
A15-A8
A7-A0
Fast Read Quad
Output
6Bh
A23-A16
A15-A8
A7-A0
Fast Read Quad I/O
EBh
Dummy
(D7D0, …)(11)
Word Read Quad
I/O(12)
E7h
Dummy
(D7D0, …)(11)
Octal Word Read
Quad I/O(13)
E3h
Dummy
(D7D0, …)(11)
Set Burst with Wrap
77h
Manufacture/Device ID
by
Quad I/O(5)(6)
94h
xxxx,
(MF7-MF0,
ID7-ID0)
(MF7-MF0,
ID7ID0, …)
INSTRUCTION NAME
BYTE 2
BYTE 3
BYTE 4
BYTE 5
BYTE 6
(8-15)
(16-23)
(24-31)
(32-39)
D7D0, …(11)
(40-47)
D7D0, …(11)
(D7D0, …)(11)
A23-A0,
M7M0(10)
A23-A0,
M7M0(10)
A23-A0,
M7M0(10)
xxxxx,
W6W4(10)
A23-A0,
M7M0(10)
Dummy
10.1.5. QPI Instructions Set
Table 10 QPI Instructions Set (14)
INSTRUCTION NAME
BYTE 1
BYTE 2
BYTE 3
BYTE 4
BYTE 5
BYTE 6
CLOCK NUMBER
Write Enable
Write Disable
(0,1)
06h
50h
04h
(2,3)
(4,5)
(6,7)
(8,9)
(10,11)
05h
01h
(S7S0)(2)
(S7-S0)
(3)
V1.0
Datasheet
23
INSTRUCTION NAME
BYTE 1
35h
31h
15h
BYTE 2
(S15S8)(2)
(S15-S8)
(S23S16)(2)
BYTE 3
BYTE 4
Power-down
Set Read Parameters
Enable Reset
Reset
Disable QPI
Fast Read
Burst Read with Wrap
Fast Read Quad I/O(16)
C7h/60
h
75h
7Ah
B9h
C0h
66h
99h
FFh
0Bh
0Ch
EBh
A23-A16
A23-A16
A23-A16
A15-A8
A15-A8
A15-A8
A7-A0
A7-A0
A7-A0
Release Powerdown / ID(5)
ABh
dummy
dummy
dummy
90h
dummy
dummy
00h
(5)(6)
9Fh
(MF7MF0)
Manufac
turer
(ID15ID8)
Memory
Type
(ID7ID0)
Capacit
y
Page Program
02h
A23-A16
A15-A8
A7-A0
Sector Erase (4KB)
Block Erase (32KB)
Block Erase (64KB)
Read Block Lock
Global Block Lock
Global Block Unlock
20h
52h
D8h
36h
39h
3Dh
7Eh
98h
A23-A16
A23-A16
A23-A16
A23-A16
A23-A16
A23-A16
A23-A16
A23-A16
A15-A8
A15-A8
A15-A8
A15-A8
A15-A8
A15-A8
A15-A8
A15-A8
A7-A0
A7-A0
A7-A0
A7-A0
A7-A0
A7-A0
A7-A0
A7-A0
Chip Erase
JEDEC ID
BYTE 5
BYTE 6
P7-P0
dummy(15)
dummy(15)
M7-M0(15)
(ID7ID0)(2)
(MF7MF0)
D7D0(11)
(D7-D0)
(D7-D0)
(D7-D0)
(ID7-ID0)
D7-D0(4)
(D7-D0) (2)
Notes:
1. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “( )”
indicate data output from the device on either 1, 2 or 4 DQ pins.
2. The Status Register contents and Device ID will repeat continuously until CS# terminates the
instruction.
3. Write Status Register-1(01h) can also be used to program Status Register-1&2, see section
10.2.5
4. At least one byte of data input is required for Page Program, Quad Page Program and
Program Security Sectors, up to 256 bytes of data input. If more than 256 bytes of data are
sent to the device, the addressing will wrap to the beginning of the page and overwrite
previously sent data.
5. See Table 6 Manufacturer and Device Identification table for device ID information.
6. Please contact Shanghai Fudan Microelectronics Group Co., Ltd for details.
7. Security Sector Address:
Security Sector 0: A23-A16 = 00h; A15-A8 = 00h; A7-A0 = byte address
Security Sector 1: A23-A16 = 00h; A15-A8 = 01h; A7-A0 = byte address
V1.0
Datasheet
24
8.
9.
10.
11.
12.
13.
14.
Security Sector 2: A23-A16 = 00h; A15-A8 = 10h; A7-A0 = byte address
Security Sector 3: A23-A16 = 00h; A15-A8 = 11h; A7-A0 = byte address
Dual SPI address input format:
DQ0 = A22, A20, A18, A16, A14, A12, A10, A8 A6, A4, A2, A0, M6, M4, M2, M0
DQ1 = A23, A21, A19, A17, A15, A13, A11, A9 A7, A5, A3, A1, M7, M5, M3, M1
Dual SPI data output format:
DQ0 = (D6, D4, D2, D0)
DQ1 = (D7, D5, D3, D1)
Quad SPI address input format:
Set Burst with Wrap input format:
DQ0 = A20, A16, A12, A8, A4, A0, M4, M0
DQ0 = x, x, x, x, x, x, W4, x
DQ1 = A21, A17, A13, A9, A5, A1, M5, M1
DQ1 = x, x, x, x, x, x, W5, x
DQ2 = A22, A18, A14, A10, A6, A2, M6, M2
DQ2 = x, x, x, x, x, x, W6, x
DQ3 = A23, A19, A15, A11, A7, A3, M7, M3
DQ3 = x, x, x, x, x, x, x, x
Quad SPI data input/output format:
DQ0 = (D4, D0 …)
DQ1 = (D5, D1…)
DQ2 = (D6, D2…)
DQ3 = (D7, D3…)
For Word Read Quad I/O, the lowest address bit must be 0. (A0 = 0)
For Octal Word Read Quad I/O, the lowest four address bits must be 0. (A3, A2, A1, A0 = 0)
QPI Command Address, Data input/output format:
