KNSCHA Snap-in Type Aluminum Electrolytic Capacitors
Customer :
◆KNSCHA STH Series
Snap-in Terminal Type Aluminum Electrolytic Capacitors,105°C Standard
PRODUCT CHARACTERISTICS
Cap.
(120Hz)
Cap.
Tol.
Rate
Volt.
Surge
Volt.
Oper.
Temp.
Nominal
Case Size
Leakage
Current
D.F.
Max
RC
120HZ
ESR
100KHZ
Normal
servicelife
(uF)
(V-DC)
(V-DC)
D*L(mm)
Max(uA)
(Arms)
(Ω)
(Hours)
152EC0329
470
±20
450
500
-25∽105℃
30*50
1379
0.20
1.80
2000
152EC0330
220
±20
450
500
-25∽105℃
25*30
944
0.20
1.11
2000
152EC0333
2200
±20
100
125
-40∽105℃
25*40
1407
0.20
2.29
2000
152EC0335
270
±20
450
500
-25∽105℃
25*40
1046
0.20
1.24
2000
152EC0336
470
±20
250
300
-40∽105℃
25*30
1028
0.15
1.44
2000
152EC0337
680
±20
400
450
-25∽105℃
35*40
1565
0.20
1.93
2000
152EC0338
6800
±20
50
62
-40∽105℃
25*40
1749
0.25
2.94
2000
152EC0339
1000
±20
400
450
-25∽105℃
35*60
1897
0.20
2.66
2000
152EC0341
15000
±20
63
78
-40∽105℃
35*50
2916
0.25
5.10
2000
152EC0342
1000
±20
450
500
-25∽105℃
35*66
2012
0.20
3.08
2000
152EC0343
220
±20
400
450
-25∽105℃
30*30
890
0.20
1.05
2000
152EC0347
560
±20
450
500
-25∽105℃
30*50
1506
0.20
1.87
2000
152EC0348
820
±20
450
500
-25∽105℃
35*60
1822
0.20
2.68
2000
152EC0349
100
±20
400
450
-25∽105℃
22*25
600
0.20
0.63
2000
KNSCHA P/N
-------------------------------------------------------------------------------------------PRODUCT CHARACTERISTICS
AL RIVET
TERMINAL
BAKE LITE
AL TAB
AL TAB
VINYL SLEEVE
CATHODE FOIL
ANODE FOIL
AL CASE
ELEMENT
ADHESIVE TAPE
BOTTOM PLATE(Φ20↑)
SEPARATOR
SAFETY VENT
LARGE SIZED TYPE CAPACITORS COMPONENT
MATERIALS
PART NAME
AL RIVET
ALUMINUM 99.9%
TERMINAL
SPCC
BAKE LITE
RUBBER+PAPER LAMINATE
AL TAB
ALUMINUM 99.9% OVER
INK
SLEEVE
P.E.T (Polyethylene Terephthalate Resin)
AL CASE
ALUMINUM 99.5%
ANODE FOIL
FORMED ALUMINUM 99.9% OVER
CATHODE FOIL
FORMED ALUMINUM 98.4% OVER
SEPARATOR
INSULATION PAPER
ADHESIVE TAPE
POLY PROPYLENE FILM
第8页,共18页
很抱歉,暂时无法提供与“152EC0349”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.51988
- 10+4.56570
- 30+4.09374
- 100+3.62178
- 640+3.60126
- 960+3.45762
- 国内价格
- 1+4.32100
- 30+4.17200
- 100+3.87400
- 500+3.57600
- 1000+3.42700
