XL-304PDC
XL-304PDC
    XINGLIGHT(成兴光)
    插件,D=3mm
    F3/3mm红外接收管
XL-304PDC 数据手册
XL-304PDC F3接收管 Technical Data Sheet characteristic * 外观尺寸:F3/3.85*3.0*5.3*18mm Appearance dimension:F3/3.85*3.0*5.3*18mm * 发光颜色及胶体:红外接收/黑色胶体 Luminous color and colloid: infrared receiver tube /black colloid * 环保工艺符合ROHS要求 Environmental protection products Complied With ROHS Directive * 湿气敏感性等级(MSL):4-5级 Moisture sensitivity level(MSL): 4-5 levels * EIA规范标准包装 EIA standard packaging * 使用寿命长 Long operating life * 高能效、启动快 High energy efficiency, fast startup product application * 医用设备:内窥镜、血氧仪 Medica l equipment: endoscope 、 oximet er * 红外遥控器 Inf rare d remot e cont roll er * 摄像监控头 Cam era monitoring he ad * 工业控制:计数器、热成像、智能电表 Indu st ri al cont rol: count ers, the rmal imagi ng, sm art me te r * 红外光电开关 Inf rare d photoe le ct ric sw it ch * 无线通信与信号传输 Wireless commu nication and signal transmission * 智能小车,机器人 Int el li ge nt car, robot 1 电性参数 Electrical Characteristics............................................................................................................3 典型特性曲线 Typical Characteristic Curves....................................................................................................................6 外形尺寸 Outline Dimensions......................................................................................................................................7 包装 Packaging.......................................................................................................................................................8 使用注意事项 Precautions.......................................................................................................................................9 2 Electrical Characteristics 参数名称 Parameter 符号 Symbol 集电极-发射极电压 Collector Emitter Voltage VCEO 30 VECO 5 发射极-集电极电压 Emitter collector voltage 工作环境温度 Operating ambient temperature 储存环境温度 Storage ambient temperature 焊接条件 Welding conditions 最大额定值 Maximum rating V V Topr -20°C ~ +85°C Tstg -40°C ~ +85°C Tsol 单位 Unit 波峰焊(reflow soldering):240°C,≦6s 手动焊(manual welding ):300°C,3s 焊接点离胶体底部在3.5mm以上 * 注: 脉冲宽度≤0. 1ms , 占空比≤1/10 * Note: Pulse width≤0. 1ms, Duty≤1/10 3 光电参数(Initial Electrical Optical Characteristics)(Ta=25℃) 项目参数 符号 最小值 Parameter Symbol Min 集电极-发射极击穿电压 Collector emitter breakdown voltage Vbr ceo 30 发射极-集电极击穿压 Emitter to collector breakdown voltage 集电极-基极击穿电压 Collector to emitter breakdown voltage Vbr ceo 代表值 最大值 单位 测试条件 Max Unit Condition / / V Ic=100uA 5 / / deg IE=100UA Vce(SAT) / / 0.8 nm IC=0.1Ma 集电极暗电流 Collector dark current Io / / 100 nA Vce=10v 上升时间Rise time 10%-90% Tr / 3 / 下降时间Fall time 90%-10% Tf / 3 / 1 / 2 2 / 4 3 / 8 4 / 状态集电极电流On sate collector current I(0n) Represe ntative uS Vce=5v V RL=100oh ms mA Vce=5V Ee=1mW/ 平方厘米 Λ=940nm 备注: 1. 此发光亮度为根据人眼对发光亮度之感应曲线之模拟发光强度符合CIE(国际光委会组织) 2. 此发光角度之测量为其发光亮度一半时所测试之数据 3. 发光亮度保证误差正负15% 1. The luminous intensity is the simulated luminous intensity according to the response curve of human eyes to luminous intensity, which conforms to CIE (International Commission on light)The aging experiment has proved that the service life of the LED, when IF=20mA and VF= 2.5 V, is 3 —— and 50,000 hours. 