CLK#
2
3
4
5
6
7
8
9
10
11
DQ0
C4
C0
A20 A16 A12
A8
A4
A0
D4
D0
D4
D0
DQ1
C5
C1
A21 A17 A13
A9
A5
A1
D5
D1
D5
D1
DQ2
C6
C2
A22 A18 A14 A10
A6
A2
D6
D2
D6
D2
DQ3
C7
C3
A23 A19 A15 A11
A7
A3
D7
D3
D7
D3
15. The number of dummy clocks is controlled by read parameter P6-P4.
16. The wrap around length for QPI Burst Read with Wrap is controlled by read parameter P1-P0
V1.0
Datasheet
25
10.2.
Instruction Description
10.2.1. Write Enable (WREN) (06h)
The Write Enable (WREN) instruction (Figure 12) sets the Write Enable Latch (WEL) bit in the
Status Register to a 1. The WEL bit must be set prior to every Page Program, Quad Page
Program, Sector Erase, Block Erase, Chip Erase, Write Status Register , Erase/Program
Security Sectors and Block/Sector Lock/Unlock instruction. The Write Enable (WREN)
instruction is entered by driving CS# low, shifting the instruction code “06h” into the Data Input
(DI) pin on the rising edge of CLK, and then driving CS# high.
CS#
CS#
Mode 3
CLK
Mode 3
CLK
2
3
4
5
6
7
Mode 0
Mode 3
Mode 0
Mode 3
Mode 0
Instruction
(06h)
Mode 0
DQ0
Instruction (06h)
DI
(DQ0)
DQ1
DQ2
High Impedance
D0
(DQ1)
DQ3
Figure 12 Write Enable Instruction for SPI Mode (left) or QPI Mode (right)
10.2.2. Write Enable for Volatile Status Register (50h)
The non-volatile Status Register bits described in section 9.1, 9.2, 9.3 can also be written to as
volatile bits. This gives more flexibility to change the system configuration and memory
protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting
the endurance of the Status Register non-volatile bits. To write the volatile values into the Status
Register bits, the Write Enable for Volatile Status Register (50h) instruction must be issued prior
to a Write Status Register (01h) instruction. Write Enable for Volatile Status Register instruction
(Figure 13) will not set the Write Enable Latch (WEL) bit, it is only valid for the Write Status
Register instruction to change the volatile Status Register bit values.
CS#
CS#
Mode 3
CLK
Mode 3
CLK
2
3
4
5
Mode 0
6
7
Mode 3
Mode 0
Mode 0
Mode 3
Mode 0
Instruction(
50h)
DQ0
Instruction (50h)
DI
(DQ0)
DQ1
DQ2
D0
(DQ1)
High Impedance
DQ3
Figure 13 Write Enable for Volatile Status Register Instruction for SPI Mode (left) or QPI
Mode (right)
V1.0
Datasheet
26
10.2.3. Write Disable (WRDI) (04h)
The Write Disable (WRDI) instruction (Figure 14) resets the Write Enable Latch (WEL) bit in the
Status Register to a 0. The Write Disable (WRDI) instruction is entered by driving CS# low,
shifting the instruction code “04h” into the DI pin and then driving CS# high. Note that the WEL
bit is automatically reset after Power-up and upon completion of the Write Status Register,
Erase/Program Security Sectors, Page Program, Quad Page Program, Sector Erase, Block
Erase, Chip Erase , Block/Sector Lock/Unlock and Reset instructions.
CS#
CS#
Mode 3
CLK
Mode 3
CLK
2
3
4
5
6
7
Mode 3
Mode 0
Mode 3
1
Mode 0
Mode 0
Instruction
(04h)
Mode 0
DQ0
Instruction (04h)
DI
(DQ0)
DQ1
DQ2
High Impedance
D0
(DQ1)
DQ3
Figure 14 Write Disable Instruction for SPI Mode (left) or QPI Mode (right)
10.2.4. Read Status Register-1 (RDSR1) (05h), Status Register-2
(RDSR2) (35h) & Status Register-3 (RDSR3) (15h)
The Read Status Register instructions allow the 8-bit Status Registers to be read. The instruction
is entered by driving CS# low and shifting the instruction code “05h” for Status Register-1, “35h”
for Status Register-2 or “15h” for Status Register-3 into the DI pin on the rising edge of CLK. The
status register bits are then shifted out on the DO pin at the falling edge of CLK with most
significant bit (MSB) first as shown in Figure 15. Refer to section 9.1, 9.2 and 9.3 for Status
Register description.
The Read Status Register instruction may be used at any time, even while a Program, Erase or
Write Status Register cycle is in progress. This allows the WIP status bit to be checked to
determine when the cycle is complete and if the device can accept another instruction. The
Status Register can be read continuously, as shown in Figure 16. The instruction is completed
by driving CS# high.
