AO3400A
N-Channel 30-V(D-S) MOSFET
ID
RDS(on)MAX
V(BR)DSS
SOT-23 / SOT-23-3L
0.028Ω@ 10V
3
30V
1.GATE
5.8 A
0.033Ω@ 4.5V
2.SOURCE
JS
0.052Ω@ 2.5V
3.DRAIN
1
2
MI
General FEATURE
Equivalent Circuit
CR
●TrenchFET Power MOSFET
●Lead free product is acquired
O
●Surface mount package
co
mi
Se
APPLICATION
●Load Switch for Portable Devices
●DC/DC Converter
nd
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
TA=25°C
Pulsed Drain Current B
Power Dissipation A
TA=25°C
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient
Maximum Junction-to-Lead C
Units
V
±12
V
ID
5.8
IDM
30
PD
1.4
W
-55 to 150
°C
TJ, TSTG
Symbol
A
A
r
to
uc
Continuous Drain
Current A
Maximum
30
t ≤ 10s
Steady-State
Steady-State
RθJA
RθJL
www.jsmsemi.com
Typ
65
85
43
Max
90
125
60
A
Units
°C/W
°C/W
°C/W
第1/6页
AO3400A
Electrical Characteristics (T J=25°C unless otherwise noted)
Parameter
Symbol
Conditions
Min
Typ
Max
Units
ID=250µA, VGS=0V
IDSS
Zero Gate Voltage Drain Current
VDS=25V, VGS=0V
1
µA
IGSS
Gate-Body leakage current
VDS=0V, VGS=±12V
100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=250µA
0.6
VGS=4.5V, VDS=5V
30
ID(ON)
JS
STATIC PARAMETERS
BVDSS
Drain-Source Breakdown Voltage
On state drain current
MI
mΩ
VGS=4.5V, ID=5.0A
30
33
mΩ
48
52
mΩ
Forward Transconductance
VSD
IS=1A,VGS=0V
Diode Forward Voltage
Maximum Body-Diode Continuous Current
VGS=2.5V, ID=4.0A
CR
VDS=5V, ID=5.8A
Rg
Gate resistance
VGS=0V, VDS=15V, f=1MHz
tf
Turn-Off Fall Time
1030
pF
99
pF
77
pF
9.7
12
nC
VGS=4.5V, VDS=15V, ID=5.8A
1.6
3.1
VGS=10V, VDS=15V, RL=2.7Ω,
RGEN=3Ω
trr
Body Diode Reverse Recovery Time
Qrr
Body Diode Reverse Recovery Charge IF=5A, dI/dt=100A/µs
nC
3.3
nC
5
ns
4.8
7
ns
26.3
40
ns
4.1
6
ns
16
12
ns
nC
r
to
uc
Turn-Off DelayTime
A
Ω
nd
Turn-On Rise Time
tD(off)
V
3.6
co
tr
1.2
2.5
1.2
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Qg
Total Gate Charge
Qgs
Gate Source Charge
Turn-On DelayTime
823
S
mi
Reverse Transfer Capacitance
Gate Drain Charge
15
0.71
Se
Output Capacitance
Crss
tD(on)
10
O
Coss
V
A
28
gFS
Qgd
1.0
25
Static Drain-Source On-Resistance
DYNAMIC PARAMETERS
Ciss
Input Capacitance
V
VGS=10V, ID=5.8A
RDS(ON)
IS
30
A: The value of R θJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C.
The value in any given application depends on the user's specific board design. The current rating is based on the t≤ 10s thermal
resistance rating.
B: Repetitive rating, pulse width limited by junction temperature.
C. The R θJA is the sum of the thermal impedence from junction to lead RθJL and lead to ambient.
D. The static characteristics in Figures 1 to 6,12,14 are obtained using 80µs pulses, duty cycle 0.5% max.
E. These tests are performed with the device mounted on 1 in2 FR-4 board with 2oz. Copper, in a still air environment with TA=25°C. The
SOA curve provides a single pulse rating.