2. The measurement of the luminous angle is the data measured when the luminous brightness is half 3. Guaranteed error of luminous brightness is plus or minus 15% 4 状态集电极电流 On sate collector current division: 代码 Code 最小值 最大值 Min Max ION1 1 2 ION2 2 4 ION3 3 8 ION4 4 测试条件 单位 unit Test conditions mA Vce=5V 5 Typical Characteristics Curves 6 Outline Dimension 备注(Note): 1. 标注尺寸单位为毫米 Dimensions are in millimeters 2. 除特别标注外,所有尺寸允许公差± 0.10mm Tolerances unless mentioned are ± 0.10mm 7 1 Packaging (1) *袋 装 In Bags *防 潮 抗 静 电 包 装 Moisture Proof and Anti-Electrostatic Foil Bag 8 1 Precautions (1) 1. 应用 APPLY 此LED可使用于一些普通的电子设备,例如办公设备,通信设备、房屋装饰,若LED用在一些可靠性要求较高的 情况下,如航空运输,交通控制及医辽器械时,一定需参考销售提供之资料进行使用。 This LED can be used in some ordinary electronic equipment, such as office equipment, communication equipment, house decoration, if LED is used in some high reliability requirements, such as air transportation, traffic control and medical liao equipment, must refer to the information provided by sales. 2. 储存 Keep in storage 贮存LED的环境,温度不超过30℃,相对湿度不超过70%。 建议LED在原包装箱里日期不超过三个月 进行使用, 如果需加长贮存时间,建议放在干燥箱内,并加放干燥剂, 或者充入氮气。 Storage environment of LED with temperature not exceeding 30℃ and relative humidity not exceeding 70%.It is recommended that LDE be used in the original box for no more than three months. If longer storage time is required, put it in the drying box and add desiccant or filled with nitrogen. 3. 清洗 Clean 当用化学品清洗胶体时必须特别小心,因为有些化学品对胶体表面有损伤并引起褪色如三氯乙烯、丙、酮等。 可用乙醇擦拭、浸渍,时间在常温下不超过3分钟。 Special care must be taken when cleaning colloids with chemicals, as some chemicals have damage to the colloidal surface and cause fading such as trichloroethylene, propylene, ketone, etc.It can be wiped and soaked with ethanol for no more than 3 minutes at room temperature. 4. 引脚配置 Feet assembly (1)必需离胶体2毫米才能折弯支架。 It must be 2 mm from the colloid to bend the bracket. (2)支架成形必须用夹具或由专业人员来完成。 Support forming must be done with fixtures or by a professional. (3)支架成形必须在焊接前完成。 Support forming must be completed before welding. (4)支架成形需保证引脚和间距与线路板上一致。 The pins and spacing are the same as on the circuit board. (5)焊接必须在正常温度下进行,当LED正常焊接到PCB板上后,应尽量避免在LED引脚处施加机械压力。 Welding must be performed at normal temperature and when LED is normally welded to the PCB plate, avoid applying mechanical pressure at LED pins at a minimum. 9 2 Precautions (2) 10 3 Precautions (3) Others: *直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也可能直接影响封装内部 的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回 流焊接过程中。 *When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially when the LEDs are heated such as during Reflow Soldering. *LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时候也 应当小心注意。 *The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While handling the product with tweezers, do not hold by the epoxy resin, be careful. Safety Advice For Human Eyes *LED 发光时,请勿直视发光光源,特别是对于一些光强较高的 LED ,强光可能伤害你的眼睛。 *Viewing direct to the light emitting center of the LEDs, especially those of great Luminous Intensity, will cause great hazard to human eyes. Please be careful. 11
XL-304PDC 价格&库存
很抱歉,暂时无法提供与“XL-304PDC”相匹配的价格&库存,您可以联系我们找货
XL-304PDC
    • 1+0.30220
    • 100+0.28320
    • 300+0.26420
    • 500+0.24520
    • 2000+0.23570
    • 5000+0.23000
    库存:1000
    XL-304PDC
    • 10+0.51080
    • 100+0.44120
    • 300+0.37160
    • 500+0.27860
    • 1000+0.23220
    • 5000+0.22060
    库存:12980
    XL-304PDC
    • 10+0.42650
    • 100+0.34193
    • 300+0.29960
    • 1000+0.26795
    • 5000+0.24257
    • 10000+0.22983
    库存:1667