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
16
17
18
19
22
23
1
Mode 0
Instruction
(05h/35h/15h)
DI
(DQ0)
Status Register 1/2/3 out
D0
(DQ1)
High Impedance
7
=MSB
6
5
4
3
2
1
6
5
4
3
2
7
Figure 15 Read Status Register Instruction (SPI Mode)
V1.0
Datasheet
27
CS#
Mode 3
CLK
2
4
3
5
Mode 0
Instruction
05h/35h/15h
DQ0
4
DQ1
5
1
5
1
5
DQ2
6
2
6
2
6
DQ3
7
3
7
3
7
SR1/2/3
out
SR1/2/3
out
Figure 16 Read Status Register Instruction (QPI Mode)
10.2.5. Write Status Register-1 (WRSR1) (01h), Status Register-2
(WRSR2) (31h)
The Write Status Register instruction allows the Status Register to be written. The writable
Status Register bits include: SRP0, TB, SEC, BP2, BP1 and BP0 in Status Register-1;
HOLD/RST, CMP, LB, QE, SRP1, DRV1, DRV0 and WPS in Status Register-2. All other Status
Register bit locations are read-only and will not be affected by Write Status Register instruction.
LB is a non-volatile OTP bit, once it is set to 1, it cannot be cleared to 0.
To write non-volatile Status Register bits, a standard Write Enable (06h) instruction must
previously have been executed for the device to accept the Write Status Register instruction
(Status Register bit WEL must equal 1). Once write enabled, the instruction is entered by driving
CS# low, sending the instruction code “01h/31h”, and then writing the status register data byte
as illustrated inFigure 17 & Figure 18.
To write volatile Status Register bits, a Write Enable for Volatile Status Register (50h) instruction
must have been executed prior to the Write Status Register instruction (Status Register bit WEL
remains 0). However, SRP1 and LB cannot be changed from 1 to 0 because of the OTP
protection for these bits. Upon power off or the execution of Software Reset, the volatile Status
Register bit values will be lost, and the non-volatile Status Register bit values will be restored.
During non-volatile Status Register write operation (06h combined with 01h/31h), after CS# is
driven high, the self-timed Write Status Register cycle will commence for a time duration of tW
(See “11.6 AC Electrical Characteristics”). While the Write Status Register cycle is in progress,
the Read Status Register instruction may still be accessed to check the status of the WIP bit.
The WIP bit is a 1 during the Write Status Register cycle and a 0 when the cycle is finished and
ready to accept other instructions again. After the Write Status Register cycle has finished, the
Write Enable Latch (WEL) bit in the Status Register will be cleared to 0.
During volatile Status Register write operation (50h combined with 01h/31h), after CS# is driven
high, the Status Register bits will be refreshed to the new values within the time period of tSHSL2
(See “11.6 AC Electrical Characteristics”). WIP bit will remain 0 during the Status Register bit
refresh period.
The Write Status Register instruction can be used in both SPI mode and QPI mode. However,
the QE bit cannot be written to 0 when the device is in the QPI mode, because QE=1 is required
V1.0
Datasheet
28
for the device to enter and operate in the QPI mode.
Refer to section 9.1, 9.2, 9.3 for Status Register description. Factory default for all status Register
bits are 0.
CS#
Mode 3
CLK
1
2
3
4
5
6
8
7
9
10
11
12
13
14
15
Mode 3
Mode 0
Mode 0
Status Register 1/2 in
Instruction (01h/31h)
DI
(DQ0)
D0
(DQ1)
7
6
5
4
3
2
1
High Impedance
=MSB
Figure 17 Write Status Register-1/2 Instruction (SPI Mode)
CS#
Mode 3
CLK
2
Mode 3
3
Mode 0
Mode 0
Instruction
01h/31h
SR1/2 in
DQ0
4
DQ1
5
1
DQ2
6
2
DQ3
7
3
Figure 18 Write Status Register-1/2 Instruction (QPI Mode)
The FM25Q128AI3 is also backward compatible to FMSH’s previous generations of serial flash
memories, in which the Status Register-1&2 can be written using a single “Write Register-1(01h)”
command. To complete the Write Status Register1&2, the CS# pin must be driven high after the
sixteenth bit of data that is clocked in as shown in Figure 19. If CS# is driven high after the eighth
clock, the Write Status Register (WRSR) instruction will only program the Status Register-1 and
the Status Register-2 will not be affected.
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
16
17
18
19
22
23
Mode 0
Mode 0
Instruction (01h)
DI
(DQ0)
D0
(DQ1)
Mode 3
Status Register 1 in
7
6
5
4
3
2
Status Register 2 in
1
14
13
12
11
10
9
8
High Impedance
=MSB
Figure 19 Write Status Register-1/2 Instruction (backward compatible,SPI Mode)
V1.0
Datasheet
29
CS#
Mode 3
CLK
2
4
3
Mode 3
5
Mode 0
Mode 0
Instruction
01h
SR1 in
SR2 in
DQ0
4
8
DQ1
5
1
13
9
DQ2
6
2
14
10
DQ3
7
3
15
11
Figure 20 Write Status Register-1/2 Instruction (backward compatible,QPI Mode)
10.2.6. Read Data (03h)
The Read Data instruction allows one or more data bytes to be sequentially read from the
memory. The instruction is initiated by driving the CS# pin low and then shifting the instruction
code “03h” followed by a 24-bit address A23-A0 into the DI pin. The code and address bits are
latched on the rising edge of the CLK pin. After the address is received, the data byte of the
addressed memory location will be shifted out on the DO pin at the falling edge of CLK with
most significant bit (MSB) first. The address is automatically incremented to the next higher
address after each byte of data is shifted out allowing for a continuous stream of data. This
means that the entire memory can be accessed with a single instruction as long as the clock
continues. The instruction is completed by driving CS# high.
The Read Data instruction sequence is shown in Figure 21. If a Read Data instruction is issued
while an Erase, Program or Write cycle is in process (WIP =1) the instruction is ignored and will
not have any effect on the current cycle. The Read Data instruction allows clock rates from D.C.
to a maximum of fR (see “11.6 AC Electrical Characteristics”).
