MMBT3906M
PNP Transistors
3
Features
Complementary to MMBT3904M
1. Base
2. Emitter
3. Collector
2
Small Package
1
■ Simplified outline(SOT-723)
Absolute Maximum Ratings Ta = 25
Parameter
Symbol
Value
Unit
VCBO
Collector-Base Voltage
-40
V
VCEO
Collector-Emitter Voltage
-40
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-0.2
A
PC
Power Dissipation
100
mW
Thermal Resistance from Junction to Ambient
1250
℃/W
TJ
Junction Temperature
150
Tstg
storage Temperature
-55~+150
RΘJA
Electrical Characteristics Ta = 25
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-10µA,IE=0
-40
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=-1mA,IB=0
-40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10µA,IC=0
-5
ICBO
VCB=-40V,IE=0
Collector cut-off current
ICEX
Emitter cut-off current
IEBO
hFE(1)
VCE=-1V,IC=-10mA
hFE(2)
VCE=-1V,IC=-50mA
60
hFE(3)
VCE=-2V,I C=-100mA
30
DC current gain
V
-100
nA
VCE=-30V,VEB(off)=-3V
-50
nA
VEB=-5V,IC=0
-100
nA
100
300
Collector-emitter saturation voltage
VCE(sat)
IC=-50mA,IB=-5mA
-0.3
V
Base-emitter saturation voltage
VBE(sat)
IC=-50mA,IB=-5mA
-0.95
V
Transition frequency
fT
Delay time
td
Rise time
tr
Storage time
ts
Fall time
tf
www.slkormicro.com
VCE=-20V,IC=-10mA,f=100MHz
300
MHz
VCC=-3V,VBE(off)=-0.5V,
IC=-10mA, IB1=IB2=-1mA
35
35
ns
VCC=-3V,IC=-10mA
IB1=IB2=-1mA
225
ns
75
ns
1
ns
Rev.1 -- 17 August 2016
MMBT3906M
Static Characteristic
-80
hFE
200
DC CURRENT GAIN
COLLECTOR CURRENT
IC
COMMON EMITTER
VCE=-1V
-350uA
-300uA
-250uA
-200uA
-40
Ta=100℃
-400uA
-60
hFE
300
COMMON
EMITTER
Ta=25℃
-500uA
-450uA
IC
(mA)
-100
-150uA
Ta=25℃
100
-100uA
-20
IB=-50uA
-0
-0
-4
-8
-12
-16
COLLECTOR-EMITTER VOLTAGE
VCEsat
-500
VCE
-20
-1
-0.3
-10
-3
COLLECTOR CURRENT
(V)
IC
VBEsat
-1.2
-100
-30
IC
-200
(mA)
IC
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-300
Ta=100℃
-100
Ta=25℃
-30
Ta=25℃
-0.8
Ta=100℃
-0.4
β=10
-10
β=10
-0.0
-1
-30
-10
-3
COLLECTOR CURRENT
IC
-100
IC
-100
-1
-200
-10
-3
(mA)
-100
-30
COLLECTOR CURRENT
—— VBE
Cob/ Cib
9
IC
VCB/ VEB
f=1MHz
IE=0/IC=0
-30
Ta=25℃
Cob
(pF)
Ta=100℃
Cib
C
-10
CAPACITANCE
IC
(mA)
COMMON EMITTER
VCE=-1V
COLLECTOR CURRENT
-200
(mA)
-3
Ta=25℃
-1
3
-0.3
-0.1
-0.2
-0.4
-0.6
-0.8
-1.0
1
-0.1
-1.2
fT
600
—— IC
-1
-3
REVERSE VOLTAGE
V
-0.3
BASE-EMMITER VOLTAGE VBE (V)
PC
150
-10
-20
(V)
Ta
VCE=-20V
TRANSITION FREQUENCY
fT
COLLECTOR POWER DISSIPATION
PC (mW)
(MHz)
Ta=25℃
400
200
100
50
-3
-10
COLLECTOR CURRENT
www.slkormicro.com
-30
IC
(mA)
25
50
75
AMBIENT TEMPERATURE
2
100
Ta
125
150
MMBT3906M
■ SOT-723
0.5
1 mm
scale
DIMENSIONS (mm are the original dimensions)
www.slkormicro.com
UNIT
A
A1
max
b
b1
c
D
E
E1
mm
0.43
0.50
0.05
0.17
0.27
0.27
0.37
0.08
0.15
1.15
1.25
0.15
0.25
0.75
0.85
3
很抱歉,暂时无法提供与“MMBT3906M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12170
- 200+0.10103
- 600+0.08956
- 2000+0.08269
- 8000+0.07673
- 16000+0.07355
- 国内价格 香港价格
- 8000+0.197638000+0.02568
- 16000+0.1769316000+0.02299
- 24000+0.1663624000+0.02161
- 40000+0.1544640000+0.02007
- 56000+0.1474256000+0.01915
- 80000+0.1405780000+0.01826
- 国内价格 香港价格
- 1+1.237461+0.16074
- 10+0.7318110+0.09506
- 100+0.45168100+0.05867
- 500+0.32659500+0.04243
- 1000+0.285821000+0.03713
- 2000+0.251342000+0.03265
