MBR130T1G
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
SOD-123
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 °C/10 seconds at terminals
0.075(1.90)
0.067(1.70)
0.031 (0.08)
0.043 (1.10)
0.114(2.90)
0.102(2.60)
0.043(1.10)
0.035(0.90)
0.008(0.20)
0.005(0.12)
0.035(0.90)
0.028(0.70)
0.154(3.90)
0.141(3.60)
Mechanical Data
Case : JEDEC SOD-123FL molded plastic body
Terminals : Solderable per MIL-STD-750,Method
2026 Polarity : Color band denotes cathode end
Mounting Position : Any
Weight : 0.0007 ounce, 0.02 grams
Dimensions in inches and (millimeters)
MARKING DIAGRAM
SL
1
ORDERING INFORMATION
www.tokmas.com
Device
Package
Shipping†
SL
SOD-123
(Pb−Free)
3000 /
Tape & Reel
MBR130T1G
MAXIMUM RATINGS
Symbol
Value
Unit
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Rating
VRRM
VRWM
VR
30
V
Average Rectified Forward Current
(Rated VR) TL = 65°C
IF(AV)
Non−Repetitive Peak Surge Current
(Surge Applied at Rated Load Conditions, Halfwave, Single Phase, 60 Hz)
IFSM
Storage Temperature Range
Tstg
−65 to +125
°C
Operating Junction Temperature
TJ
−65 to +125
°C
dv/dt
1000
V/ms
A
1.0
A
5.5
Voltage Rate of Change (Rated VR)
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality
should not be assumed, damage may occur and reliability may be affected.
THERMAL CHARACTERISTICS
Characteristic
Symbol
Value
Unit
Thermal Resistance, Junction to Ambient (Note 1)
RθJA
230
°C/W
Thermal Resistance, Junction to Lead (Note 1)
RθJL
108
°C/W
Typ
Max
Unit
0.47
0.35
0.45
1. FR−4 or FR−5 = 3.5 × 1.5 inches using a 1 inch Cu pad.
ELECTRICAL CHARACTERISTICS
Characteristic
Symbol
Instantaneous Forward Voltage (Note 2)
(IF = 0.1 A, TJ = 25°C)
(IF = 0.7 A, TJ = 25°C)
(IF = 1.0 A, TJ = 25°C)
VF
Maximum Instantaneous Reverse Current (Note 2)
(Rated DC Voltage, TC = 25°C)
(VR = 5 V, TC = 25°C)
IR
V
mA
60
10
Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product
performance may not be indicated by the Electrical Characteristics if operated under different conditions.
2. Pulse Test: Pulse Width = 300 ms, Duty Cycle ≤ 2%.
www.tokmas.com
MBR130T1G
10
IF, INSTANTANEOUS FORWARD
CURRENT (AMPS)
CURRENT (AMPS)
10
1
TJ = 125°C
75°C
0.1
0.2 0.25
0.3
0.35
25°C
0.4
0.45 0.5
0.55
0.6
1
TJ = 125°C
75°C
0.1
0.65
0.2 0.25
VF, INSTANTANEOUS FORWARD VOLTAGE (VOLTS)
0.4
0.45 0.5
0.55
0.6 0.65
Figure 2. Typical Forward Voltage
0.01
200
TJ = 125°C
180
C, CAPACITANCE (pF)
0.001
75°C
0.0001
0.00001
25°C
0.000001
160
140
120
100
80
60
40
10
15
VR, REVERSE VOLTAGE (VOLTS)
30
Figure 3. Typical Reverse Current
1.8
1.6
dc
1.4
RATED
VOLTAGE
APPLIED
1.2
SQUARE
WAVE
1
0.8
0.6
0.4
0.2
60
80
100
TL, LEAD TEMPERATURE (°C)
120
Figure 5. Current Derating, Lead, RqJL = 1085C/W
10
15
30
35
Figure 4. Typical Capacitance
PF(AV), AVERAGE FORWARD POWER
DISSIPATION (WATTS)
IF(AV), AVERAGE FORWARD CURRENT (AMPS)
0.35
Figure 1. Maximum Forward Voltage
IR, REVERSE CURRENT (AMPS)
0.3
25°C
0.9
0.8
0.7
SQUARE
WAVE
0.6
dc
0.5
0.4
0.3
0.2
0.1
0.4
0.6 0.8
1
1.2 1.4 1.6 1.8
Figure 6. Forward Power Dissipation
www.tokmas.com
MBR130T1G
Packing information
unit:mm
P0
P1
Item
d
E
F
B
A
W
P
D2
D1
T
C
D
W1
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-123
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Suggested Pad Layout
Symbol
Unit (mm)
A
1.2
0.047
B
1.2
0.047
C
3.2
0.126
D
2
0.079
E
4.4
0.173
www.tokmas.com
Unit (inch)
很抱歉,暂时无法提供与“MBR130T1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.70415
- 20+0.69159
- 100+0.66643