The Read Data (03h) instruction is only supported in Standard SPI mode.
CS#
Mode3
CLK Mode0
0 1
2
3
4
5 6
8 9 10
7
24-Bit Addess
Instruction (03h)
DI
(DQ0)
DO
(DQ1)
28 29 30 31 32 33 34 35 36 37 38 39
23 22 21
3
2
1
Data Out1
HIGH IMPEDANCE
7
6
5
4
3
2
Data Out2
1
▲ = MSB
Figure 21 Read Data Instruction (SPI Mode only)
V1.0
Datasheet
30
10.2.7. Fast Read (0Bh)
The Fast Read instruction is similar to the Read Data instruction except that it can operate at the
highest possible frequency of FR (see “11.6 AC Electrical Characteristics”). This is accomplished
by adding eight “dummy” clocks after the 24-bit address as shown in Figure 22. The dummy
clocks allow the devices internal circuits additional time for setting up the initial address. During
the dummy clocks the data value on the DI pin is a “don’t care”.
CS#
Mode
3
CLK
Mode
3
4
5
6
8
7
9
10
Instruction (0Bh)
28
29
30
31
3
2
1
46
47
48
49
50
6
5
24-Bit Address
DI
(DQ0)
23
22
21
42
43
High Impedance
D0
(DQ1)
=MSB
CS#
31
32
33
34
35
36
37
38
39
40
41
44
51
52
53
54
55
2
1
CLK
Dummy Clocks
DI
(DQ0)
Data Out 2
Data Out 1
D0
(DQ1)
High Impedance
7
6
5
4
3
2
1
4
3
7
Figure 22 Fast Read Instruction (SPI Mode)
Fast Read (0Bh) in QPI Mode
The Fast Read instruction is also supported in QPI mode. When QPI mode is enabled, the
number of dummy clocks is configured by the “Set Read Parameters (C0h)” instruction to
accommodate wide range applications with different needs for either maximum Fast Read
frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting,
the number of dummy clocks can be configured as either 2, 4, 6 or 8. The default number of
dummy clocks upon power up or after a Reset instruction is 2.
V1.0
Datasheet
31
CS#
Mode 3
CLK
2
3
4
5
6
7
8
9
10
11
12
13
Mode 0
Instruction
IOs switch from
Input to Output
A23-16
A15-8
A7-0
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
0Bh
Dummy
Byte1
Byte2
*the number of dummy clocks is controlled by LC[1:0]
Figure 23 Fast Read Instruction (QPI Mode)
10.2.8. Fast Read Dual Output (3Bh)
The Fast Read Dual Output (3Bh) instruction is similar to the standard Fast Read (0Bh)
instruction except that data is output on two pins; DQ0 and DQ1. This allows data to be
transferred from the FM25Q128AI3 at twice the rate of standard SPI devices. The Fast Read
Dual Output instruction is ideal for quickly downloading code from Flash to RAM upon power-up
or for applications that cache code-segments to RAM for execution.
Similar to the Fast Read instruction, the Fast Read Dual Output instruction can operate at the
highest possible frequency of FR (see “11.6 AC Electrical Characteristics”). For Fast Read Dual
Output instruction, there are eight dummy cycles required after the last address bit is shifted into
DI before data begins shifting out of DQ0 and DQ1. The dummy clocks allow the device's internal
circuits additional time for setting up the initial address. The input data during the dummy clocks
is “don’t care”. However, the DQ0 pin should be high-impedance prior to the falling edge of the
first data out clock.
V1.0
Datasheet
32
CS#
Mode 3
CLK
1
2
3
4
5
6
8
7
9
10
Instruction (3Bh)
29
30
31
2
1
24-Bit Address
DI
(DQ0)
D0
(DQ1)
28
Mode 0
23
22
21
3
High Impedance
=MSB
CS#
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
CLK
IO0 switches from
Input to Output
Dummy Clocks
DI
(DQ0)
4
2
3
1
6
4
2
5
3
1
6
4
2
5
3
1
6
4
2
7
5
3
1
7
High Impedance
D0
(DQ1)
7
Data Out 1
Figure 24
Data Out 2
Data Out 3
Data Out 4
Fast Read Dual Output Instruction (SPI Mode only)
10.2.9. Fast Read Quad Output (6Bh)
The Fast Read Quad Output (6Bh) instruction is similar to the Fast Read Dual Output (3Bh)
instruction except that data is output on four pins, DQ0, DQ1, DQ2, and DQ3. A Quad enable of
Status Register-2 must be executed before the device will accept the Fast Read Quad Output
Instruction (Status Register bit QE must equal 1). The Fast Read Quad Output Instruction allows
data to be transferred from the FM25Q128AI3 at four times the rate of standard SPI devices.
The Fast Read Quad Output instruction can operate at the highest possible frequency of FR (see
“11.6 AC Electrical Characteristics”). For Fast Read Quad Output instruction, there are eight
dummy cycles required after the last address bit is shifted into DI before data begins shifting out
of DQ0, DQ1, DQ2 and DQ3. The dummy clocks allow the device's internal circuits additional time
for setting up the initial address. The input data during the dummy clocks is “don’t care”. However,
the DQ pins should be high-impedance prior to the falling edge of the first data out clock.