Rev 4 : June 2005
www.jsmsemi.com
第2/6页
AO3400A
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS
10V
3V
VDS=5V
16
4.5V
2.5V
12
ID(A)
ID (A)
15
8
JS
5
125°C
VGS=2V
MI
3
4
VDS (Volts)
Fig 1: On-Region Characteristics
5
CR
VGS=2.5V
30
VGS=4.5V
2
2.5
VGS(Volts)
Figure 2: Transfer Characteristics
1
3
1.6
VGS=4.5V
1.4
VGS=10V
1.2
VGS=2.5V
1
co
VGS=10V
10
0.8
5
10
15
50
nd
100
125
150
175
Temperature (°C)
Figure 4: On-Resistance vs. Junction
Temperature
ID (A)
Figure 3: On-Resistance vs. Drain Current and
Gate Voltage
1.0E+01
60
1.0E+00
r
to
uc
70
ID=5.8A
1.0E-01
50
125°C
IS (A)
RDS(ON) (mΩ )
0.5
mi
Se
RDS(ON) (mΩ )
50
40
O
60
25°C
4
Normalized On-Resistance
10
40
30
125°C
1.0E-02
1.0E-03
25°C
1.0E-04
25°C
1.0E-05
1.0E-06
10
4
6
8
10
0.0
VGS (Volts)
Figure 5: On-Resistance vs. Gate-Source Voltage
www.jsmsemi.com
0.2
0.4
0.6
0.8
1.0
1.2
VSD (Volts)
Figure 6: Body-Diode Characteristics
第3/6页
AO3400A
1400
5
VDS=15V
ID=5.8A
1200
Capacitance (pF)
VGS (Volts)
4
3
2
600
400
4
6
8
10
Qg (nC)
Figure 7: Gate-Charge Characteristics
CR
40
TJ(Max)=150°C
TA=25°C
Se
1ms
10ms
1s
TJ(Max)=150°C
TA=25°C
10
100
VDS (Volts)
co
DC
0.1
0.1
1
10
100
1000
nd
r
to
uc
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
RθJA=90°C/W
0.01
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junction-toAmbient (Note E)
Figure 9: Maximum Forward Biased Safe
Operating Area (Note E)
ZθJA Normalized Transient
Thermal Resistance
30
10
10s
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
1
PD
0.1
Ton
0.01
0.00001
25
mi
1.0
100µs
0.1s
10
15
VDS (Volts)
Figure 8: Capacitance Characteristics
Power (W)
RDS(ON)
10.0 limited
0.1
10
O
ID (Amps)
100.0
Crss
200
MI
Ciss
800
Coss
JS
1
1000
T
Single Pulse
0.0001
0.001
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance
www.jsmsemi.com
第4/6页
AO3400A
SOT-23 Package Outline Dimensions
JS
MI
Dimensions In Millimeters
Min
Max
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP
1.800
2.000
0.550 REF
0.300
0.500
0°
8°
O
Dimensions In Inches
Min
Max
0.045
0.035
0.000
0.004
0.035
0.041
0.012
0.020
0.006
0.003
0.118
0.110
0.055
0.047
0.100
0.089
0.037 TYP
0.071
0.079
0.022 REF
0.012
0.020
0°
8°
co
www.jsmsemi.com
r
to
uc
nd
SOT-23 Suggested Pad Layout
mi
Se
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
CR
Symbol
第5/6页
AO3400A
SOT-23 -3L Package Outline Dimensions
JS
MI
Min.
Max.
1.050
1.250
0.000
0.100
1.050
1.150
0.300
0.500
0.100
0.200
2.820
3.020
1.500
1.700
2.650
2.950
0.950(BSC)
1.800
2.000
0.300
0.600
0°
8°
Min.
Max.
0.041
0.049
0.000
0.004
0.041
0.045
0.012
0.020
0.004
0.008
0.111
0.119
0.059
0.067
0.104
0.116
0.037(BSC)
0.071
0.079
0.012
0.024
0°
8°
O
co
mi
Se
A
A1
A2
b
c
D
E1
E
e
e1
L
CR
Symbol
www.jsmsemi.com
r
to
uc
nd
SOT-23-3L Suggested Pad Layout
第6/6页
很抱歉,暂时无法提供与“AO3400A”相匹配的价格&库存,您可以联系我们找货
