产品承认书
SPECIFICATION FOR APPROVAL
CUSTOMER:
CUSTOMER P/N:
CND-TEK P/N. :
G2426S
DESCRIPTION:
1000 BASE-T MAGNETICS MODULES
REF NO:
QTC-001
REV/NO:
V1.02
DATE:
2021/05/07
■ SPECIFICATION
■ SAMPLE
Q’TY OF SAMPLES
PCS
FULL APPROVED
CONDITIONAL APPROVED
REJECTED
CUSTOMER'S SIGNATURE
REMARK
G2426S
V1.0.2
May 7, 2021
␡ൣ⻱㚄䗮⭥ᆀᴹ䲀ޜਨ
6KHQ]KHQ&1'7(.Electronics&R/WG
ޜਨൠ൰: ␡ൣᐲইኡ४㾯ѭ䭷街道百旺社区牛城村牛城路221号505
TEL: 86-755-29016433
FAX:86- 755-27652977
Email: sales2@cd-tek.com
Http: //www.cd-tek.com
1.FEATURES:
1.1 Designed for long haul Gigabit Ethernet 100/1000 Base-T, full duplex applications.
1.2 Supports four pairs of category 5 UTP cable,Cable interface for isolation and low common mode
emissions.
1.3 Low profile Surface Mount Packaging designed for Hi-Temp Reflow Process
1.4 Compliant with IEEE 802.3ab standard for 1000 Base-T,Designed to support 1:1 Turns Ratio
Transceivers.
1.5 Operating Temperature range: -40℃ TO +85℃
1.6 Storage temperature range: -40℃ TO +85℃
2. DIMENSIONS & MARKING
CND-TEK XXXX
G2426S
Note:1、Dimension:
mm 2、Unless otherwise specified,all tolerances are:
3. SCHEMATICS:
4.ELECTRICAL SPECIFICATIONS @25℃
4.1 OCL :
350 μH Min. @ 100 KHz, 100mV with 8mA DC Bias
4.2 Leakage Inductance:
0.5 μH Max. @ 100KHz, 0.2V
4.3 Cw/w:
30pF Max. @ 100KHz, 0.2V
4.4 DCR:
1.2Ω Max.
4.5 Turns Ratio(±5%):
1CT:1CT(TX), 1CT:1CT(RX)
4.6 Polarity
1-24, 4-20, 7-18, 10-14In-Phase
4.7 Insertion Loss:
-1.0 dB Max. @ 1-100MHz
4.8 Return Loss:
-16 dB Min. @ 1-30MHz
-12 dB Min. @ 30-60 MHz
-10 dB Min.@ 60-80 MHz
4.9 Cross Talk:
-42 dB Min.@ 1-60 MHz
-35 dB Min.@ 60-100 MHz
4.10 Common Mode Rejection : -40 dB Min.@ 1-30 MHz
-35dB Min.@ 60 MHz
-30dB Min.@ 80-100 MHz
4.11 Isolation HI-POT:
1500Vrms 1mA 1Second
5. Recommended Lead Free IR Reflow Soldering Curve:
Item
Soldertechnique
simulation
Temperature
Time(s)
1
Solder iron
350±10
(solder irno temp)
4~5
2
Vapor phase reflow
215±5
(vapor temp)
60±5
3
IR/convection reflow
255±5
(component temp)
30±5
Temperature ramp/immersion
and emersion rate
1℃/s~4℃/s time above 183℃
90s~120s
Note:The curve includes recommended value only, please adjust your equipment to make sure the solder
process.Details please refers to the standard J-STD-020.
6. Reliability Test Criteria:
6.1 Terminal strength: Pull test withstand 9.8N 60+/-0.5S no looseness or movement.
6.2 Solderbility: Dipped in 245℃+/-5℃ molten solder for 3+/-0.5 seconds,95% min shall be smooth any and
bright.
6.3 Resistance to soldering heat : Convection reflow condition setting: peak temperature at 260℃+0/-5℃
above 217℃ for 90-180 seconds, ramp-up rate 2-3℃/s. Ramp-down rate 6℃/s Max. No mechanical problem
found. No electrical failure found per our specification.
6.4 Vibration: 1.5mm amplitude total excursion 10-55-10 Hz traversed in 1minute, x.y.z, axis for 2 hours. Shall
not be any abnormality.
6.5 Random drop (Packing condition): Height 60cm, 3 times on the wood floorboard ,shall not be any
abnormality.
6.6 Dry heat: 100+/-2℃ 96 hours.
6.7 Cold: -20+/-2℃ 96 hours.
6.8 Damp Heat: 60+/-2℃, 93+/-3% RH 96 hours.
6.9 Change of temperature: exposed 5 cycle; each consisting of 30 minutes at -20+/-2℃,2-3minutes at 20+/2℃,30 minutes at 85+/-2℃, 2-3 minutes at 20+/-2℃.
Packing
Specification
Packing Specification
1ȻEach Reel Qty漡1100pcs/pkg
2ȻTotal unit transformer in carton:
1100灤 5 (Total Reel in Carton) = 5500PCS
很抱歉,暂时无法提供与“G2426S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.41570
- 10+3.50470
- 30+3.06780
- 100+2.63090
- 500+2.42770
- 国内价格
- 1+4.43232
- 10+3.53970
- 30+3.09852
- 100+2.65734
- 500+2.45214
- 1100+2.31876
- 国内价格
- 1+3.07530
- 10+2.97480
- 100+2.73360
- 500+2.61300
- 国内价格
- 1+4.15180
- 10+3.83240
- 100+3.51300
- 500+3.19370