V1.0
Datasheet
33
CS#
Mode 3
CLK
1
2
3
4
5
6
7
8
9
10
28
29
30
31
2
1
Mode 0
Instruction (6Bh)
24-Bit Address
DQ0
23
22
21
3
High Impedance
DQ1
High Impedance
DQ2
High Impedance
DQ3
=MSB
CS#
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
CLK
IO0 switches from
Input to Output
Dummy Clocks
DQ0
DQ1
DQ2
DQ3
High Impedance
High Impedance
High Impedance
4
5
1
5
1
5
1
5
1
5
6
2
6
2
6
2
6
2
6
3
7
3
7
3
7
3
7
7
Byte1
Byte2
Byte3
Byte4
Figure 25 Fast Read Quad Output Instruction (SPI Mode only)
10.2.10. Fast Read Dual I/O (BBh)
The Fast Read Dual I/O (BBh) instruction allows for improved random access while maintaining
two I/O pins, DQ0 and DQ1. It is similar to the Fast Read Dual Output (3Bh) instruction but with
the capability to input the Address bits A23-A0 two bits per clock. This reduced instruction
overhead may allow for code execution (XIP) directly from the Dual SPI in some applications.
Fast Read Dual I/O with “Continuous Read Mode”
The Fast Read Dual I/O instruction can further reduce instruction overhead through setting the
“Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 26.
The upper nibble of the (M7-4) controls the length of the next Fast Read Dual I/O instruction
through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the
(M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance prior to the falling
If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Dual I/O instruction
(after CS# is raised and then lowered) does not require the BBh instruction code, as shown in
Figure 27. This reduces the instruction sequence by eight clocks and allows the Read address to
be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do
not equal to (1,0), the next instruction (after CS# is raised and then lowered) requires the first
byte instruction code, thus returning to normal operation. It is recommended to input FFFFh on
DQ0 for the next instruction (16 clocks), to ensure M4 = 1 and return the device to normal
operation.
V1.0
Datasheet
34
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
16
17
18
19
22
23
Mode 0
Instruction (BBh)
A23-16
DI
(DQ0)
D0
(DQ1)
A15-8
A7-0
M7-0
22
16
14
12
10
8
6
4
2
21
19
17
15
13
11
9
7
5
3
1
4
2
5
3
1
=MSB
6
CS#
23
24
25
26
27
28
29
31
30
32
33
34
35
36
37
38
39
CLK
IOs switch from
Input to Output
DI
(DQ0)
D0
(DQ1)
1
6
4
2
5
3
1
6
4
2
5
3
1
6
4
2
5
3
1
Byte 1
6
4
2
7
5
3
1
7
Byte 2
Byte 3
Byte 4
Figure 26 Fast Read Dual I/O Instruction (Initial instruction or previous M5-4 ≠ 10, SPI
Mode only)
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
Mode 0
A23-16
A15-8
A7-0
M7-0
DI
(DQ0)
22
16
14
12
10
8
6
4
2
D0
(DQ1)
23
21
19
17
15
13
11
9
7
5
3
1
6
4
2
5
3
1
30
31
=MSB
CS#
15
16
17
18
19
22
23
24
25
26
27
28
29
CLK
IOs switch from
Input to Output
DI
(DQ0)
D0
(DQ1)
1
6
4
2
5
3
1
6
4
2
5
3
1
4
2
5
3
1
Byte 1
6
Byte 2
6
4
2
7
5
3
1
7
Byte 3
Byte 4
Figure 27 Fast Read Dual I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode
only)
V1.0
Datasheet
35
10.2.11. Fast Read Quad I/O (EBh)
The Fast Read Quad I/O (EBh) instruction is similar to the Fast Read Dual I/O (BBh) instruction
except that address and data bits are input and output through four pins DQ0, DQ1, DQ2 and DQ3
and four Dummy clocks are required in SPI mode prior to the data output. The Quad I/O
dramatically reduces instruction overhead allowing faster random access for code execution (XIP)
directly from the Quad SPI. The Quad Enable bit (QE) of Status Register-2 must be set to enable
the Fast Read Quad I/O Instruction.
Fast Read Quad I/O with “Continuous Read Mode”
The Fast Read Quad I/O instruction can further reduce instruction overhead through setting the
“Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 28.
The upper nibble of the (M7-4) controls the length of the next Fast Read Quad I/O instruction
If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Quad I/O instruction
(after CS# is raised and then lowered) does not require the EBh instruction code, as shown in
Figure 29. This reduces the instruction sequence by eight clocks and allows the Read address to
not equal to (1, 0), the next instruction (after CS# is raised and then lowered) requires the first
byte instruction code, thus returning to normal operation. It is recommended to input FFh on DQ0
for the next instruction (8 clocks), to ensure M4 = 1 and return the device to normal operation.
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
16
17
18
19
22
23
Mode 0
Instruction (EBh)
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
Dq3
23
19
15
11
7
3
7
3
7
3
7
3
7
Dummy Dummy
Byte1
Byte2
Byte3
Figure 28 Fast Read Quad I/O Instruction (Initial instruction or previous M5-4≠10, SPI
Mode)
FM25Q128AI3 128M-BIT SERIAL FLASH MEMORY
V1.0
Datasheet
36
CS#
Mode 3
CLK
2
3
4
5
6
7
8
9
10
11
12
13
14
15
Mode 0
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0
Dummy Dummy
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
Byte1
Byte2
Byte3
Figure 29 Fast Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode)
Fast Read Quad I/O with “8/16/32/64-Byte Wrap Around” in Standard SPI mode
The Fast Read Quad I/O instruction can also be used to access a specific portion within a page
by issuing a “Set Burst with Wrap” (77h) command prior to EBh. The “Set Burst with Wrap” (77h)
command can either enable or disable the “Wrap Around” feature for the following EBh
commands. When “Wrap Around” is enabled, the data being accessed can be limited to either a 8,
16, 32 or 64-byte section of a 256-byte page. The output data starts at the initial address
specified in the instruction, once it reaches the ending boundary of the 8/16/32/64-byte section,
the output will wrap around to the beginning boundary automatically until CS# is pulled high to
terminate the command.
