11/18/23, 2:40 AM
Audio Broadcast Quality (800A Series) - Hammond Mfg.
Quality Products. Service Excellence.
Audio Broadcast Quality 800A Series
Features
Deep-drawn steel case with tin plated finish, with two convenient 6-32 mounting studs
with hardware.
Includes wire leads (minimum length of 4").
Frequency response +/- 0.5 db max. from 50 Hz. to 15 Khz.
Insertion loss of apx. 1 db.
Maximum power level +15 dbm. (except 841A, 842A & 844A which are +20 dbm) with
specified characteristics, or higher levels with reduced low frequency performance.
Electrostatic shield between pri. & sec.
Humbucking construction
Balanced split windings on pri. & sec. for circuit versatility. Primary may be used as a
secondary and vice versa for impedance matching.
Overall dimensions 1.75" (44.5 mm) wide x 1.25" (31.8 mm) deep x 2.56" (65 mm) high
max.
Shipping weight 0.5 lb. (0.2 kg)
https://www.hammfg.com/electronics/transformers/audio/800a
1/3
11/18/23, 2:40 AM
2/3
11/18/23, 2:40 AM
Part No.
Application
Nominal Impedance
Max. Primary D.C.
(Ohms)
Unbalanced Current
Primary
Secondary
(ma.)
801A
Isolating, Matching
*50/200
50/200
0.8
802A
Isolating, Matching
*50/200 (60/240)
125/500 (150/600)
0.8
804A
Isolating, Matching, Hybrid
*125/500 (150/600)
125/500 (150/600)
0.5
806A
Dynamic MIC or Voice Coil to Grid
*7.5/30
10K/40K
1.6
807A
Dynamic MIC or Voice Coil to Base
*7.5/30
600/2400
1.6
808A
MIC or Mixer to Single or P.P. Grid
*50/200
10000/40000
0.6
809A
MIC to Mixer to Base
*50/200
600/2400
0.6
812A
Line or 150 ohm MIC to 1 or 2 Grids
*125/500 (150/600)
10K/40K (12K/48K)
0.4
813A
Line or 150 ohm MIC to Base
*125/500 (150/600)
600/2400 (720/2880)
0.4
832A
Interstage (ratio 1:2)
5K/20K
20K/80K
834A
Interstage (ratio 1:1.4)
5K/20K
10K/40K
835A
Interstage (ratio 1:1)
10K/40K
10K/40K
841A
** P.P. Plates to Line
5K/20K
50/200
842A
5K/20K (6K/24K)
125/500 (150/600)
844A
10K/40K (12K/48K)
125/500 (150/600)
* Electrostatic shield between primary & secondary ** Single plate requires parallel feed. When operating at impedances below nominal, power capability is lower and
the frequency spectrum is shifted downward, conversely, at higher impedances power capability and frequency spectrum will be shifted upward.
Tags: audio transformer, broadcast, steel case, humbucking, shield, split windings, impedance
matching, stud mounting
Data subject to change without notice
© 2023. Hammond Manufacturing Ltd. All rights reserved.
3/3
很抱歉,暂时无法提供与“806A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2557.55880
- 200+1020.48120
- 500+986.38560
- 1000+969.53760