The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address
and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing
multiple read commands.
The “Set Burst with Wrap” instruction allows three “Wrap Bits”, W6-4 to be set. The W4 bit is used
to enable or disable the “Wrap Around” operation while W6-5 are used to specify the length of the
wrap around section within a page. See “Set Burst with Wrap (77h)” for detail descriptions.
Fast Read Quad I/O (EBh) in QPI Mode
The Fast Read Quad I/O instruction is also supported in QPI mode, as shown in Figure 30. When
QPI mode is enabled, the number of dummy clocks can be configured as either 2, 4, 6 or 8. The
default number of dummy clocks upon power up or after a Reset instruction is 2.
“Continuous Read Mode” feature is also available in QPI mode for Fast Read Quad I/O
instruction. Please refer to the description on previous pages for details.
“Wrap Around” feature is also available in QPI mode for Fast Read Quad I/O instruction. Please
V1.0
Datasheet
37
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
Mode 0
Instruction
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0 Dummy
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
EBh
Byte1
Byte2
* "Set Read Parameters" instruction (C0h) can
set the number of dummy clocks.
Figure 30 Fast Read Quad I/O Instruction (Initial instruction or previous M5-4≠10, QPI
Mode)
10.2.12. Word Read Quad I/O (E7h)
The Word Read Quad I/O (E7h) instruction is similar to the Fast Read Quad I/O (EBh) instruction
except that the lowest Address bit (A0) must equal 0 and only two Dummy clocks are required
prior to the data output. The Quad I/O dramatically reduces instruction overhead allowing faster
random access for code execution (XIP) directly from the Quad SPI. The Quad Enable bit (QE) of
Status Register-2 must be set to enable the Word Read Quad I/O Instruction.
Word Read Quad I/O with “Continuous Read Mode”
The Word Read Quad I/O instruction can further reduce instruction overhead through setting the
“Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 31.
(after CS# is raised and then lowered) does not require the E7h instruction code, as shown in
Figure 32. This reduces the instruction sequence by eight clocks and allows the Read address to
V1.0
Datasheet
38
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
16
15
17
18
19
Mode 0
Instruction (E7h)
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0
Dummy
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
Byte1
Byte2
Byte3
Figure 31 Word Read Quad I/O Instruction (Initial instruction or previous M5-4 ≠ 10, SPI
Mode only)
CS#
Mode 3
CLK
2
3
4
5
6
7
8
9
10
11
12
13
Mode 0
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0
Dummy
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
Byte1
Byte2
Byte3
Figure 32 Word Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode
only)
Word Read Quad I/O with “8/16/32/64-Byte Wrap Around” in Standard SPI mode
The Word Read Quad I/O instruction can also be used to access a specific portion within a page
by issuing a “Set Burst with Wrap” (77h) command prior to E7h. The “Set Burst with Wrap” (77h)
command can either enable or disable the “Wrap Around” feature for the following E7h
V1.0
Datasheet
39
10.2.13. Octal Word Read Quad I/O (E3h)
The Octal Word Read Quad I/O (E3h) instruction is similar to the Fast Read Quad I/O (EBh)
instruction except that the lower four Address bits (A0, A1, A2, A3) must equal 0. As a result, the
dummy clocks are not required, which further reduces the instruction overhead allowing even
faster random access for code execution (XIP). The Quad Enable bit (QE) of Status Register-2
must be set to enable the Octal Word Read Quad I/O Instruction.
Octal Word Read Quad I/O with “Continuous Read Mode”
The Octal Word Read Quad I/O instruction can further reduce instruction overhead through
setting the “Continuous Read Mode” bits M7-M0 after the input Address bits A23-A0, as shown in
Figure 33. The upper nibble of the (M7-4) controls the length of the next Octal Word Read Quad
I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower
nibble bits of the (M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance
(after CS# is raised and then lowered) does not require the E3h instruction code, as shown in
Figure 34. This reduces the instruction sequence by eight clocks and allows the Read address to
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
16
17
18
19
Mode 0
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
3
7
Instruction (E3h)
Byte2
Byte1
Byte3
Byte4
Figure 33 Octal Word Read Quad I/O Instruction (Initial instruction or previous M5-4 ≠ 10,
SPI Mode only)
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
Mode 0
IOs switch from
Input to Output
A23-16
A15-8
A7-0
M7-0
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
1
5
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
2
6
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
3
7
Byte1
Byte2
Byte3
Byte4
Figure 34 Octal Word Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI
Mode only)
V1.0
Datasheet
40
10.2.14. Set Burst with Wrap (77h)
The Set Burst with Wrap (77h) instruction is used in conjunction with “Fast Read Quad I/O” and
“Word Read Quad I/O” instructions to access a fixed length of 8/16/32/64-byte section within a
256-byte page. Certain applications can benefit from this feature and improve the overall system
code execution performance.
Similar to a Quad I/O instruction, the Set Burst with Wrap instruction is initiated by driving the
CS# pin low and then shifting the instruction code “77h” followed by 24 dummy bits and 8 “Wrap
Bits”, W7-0. The instruction sequence is shown in Figure 35. Wrap bit W7 and the lower nibble
W3-0 are not used.
W4 = 0
Wrap Around
Wrap Length
W6, W5
00
01
10
11
Yes
Yes
Yes
Yes
W4 =1 (default)
Wrap Around
Wrap Length
8-byte
16-byte
32-byte
64-byte
No
No
No
No
N/A
N/A
N/A
N/A
Once W6-4 is set by a Set Burst with Wrap instruction, all the following “Fast Read Quad I/O” and
“Word Read Quad I/O” instructions will use the W6-4 setting to access the 8/16/32/64-byte
section within any page. To exit the “Wrap Around” function and return to normal read operation,
another Set Burst with Wrap instruction should be issued to set W4 = 1. The default value of W4
upon power on is 1. In the case of a system Reset while W4 = 0, it is recommended that the
controller issues a Set Burst with Wrap instruction to reset W4 = 1 prior to any normal Read
instructions since FM25Q128AI3 does not have a hardware Reset Pin.
CS#
Mode 3
CLK
2
3
4
5
6
8
7
9
10
11
12
13
14
15
Mode 3
Mode 0
Mode 0
Instruction (77h)
don’t
care
don’t
care
DQ0
X
X
X
X
DQ1
X
X
X
X
DQ2
X
X
X
DQ3
X
X
X
don’t
care
Wrap
Bit
X
W4
X
X
X
W5
X
X
X
X
W6
X
X
X
X
X
X
X
Figure 35 Set Burst with Wrap Instruction for SPI Mode
10.2.15. Page Program (02h)
The Page Program instruction allows from one byte to 256 bytes (a page) of data to be
programmed at previously erased (FFh) memory locations. A Write Enable instruction must be
executed before the device will accept the Page Program Instruction (Status Register bit WEL= 1).
The instruction is initiated by driving the CS# pin low then shifting the instruction code “02h”
followed by a 24-bit address A23-A0 and at least one data byte, into the DI pin. The CS# pin must
be held low for the entire length of the instruction while data is being sent to the device. The Page
Program instruction sequence is shown in Figure 36 and Figure 37.
If an entire 256 byte page is to be programmed, the last address byte (the 8 least significant
V1.0
Datasheet
41
address bits) should be set to 0. If the last address byte is not zero, and the number of clocks
exceeds the remaining page length, the addressing will wrap to the beginning of the page. In
some cases, less than 256 bytes (a partial page) can be programmed without having any effect
on other bytes within the same page. One condition to perform a partial page program is that the
number of clocks can not exceed the remaining page length. If more than 256 bytes are sent to
the device the addressing will wrap to the beginning of the page and overwrite previously sent
data.
As with the write and erase instructions, the CS# pin must be driven high after the eighth bit of the
last byte has been latched. If this is not done the Page Program instruction will not be executed.
After CS# is driven high, the self-timed Page Program instruction will commence for a time
duration of tPP (See “11.6 AC Electrical Characteristics”). While the Page Program cycle is in
progress, the Read Status Register instruction may still be accessed for checking the status of
the WIP bit. The WIP bit is a 1 during the Page Program cycle and becomes a 0 when the cycle is
finished and the device is ready to accept other instructions again. After the Page Program cycle
has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Page
Program instruction will not be executed if the addressed page is protected by the Block Protect
(CMP, SEC, TB, BP2, BP1 and BP0) bits or the Individual Block/Sector Locks.
CS#
Mode 3
CLK
1
2
3
4
5
6
7
8
9
10
28
29
30
31
32
33
34
35
36
37
38
39
2
1
Mode 0
Instruction (02h)
Data Byte 1
24-Bit Address
DI
(DQ0)
23
22
21
3
2
1
7
=MSB
6
5
4
3
46
47
48
49
50
51
52
53
54
55
2079
45
2078
44
2077
43
2076
42
2075
41
2074
40
2073
39
2072
CS#
CLK
Mode 0
Data Byte 2
DI
(DQ0)
Mode 3
6
5
4
3
Data Byte 256
Data Byte 3
2
1
6
5
4
3
2
1
6
5
4
3
2
1
Figure 36 Page Program Instruction (SPI Mode)
2
3
4
5
6
8
7
9
10
11
12
13
519
1
518
Mode 3
CLK
516
CS#
Mode 3
Mode 0
Mode 0
Instruction
A23-16
02h
A15-8
A7-0
Byte1
Byte2
Byte3
Byte 255
Byte 256
DQ0
12
8
4
DQ1
21
17
13
9
5
1
5
1
5
1
5
1
5
1
5
1
DQ2
22
18
14
10
6
2
6
2
6
2
6
2
6
2
6
2
DQ3
23
19
15
11
7
3
7
3
7
3
7
3
7
3
7
3
Figure 37 Page Program Instruction (QPI Mode)
V1.0
Datasheet
42
10.2.16. Quad Input Page Program (32h)
The Quad Page Program instruction allows up to 256 bytes of data to be programmed at
previously erased (FFh) memory locations using four pins: DQ0, DQ1, DQ2, and DQ3. The Quad
Page Program can improve performance for PROM Programmer and applications that have slow
clock speeds = 1 / FCLK ;
2. This parameter is characterized and is not 100% tested.
SPEC
TYP
MAX
UNIT
4
5
5
5
5
3
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
µs
3
µs
1.8
µs
400
15
50
3
500
1500
2000
100
µs
ms
us
ms
ms
ms
ms
s
us
12
7
8
10
30
0.7
50
200
250
50
1
CS#
tCH
CLK
I/O
OUTPUT
tCLQX
tCLQV
tCLQX
tCLQV
tCL
tSHQZ
LSB OUT
tQLQH
tQHQL
Figure 83 Serial Output Timing
V1.0
Datasheet
74
tSHSL
CS#
tCHSL
tCHSH
tSLCH
tSHCH
CLK
tDVCH
I/O
INPUT
tCHDX
tCLCH
MSB IN
I/O
OUTPUT
tCHCL
LSB IN
(High Impedance)
Figure 84 Serial Input Timing
CS#
tHLCH
tCHHL
tHHCH
CLK
tCHHH
tHLQZ
tHHQX
I/O
OUTPUT
I/O
INPUT
HOLD#
Figure 85 Hold Timing
CS#
tSHWL
tWHSL
WP#
CLK
I/O
INPUT
Write Status Register is allowed
Write Status Register is not allowed
Figure 86 WP# Timing
V1.0
Datasheet
75
12.
Ordering Information
FM 25Q 128 AI3 -XXX -C -H M
Company Prefix
FM = Fudan Microelectronics Group Co.,ltd
Product Family
25Q =2.3~3.6V Serial Flash with 4KB Uniform-Sector,
Dual/Quad SPI & QPI
Product Density
128 = 128M-bit
Product Version
Package Type
SOB = 8-pin SOP (208mil)
DNA = 8-pin TDFN (5x6mm)
BGB = 24-ball BGA (8x6mm)
Product Carrier
U = Tube
T = Tape and Reel
A = Tray
HSF ID Code
G = RoHS Compliant, Halogen-free, Antimony-free
Moisture Sensitivity Level
1 = MSL1
3 = MSL3
V1.0
Datasheet
76
13.
Part Marking Scheme
13.1.
SOP8 (208mil)
FM25Q128AI3
YYWWALHM
Product Density
1 = MSL1
Blank=MSL3
HSF ID Code
Lot Number(just with 0~9、A~Z)
Assembly’s Code
Work week during which the products was molded (eg..week 12)
The last two digits of the year In which the products was seal / molded.
13.2.
TDFN8 (5x6mm)
FM25Q128AI3
YYWWALHM
Product Density
1 = MSL1
Blank=MSL3
HSF ID Code
Assembly’s Code
Work week during which the product was molded (eg..week 12)
The last two digits of the year In which the product was sealed / molded.
13.3.
BGA24 (8x6mm)
V1.0
Datasheet
77
FM25Q128AI3
Product Density
YYWWALHM
1 = MSL1
Blank=MSL3
HSF ID Code
Package Lot Number (just with 0~9, A~Z)
Assembly’s Code
The last two digits of the year in which the product was sealed/molded
V1.0
Datasheet
78
14.
Packaging Information
14.1.
SOP8 (208mil)
SOP 8 (208mil)
Symbol
MIN
A
A1
0.050
b
0.350
c
0.100
D
5.130
E1
5.180
E
7.700
e
L
0.500
θ
0°
NOTE:
1. Dimensions are in Millimeters.
MAX
2.150
0.250
0.500
0.250
5.330
5.380
8.100
1.270(BSC)
0.850
8°
V1.0
Datasheet
79
14.2.
TDFN8 (5x6mm)
TDFN 8 (5x6mm)
Symbol
A
A1
D
D1
E
E1
b
e
L
MIN
0.700
0.000
4.900
3.900
5.900
3.300
0.350
MAX
0.800
0.050
5.100
4.300
6.100
3.500
0.450
1.270TYP
0.550
0.650
NOTE:
1
V1.0
Datasheet
80
14.3.
BGA24 (8x6mm)
BGA24 (8x6mm)
Symbol
A
A1
A2
D
D1
E
E1
e
b
MIN
--0.17
0.69
7.90
MAX
1.20
0.25
0.79
8.10
5.00 BSC
5.90
6.10
3.00 BSC
1.00 BSC
0.350
0.450
Note:
V1.0
Datasheet
81
15.
Revision History
Version
1.0
Publication
Pages
date
Sep. 2022
83
Paragraph or
Illustration
Revise Description
Initial Document Release.
V1.0
Datasheet
82
Sales and Service
Shanghai Fudan Microelectronics Group Co., Ltd.
Address: Bldg No. 4, 127 Guotai Rd, Shanghai City China.
Postcode: 200433
Tel: (86-021) 6565 5050 Fax: (86-021) 6565 9115
Shanghai Fudan Microelectronics (HK) Co., Ltd.
Address: Unit 506, 5/F., East Ocean Centre, 98 Granville
Road, Tsimshatsui East, Kowloon, Hong Kong
Tel: (852) 2116 3288 2116 3338
Fax: (852) 2116 0882
Beijing Office
Address: Room 423, Bldg B, Gehua Building, 1 QingLong
Hutong, Dongzhimen Alley north Street, Dongcheng
District, Beijing City, China.
Postcode: 100007
Tel: (86-010) 8418 6608
Fax: (86-010) 8418 6211
Shenzhen Office
Address: Room.2306-2308, Building A7, Chuangzhi
Cloud City, Liuxian Avenue, Xili Street, Nanshan District,
Shenzhen, China.
Postcode: 518000
Tel: (86-0755) 8335 0911 8335 1011 8335 2011 8335
0611
Fax: (86-0755) 8335 9011
Shanghai Fudan Microelectronics (HK) Ltd Taiwan
Representative Office
Address: Unit 1225, 12F., No 252, Sec.1 Neihu Rd.,
Neihu Dist., Taipei City 114, Taiwan
Tel : (886-2) 7721 1889
Fax: (886-2) 7722 3888
Shanghai Fudan Microelectronics (HK) Ltd Singapore
Address : 47 Kallang Pudding Road, #08-06,The
Crescent @ Kallang ,Singapore 349318
Tel : (65) 6443 0860
Fax: (65) 6443 1215
Fudan Microelectronics(USA)Inc.
Address : 97 E Brokaw Road, Suite 320,San Jose,CA
95112
Tel : (+1)408-335-6936
Web Site: http://www.fmsh.com/
V1.0
Datasheet
83
